{"name":"Rocketbot","description":"Suite completa de Automatizaci\u00f3n Empresarial end-to-end","url":"http:\/\/rocketbot.com","home":"https:\/\/rocketbot.com\/pt-br\/","gmt_offset":"0","timezone_string":"","page_for_posts":2964,"page_on_front":1407,"show_on_front":"page","namespaces":["oembed\/1.0","wpml\/v1","contact-form-7\/v1","cookieyes\/v1","cky\/v1","jetpack\/v4","quiz-survey-master\/v1","qsm","quiz-survey-master\/v2","templately\/v1","wordfence\/v1","wp-rollback\/v1","elementor-one\/v1","wpml\/tm\/v1","wpml\/ate\/v1","wpml\/st\/v1","wpcom\/v2","jetpack\/v4\/stats-app","elementor\/v1","elementor-pro\/v1","wpcom\/v3","post-views-counter","wp-smush\/v1","hub-connector\/v1","jetpack-boost\/v1","my-jetpack\/v1","jetpack\/v4\/explat","elementskit\/v1\/ajaxselect2","elementor\/v1\/documents","elementor-ai\/v1","elementor\/v1\/feedback","elementskit\/v1\/widget\/mailchimp","elementskit\/v1\/dynamic-content","elementskit\/v1\/layout-manager-api","elementskit\/v1\/my-template","elementskit\/v1\/megamenu","elementskit\/v1\/widget-builder","wpmudev_pcs\/v1","otgs\/installer\/v1","wp\/v2","wp-site-health\/v1","wp-block-editor\/v1","wp-abilities\/v1"],"authentication":[],"routes":{"\/":{"namespace":"","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/"}]}},"\/batch\/v1":{"namespace":"","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"validation":{"type":"string","enum":["require-all-validate","normal"],"default":"normal","required":false},"requests":{"type":"array","maxItems":25,"items":{"type":"object","properties":{"method":{"type":"string","enum":["POST","PUT","PATCH","DELETE"],"default":"POST"},"path":{"type":"string","required":true},"body":{"type":"object","properties":[],"additionalProperties":true},"headers":{"type":"object","properties":[],"additionalProperties":{"type":["string","array"],"items":{"type":"string"}}}}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/batch\/v1"}]}},"\/oembed\/1.0":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"oembed\/1.0","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/oembed\/1.0"}]}},"\/oembed\/1.0\/embed":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"O URL do recurso de onde devem ser coletados os dados do oEmbed.","type":"string","format":"uri","required":true},"format":{"default":"json","required":false},"maxwidth":{"default":600,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/oembed\/1.0\/embed"}]}},"\/oembed\/1.0\/proxy":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"O URL do recurso de onde devem ser coletados os dados do oEmbed.","type":"string","format":"uri","required":true},"format":{"description":"O formato oEmbed a ser usado.","type":"string","default":"json","enum":["json","xml"],"required":false},"maxwidth":{"description":"A largura m\u00e1xima, em p\u00edxeis, do frame da m\u00eddia incorporada.","type":"integer","default":600,"required":false},"maxheight":{"description":"A altura m\u00e1xima, em p\u00edxeis, do frame da m\u00eddia incorporada.","type":"integer","required":false},"discover":{"description":"Fazer ou n\u00e3o uma requisi\u00e7\u00e3o de descoberta para um servidor oEmbed n\u00e3o pertencente \u00e0 lista de servidores permitidos.","type":"boolean","default":true,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/oembed\/1.0\/proxy"}]}},"\/wpml\/v1":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wpml\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wpml\/v1"}]}},"\/wpml\/v1\/custom-xml-config":{"namespace":"wpml\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wpml\/v1\/custom-xml-config"}]}},"\/wpml\/v1\/custom-xml-config\/validate":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wpml\/v1\/custom-xml-config\/validate"}]}},"\/contact-form-7\/v1":{"namespace":"contact-form-7\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"contact-form-7\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/contact-form-7\/v1"}]}},"\/contact-form-7\/v1\/contact-forms":{"namespace":"contact-form-7\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/contact-form-7\/v1\/contact-forms"}]}},"\/contact-form-7\/v1\/contact-forms\/(?P<id>\\d+)":{"namespace":"contact-form-7\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["DELETE"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/contact-form-7\/v1\/contact-forms\/(?P<id>\\d+)\/feedback":{"namespace":"contact-form-7\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/contact-form-7\/v1\/contact-forms\/(?P<id>\\d+)\/feedback\/schema":{"namespace":"contact-form-7\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/contact-form-7\/v1\/contact-forms\/(?P<id>\\d+)\/refill":{"namespace":"contact-form-7\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/cookieyes\/v1":{"namespace":"cookieyes\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"cookieyes\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/cookieyes\/v1"}]}},"\/cookieyes\/v1\/fetch_results":{"namespace":"cookieyes\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/cookieyes\/v1\/fetch_results"}]}},"\/cky\/v1":{"namespace":"cky\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"cky\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/cky\/v1"}]}},"\/cky\/v1\/uninstall-feedback":{"namespace":"cky\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/cky\/v1\/uninstall-feedback"}]}},"\/jetpack\/v4":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"jetpack\/v4","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4"}]}},"\/jetpack\/v4\/backup-helper-script":{"namespace":"jetpack\/v4","methods":["POST","DELETE"],"endpoints":[{"methods":["POST"],"args":{"helper":{"description":"Corpo do script auxiliar de backup codificado em Base64.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["DELETE"],"args":{"path":{"description":"Caminho para o script auxiliar de backup","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/backup-helper-script"}]}},"\/jetpack\/v4\/database-object\/backup":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"object_type":{"description":"Tipo de objeto a ser buscado no banco de dados","required":true},"object_id":{"description":"ID do objeto de banco de dados a ser buscado","type":"integer","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/database-object\/backup"}]}},"\/jetpack\/v4\/options\/backup":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"name":{"description":"Um nome opcional ou mais a serem inclu\u00eddos no backup","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/options\/backup"}]}},"\/jetpack\/v4\/comments\/(?P<id>\\d+)\/backup":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/jetpack\/v4\/posts\/(?P<id>\\d+)\/backup":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/jetpack\/v4\/terms\/(?P<id>\\d+)\/backup":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/jetpack\/v4\/users\/(?P<id>\\d+)\/backup":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/jetpack\/v4\/site\/backup\/undo-event":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/site\/backup\/undo-event"}]}},"\/jetpack\/v4\/orders\/(?P<id>\\d+)\/backup":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/jetpack\/v4\/site\/backup\/preflight":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/site\/backup\/preflight"}]}},"\/jetpack\/v4\/jetpack-ai-jwt":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/jetpack-ai-jwt"}]}},"\/jetpack\/v4\/plans":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/plans"}]}},"\/jetpack\/v4\/products":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/products"}]}},"\/jetpack\/v4\/marketing\/survey":{"namespace":"jetpack\/v4","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/marketing\/survey"}]}},"\/jetpack\/v4\/connection\/test":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/connection\/test"}]}},"\/jetpack\/v4\/connection\/test-wpcom":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/connection\/test-wpcom"}]}},"\/jetpack\/v4\/rewind":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/rewind"}]}},"\/jetpack\/v4\/scan":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/scan"}]}},"\/jetpack\/v4\/connection\/url":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"from":{"type":"string","required":false},"redirect":{"type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/connection\/url"}]}},"\/jetpack\/v4\/tracking\/settings":{"namespace":"jetpack\/v4","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"tracks_opt_out":{"type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/tracking\/settings"}]}},"\/jetpack\/v4\/site":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/site"}]}},"\/jetpack\/v4\/site\/features":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/site\/features"}]}},"\/jetpack\/v4\/site\/products":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/site\/products"}]}},"\/jetpack\/v4\/site\/purchases":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/site\/purchases"}]}},"\/jetpack\/v4\/site\/benefits":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/site\/benefits"}]}},"\/jetpack\/v4\/site\/activity":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/site\/activity"}]}},"\/jetpack\/v4\/module\/all":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/module\/all"}]}},"\/jetpack\/v4\/module\/all\/active":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"modules":{"default":"","type":"array","items":{"type":"string"},"required":true},"active":{"default":true,"type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/module\/all\/active"}]}},"\/jetpack\/v4\/module\/(?P<slug>[a-z\\-]+)":{"namespace":"jetpack\/v4","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"context":{"default":"edit","required":false},"jetpack_blocks_disabled":{"description":"Blocos do Jetpack desativados.","type":"boolean","default":false,"required":false},"carousel_background_color":{"description":"Esquema de cores.","type":"string","default":"black","enum":["black","white"],"required":false},"carousel_display_exif":{"description":"Mostrar metadados de foto (<a href=\"https:\/\/en.wikipedia.org\/wiki\/Exchangeable_image_file_format\" target=\"_blank\">Exif<\/a>) em carrossel, quando dispon\u00edvel.","type":"boolean","default":0,"required":false},"carousel_display_comments":{"description":"Mostrar \u00e1rea de coment\u00e1rios em carrossel","type":"boolean","default":1,"required":false},"highlander_comment_form_prompt":{"description":"Texto de Sauda\u00e7\u00e3o","type":"string","default":"Deixe uma resposta","required":false},"jetpack_comment_form_color_scheme":{"description":"Combina\u00e7\u00e3o de cores","type":"string","default":"light","enum":["light","dark","transparent"],"required":false},"jetpack_portfolio":{"description":"Ativar ou desativar tipo de post para portf\u00f3lio do Jetpack.","type":"boolean","default":0,"required":false},"jetpack_portfolio_posts_per_page":{"description":"N\u00famero m\u00e1ximo de entradas a exibir em p\u00e1ginas de Portf\u00f3lio.","type":"integer","default":10,"required":false},"jetpack_testimonial":{"description":"Ativar ou desativar tipo de post para depoimento do Jetpack.","type":"boolean","default":0,"required":false},"jetpack_testimonial_posts_per_page":{"description":"N\u00famero m\u00e1ximo de entradas a exibir nas p\u00e1ginas de Depoimentos.","type":"integer","default":10,"required":false},"jetpack_waf_automatic_rules":{"description":"Ative regras autom\u00e1ticas: proteja seu site contra fontes de tr\u00e1fego n\u00e3o confi\u00e1veis, com regras de seguran\u00e7a autom\u00e1ticas.","type":"boolean","default":false,"required":false},"jetpack_waf_ip_block_list_enabled":{"description":"Lista de bloqueios: bloqueie uma solicita\u00e7\u00e3o de IP espec\u00edfico.","type":"boolean","default":0,"required":false},"jetpack_waf_ip_block_list":{"description":"Endere\u00e7os IP bloqueados","type":"string","default":"","required":false},"jetpack_waf_ip_allow_list_enabled":{"description":"Lista de permiss\u00f5es: permita uma solicita\u00e7\u00e3o de IP espec\u00edfico.","type":"boolean","default":0,"required":false},"jetpack_waf_ip_allow_list":{"description":"Endere\u00e7os IP sempre permitidos","type":"string","default":"","required":false},"jetpack_waf_share_data":{"description":"Compartilhe dados b\u00e1sicos com o Jetpack.","type":"boolean","default":0,"required":false},"jetpack_waf_share_debug_data":{"description":"Compartilhe dados detalhados com o Jetpack.","type":"boolean","default":0,"required":false},"tiled_galleries":{"description":"Exibir todas as suas fotos de galeria em um mosaico maneiro.","type":"boolean","default":0,"required":false},"gravatar_disable_hovercards":{"description":"Veja os perfis das pessoas quando passa o mouse sobre seus Gravatar","type":"string","default":"enabled","enum":["enabled","disabled"],"required":false},"infinite_scroll":{"description":"Para o infinito e al\u00e9m","type":"boolean","default":1,"required":false},"infinite_scroll_google_analytics":{"description":"Use o Google Analytics com a Rolagem Infinita","type":"boolean","default":0,"required":false},"wpl_default":{"description":"Curtidas WordPress.com","type":"string","default":"on","enum":["on","off"],"required":false},"social_notifications_like":{"description":"Enviar notifica\u00e7\u00e3o por e-mail quando algu\u00e9m curtir um post","type":"boolean","default":1,"required":false},"wpcom_publish_comments_with_markdown":{"description":"Usar Markdown para coment\u00e1rios.","type":"boolean","default":0,"required":false},"wpcom_publish_posts_with_markdown":{"description":"Use Markdown para posts.","type":"boolean","default":0,"required":false},"monitor_receive_notifications":{"description":"Receba notifica\u00e7\u00f5es do Monitor por e-mail.","type":"boolean","default":0,"required":false},"post_by_email_address":{"description":"Endere\u00e7o de e-mail","type":"string","default":"noop","enum":["noop","create","regenerate","delete"],"required":false},"jetpack_protect_key":{"description":"Chave da API do Proteger","type":"string","default":"","required":false},"jetpack_protect_global_whitelist":{"description":"Proteger lista global de IPs permitidos","type":"string","default":"","required":false},"sharing_services":{"description":"Servi\u00e7os ativados e ocultos atr\u00e1s de um bot\u00e3o","type":"object","default":{"visible":["facebook","x"],"hidden":[]},"required":false},"button_style":{"description":"Estilo do bot\u00e3o","type":"string","default":"icon","enum":["icon-text","icon","text","official"],"required":false},"sharing_label":{"description":"R\u00f3tulo de compartilhamento","type":"string","default":"","required":false},"show":{"description":"Exibi\u00e7\u00f5es onde os bot\u00f5es s\u00e3o mostrados","type":"array","items":{"type":"string"},"default":["post"],"required":false},"jetpack-twitter-cards-site-tag":{"description":"O nome de usu\u00e1rio no Twitter do propriet\u00e1rio do dom\u00ednio deste site.","type":"string","default":"","required":false},"sharedaddy_disable_resources":{"description":"Desativar CSS e JS","type":"boolean","default":0,"required":false},"custom":{"description":"Servi\u00e7os de compartilhamento personalizados adicionados pelo usu\u00e1rio.","type":"object","default":{"sharing_name":"","sharing_url":"","sharing_icon":""},"required":false},"sharing_delete_service":{"description":"Excluir servi\u00e7o de compartilhamento personalizado.","type":"string","default":"","required":false},"jetpack_sso_require_two_step":{"description":"Exige Autentica\u00e7\u00e3o Dois Fatores ","type":"boolean","default":false,"required":false},"jetpack_sso_match_by_email":{"description":"Coincidir por e-mail","type":"boolean","default":1,"required":false},"stb_enabled":{"description":"Mostrar uma op\u00e7\u00e3o &lt;em&gt;&#039;seguir blog&#039;&lt;\/em&gt; no formul\u00e1rio de coment\u00e1rio","type":"boolean","default":1,"required":false},"stc_enabled":{"description":"Mostrar a op\u00e7\u00e3o &lt;em&gt;&#039;seguir coment\u00e1rios&#039;&lt;\/em&gt; no formul\u00e1rio de coment\u00e1rios","type":"boolean","default":1,"required":false},"wpcom_newsletter_categories":{"description":"Array de IDs de categoria de post marcadas como categorias de newsletter","type":"array","default":[],"required":false},"wpcom_newsletter_categories_enabled":{"description":"Se as categorias de newsletter est\u00e3o ativadas ou n\u00e3o","type":"boolean","default":0,"required":false},"wpcom_featured_image_in_email":{"description":"Se \u00e9 para incluir a imagem destacada no e-mail ou n\u00e3o","type":"boolean","default":0,"required":false},"jetpack_gravatar_in_email":{"description":"Escolha mostrar ou n\u00e3o o avatar do autor no in\u00edcio do seu e-mail","type":"boolean","default":1,"required":false},"jetpack_author_in_email":{"description":"Escolha mostrar ou n\u00e3o o nome de exibi\u00e7\u00e3o do autor no in\u00edcio do seu e-mail","type":"boolean","default":1,"required":false},"jetpack_post_date_in_email":{"description":"Escolha mostrar ou n\u00e3o a data no in\u00edcio do seu e-mail","type":"boolean","default":1,"required":false},"wpcom_subscription_emails_use_excerpt":{"description":"Se \u00e9 para usar o resumo no e-mail ou n\u00e3o","type":"boolean","default":0,"required":false},"jetpack_subscriptions_reply_to":{"description":"Comportamento do e-mail para respostas \u00e0s suas newsletters","type":"string","default":"comment","required":false},"jetpack_subscriptions_from_name":{"description":"Nome de remetente para e-mails de newsletters","type":"string","default":"","required":false},"sm_enabled":{"description":"Exiba um modal popup de assinatura para os leitores.","type":"boolean","default":0,"required":false},"jetpack_subscribe_overlay_enabled":{"description":"Exibir a sobreposi\u00e7\u00e3o de assinatura na p\u00e1gina inicial.","type":"boolean","default":0,"required":false},"jetpack_subscribe_floating_button_enabled":{"description":"Mostra um bot\u00e3o flutuante de assinatura.","type":"boolean","default":0,"required":false},"jetpack_subscriptions_subscribe_post_end_enabled":{"description":"Adicione um bloco de assinatura ao final de cada post.","type":"boolean","default":0,"required":false},"jetpack_subscriptions_login_navigation_enabled":{"description":"Adicione o bloco de login do assinante \u00e0 navega\u00e7\u00e3o.","type":"boolean","default":0,"required":false},"jetpack_subscriptions_subscribe_navigation_enabled":{"description":"Adicione o bloco Assinar \u00e0 navega\u00e7\u00e3o.","type":"boolean","default":0,"required":false},"social_notifications_subscribe":{"description":"Enviar notifica\u00e7\u00e3o por e-mail quando algu\u00e9m assinar meu blog","type":"boolean","default":0,"required":false},"subscription_options":{"description":"Tr\u00eas op\u00e7\u00f5es usadas nos modelos de e-mail por assinatura: &quot;invitation&quot;, &quot;welcome&quot; e &quot;comment_follow&quot;.","type":"object","default":{"invitation":"","welcome":"","comment_follow":""},"required":false},"show_headline":{"description":"Destaque o conte\u00fado relacionado com um cabe\u00e7alho","type":"boolean","default":1,"required":false},"show_thumbnails":{"description":"Exibir uma miniatura de imagem quando dispon\u00edvel","type":"boolean","default":0,"required":false},"instant_search_enabled":{"description":"Ative a busca instant\u00e2nea","type":"boolean","default":0,"required":false},"has_jetpack_search_product":{"description":"Tem uma compra de produto ativa do Jetpack Search","type":"boolean","default":0,"required":false},"search_auto_config":{"description":"Acione uma configura\u00e7\u00e3o autom\u00e1tica de busca instant\u00e2nea","type":"boolean","default":0,"required":false},"google":{"description":"Console de busca do Google","type":"string","default":"","required":false},"bing":{"description":"Centro do webmaster Bing","type":"string","default":"","required":false},"pinterest":{"description":"Verifica\u00e7\u00e3o do Site Pinterest","type":"string","default":"","required":false},"yandex":{"description":"Verifica\u00e7\u00e3o de site Yandex","type":"string","default":"","required":false},"facebook":{"description":"Verifica\u00e7\u00e3o de dom\u00ednio do Facebook","type":"string","default":"","required":false},"enable_header_ad":{"description":"Exiba um an\u00fancio na parte superior de cada p\u00e1gina.","type":"boolean","default":1,"required":false},"wordads_approved":{"description":"Este site est\u00e1 aprovado para WordAds?","type":"boolean","default":0,"required":false},"wordads_second_belowpost":{"description":"Exibir um segundo an\u00fancio abaixo do post?","type":"boolean","default":1,"required":false},"wordads_inline_enabled":{"description":"Exibir an\u00fancio integrado ao conte\u00fado do post?","type":"boolean","default":1,"required":false},"wordads_display_front_page":{"description":"Exibir an\u00fancios na p\u00e1gina inicial?","type":"boolean","default":1,"required":false},"wordads_display_post":{"description":"Exibir publicidade nos posts?","type":"boolean","default":1,"required":false},"wordads_display_page":{"description":"Exibir an\u00fancios nas p\u00e1ginas?","type":"boolean","default":1,"required":false},"wordads_display_archive":{"description":"Exibir publicidade nas p\u00e1ginas de arquivos?","type":"boolean","default":1,"required":false},"wordads_custom_adstxt_enabled":{"description":"Personalizar ads.txt","type":"boolean","default":0,"required":false},"wordads_custom_adstxt":{"description":"Entradas de ads.txt personalizados","type":"string","default":"","required":false},"wordads_ccpa_enabled":{"description":"Ativar compatibilidade com a Lei de Privacidade do Consumidor da Calif\u00f3rnia","type":"boolean","default":0,"required":false},"wordads_ccpa_privacy_policy_url":{"description":"URL da pol\u00edtica de privacidade","type":"string","default":"","required":false},"wordads_cmp_enabled":{"description":"Ativar banner de gerenciamento de consentimento do GDPR para WordAds","type":"boolean","default":0,"required":false},"google_analytics_tracking_id":{"description":"Google Analytics","type":"string","default":"","required":false},"jetpack_wga":{"description":"Google Analytics","type":"object","required":false},"admin_bar":{"description":"Adicionar um pequeno gr\u00e1fico na barra administrativa com o tr\u00e1fego das \u00faltimas 48 horas.","type":"boolean","default":1,"required":false},"enable_odyssey_stats":{"description":"Confira a nova experi\u00eancia das Estat\u00edsticas do Jetpack (em teste).","type":"boolean","default":1,"required":false},"roles":{"description":"Selecione as fun\u00e7\u00f5es de usu\u00e1rios que ser\u00e3o capaz de visualizar relat\u00f3rios de estat\u00edsticas.","type":"array","items":{"type":"string"},"default":["administrator"],"required":false},"count_roles":{"description":"Contar visualiza\u00e7\u00f5es de p\u00e1ginas de usu\u00e1rios registrados que est\u00e3o autenticados.","type":"array","items":{"type":"string"},"default":["administrator"],"required":false},"blog_id":{"description":"ID do blog.","type":"boolean","default":0,"required":false},"do_not_track":{"description":"N\u00e3o rastrear.","type":"boolean","default":1,"required":false},"version":{"description":"Vers\u00e3o.","type":"integer","default":9,"required":false},"collapse_nudges":{"description":"Recolher sugest\u00f5es de upgrade","type":"boolean","default":0,"required":false},"wpcom_reader_views_enabled":{"description":"Mostre visualiza\u00e7\u00f5es de posts no Leitor do WordPress.com.","type":"boolean","default":1,"required":false},"akismet_show_user_comments_approved":{"description":"","type":"boolean","default":0,"required":false},"wordpress_api_key":{"description":"","type":"string","default":"","required":false},"dismiss_empty_stats_card":{"description":"","type":"boolean","default":0,"required":false},"dismiss_dash_backup_getting_started":{"description":"","type":"boolean","default":0,"required":false},"dismiss_dash_agencies_learn_more":{"description":"","type":"boolean","default":0,"required":false},"lang_id":{"description":"Idioma principal do site.","type":"string","default":"en_US","required":false},"advanced_seo_front_page_description":{"description":"Metadescri\u00e7\u00e3o da p\u00e1gina inicial.","type":"string","default":"","required":false},"advanced_seo_title_formats":{"description":"Estruturas de t\u00edtulo de p\u00e1gina de SEO.","type":"object","default":{"archives":[],"front_page":[],"groups":[],"pages":[],"posts":[]},"required":false},"videopress_private_enabled_for_site":{"description":"Privacidade do v\u00eddeo: restringir visualiza\u00e7\u00e3o aos membros deste site","type":"boolean","default":0,"required":false},"ai_seo_enhancer_enabled":{"description":"Gere automaticamente t\u00edtulo de SEO, descri\u00e7\u00e3o de SEO e texto alternativo de imagem para novos posts.","type":"boolean","default":0,"required":false},"account-protection":{"description":"","type":"boolean","default":0,"required":false},"blaze":{"description":"","type":"boolean","default":0,"required":false},"blocks":{"description":"","type":"boolean","default":0,"required":false},"canonical-urls":{"description":"","type":"boolean","default":0,"required":false},"carousel":{"description":"","type":"boolean","default":0,"required":false},"comment-likes":{"description":"","type":"boolean","default":0,"required":false},"comments":{"description":"","type":"boolean","default":0,"required":false},"contact-form":{"description":"","type":"boolean","default":0,"required":false},"copy-post":{"description":"","type":"boolean","default":0,"required":false},"custom-content-types":{"description":"","type":"boolean","default":0,"required":false},"google-fonts":{"description":"","type":"boolean","default":0,"required":false},"gravatar-hovercards":{"description":"","type":"boolean","default":0,"required":false},"infinite-scroll":{"description":"","type":"boolean","default":0,"required":false},"json-api":{"description":"","type":"boolean","default":0,"required":false},"latex":{"description":"","type":"boolean","default":0,"required":false},"likes":{"description":"","type":"boolean","default":0,"required":false},"markdown":{"description":"","type":"boolean","default":0,"required":false},"monitor":{"description":"","type":"boolean","default":0,"required":false},"notes":{"description":"","type":"boolean","default":0,"required":false},"photon-cdn":{"description":"","type":"boolean","default":0,"required":false},"photon":{"description":"","type":"boolean","default":0,"required":false},"post-by-email":{"description":"","type":"boolean","default":0,"required":false},"post-list":{"description":"","type":"boolean","default":0,"required":false},"protect":{"description":"","type":"boolean","default":0,"required":false},"publicize":{"description":"","type":"boolean","default":0,"required":false},"related-posts":{"description":"","type":"boolean","default":0,"required":false},"search":{"description":"","type":"boolean","default":0,"required":false},"seo-tools":{"description":"","type":"boolean","default":0,"required":false},"sharedaddy":{"description":"","type":"boolean","default":0,"required":false},"shortcodes":{"description":"","type":"boolean","default":0,"required":false},"shortlinks":{"description":"","type":"boolean","default":0,"required":false},"sitemaps":{"description":"","type":"boolean","default":0,"required":false},"sso":{"description":"","type":"boolean","default":0,"required":false},"stats":{"description":"","type":"boolean","default":0,"required":false},"subscriptions":{"description":"","type":"boolean","default":0,"required":false},"tiled-gallery":{"description":"","type":"boolean","default":0,"required":false},"vaultpress":{"description":"","type":"boolean","default":0,"required":false},"verification-tools":{"description":"","type":"boolean","default":0,"required":false},"videopress":{"description":"","type":"boolean","default":0,"required":false},"waf":{"description":"","type":"boolean","default":0,"required":false},"widget-visibility":{"description":"","type":"boolean","default":0,"required":false},"widgets":{"description":"","type":"boolean","default":0,"required":false},"woocommerce-analytics":{"description":"","type":"boolean","default":0,"required":false},"wordads":{"description":"","type":"boolean","default":0,"required":false},"wpcom-reader":{"description":"","type":"boolean","default":0,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/jetpack\/v4\/module\/(?P<slug>[a-z\\-]+)\/active":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"active":{"default":true,"type":"boolean","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/jetpack\/v4\/module\/(?P<slug>[a-z\\-]+)\/data":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"range":{"default":"day","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/jetpack\/v4\/module\/(?P<service>[a-z\\-]+)\/key\/check":{"namespace":"jetpack\/v4","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"api_key":{"default":"","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/jetpack\/v4\/settings":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH","GET"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"context":{"default":"edit","required":false},"jetpack_blocks_disabled":{"description":"Blocos do Jetpack desativados.","type":"boolean","default":false,"required":false},"carousel_background_color":{"description":"Esquema de cores.","type":"string","default":"black","enum":["black","white"],"required":false},"carousel_display_exif":{"description":"Mostrar metadados de foto (<a href=\"https:\/\/en.wikipedia.org\/wiki\/Exchangeable_image_file_format\" target=\"_blank\">Exif<\/a>) em carrossel, quando dispon\u00edvel.","type":"boolean","default":0,"required":false},"carousel_display_comments":{"description":"Mostrar \u00e1rea de coment\u00e1rios em carrossel","type":"boolean","default":1,"required":false},"highlander_comment_form_prompt":{"description":"Texto de Sauda\u00e7\u00e3o","type":"string","default":"Deixe uma resposta","required":false},"jetpack_comment_form_color_scheme":{"description":"Combina\u00e7\u00e3o de cores","type":"string","default":"light","enum":["light","dark","transparent"],"required":false},"jetpack_portfolio":{"description":"Ativar ou desativar tipo de post para portf\u00f3lio do Jetpack.","type":"boolean","default":0,"required":false},"jetpack_portfolio_posts_per_page":{"description":"N\u00famero m\u00e1ximo de entradas a exibir em p\u00e1ginas de Portf\u00f3lio.","type":"integer","default":10,"required":false},"jetpack_testimonial":{"description":"Ativar ou desativar tipo de post para depoimento do Jetpack.","type":"boolean","default":0,"required":false},"jetpack_testimonial_posts_per_page":{"description":"N\u00famero m\u00e1ximo de entradas a exibir nas p\u00e1ginas de Depoimentos.","type":"integer","default":10,"required":false},"jetpack_waf_automatic_rules":{"description":"Ative regras autom\u00e1ticas: proteja seu site contra fontes de tr\u00e1fego n\u00e3o confi\u00e1veis, com regras de seguran\u00e7a autom\u00e1ticas.","type":"boolean","default":false,"required":false},"jetpack_waf_ip_block_list_enabled":{"description":"Lista de bloqueios: bloqueie uma solicita\u00e7\u00e3o de IP espec\u00edfico.","type":"boolean","default":0,"required":false},"jetpack_waf_ip_block_list":{"description":"Endere\u00e7os IP bloqueados","type":"string","default":"","required":false},"jetpack_waf_ip_allow_list_enabled":{"description":"Lista de permiss\u00f5es: permita uma solicita\u00e7\u00e3o de IP espec\u00edfico.","type":"boolean","default":0,"required":false},"jetpack_waf_ip_allow_list":{"description":"Endere\u00e7os IP sempre permitidos","type":"string","default":"","required":false},"jetpack_waf_share_data":{"description":"Compartilhe dados b\u00e1sicos com o Jetpack.","type":"boolean","default":0,"required":false},"jetpack_waf_share_debug_data":{"description":"Compartilhe dados detalhados com o Jetpack.","type":"boolean","default":0,"required":false},"tiled_galleries":{"description":"Exibir todas as suas fotos de galeria em um mosaico maneiro.","type":"boolean","default":0,"required":false},"gravatar_disable_hovercards":{"description":"Veja os perfis das pessoas quando passa o mouse sobre seus Gravatar","type":"string","default":"enabled","enum":["enabled","disabled"],"required":false},"infinite_scroll":{"description":"Para o infinito e al\u00e9m","type":"boolean","default":1,"required":false},"infinite_scroll_google_analytics":{"description":"Use o Google Analytics com a Rolagem Infinita","type":"boolean","default":0,"required":false},"wpl_default":{"description":"Curtidas WordPress.com","type":"string","default":"on","enum":["on","off"],"required":false},"social_notifications_like":{"description":"Enviar notifica\u00e7\u00e3o por e-mail quando algu\u00e9m curtir um post","type":"boolean","default":1,"required":false},"wpcom_publish_comments_with_markdown":{"description":"Usar Markdown para coment\u00e1rios.","type":"boolean","default":0,"required":false},"wpcom_publish_posts_with_markdown":{"description":"Use Markdown para posts.","type":"boolean","default":0,"required":false},"monitor_receive_notifications":{"description":"Receba notifica\u00e7\u00f5es do Monitor por e-mail.","type":"boolean","default":0,"required":false},"post_by_email_address":{"description":"Endere\u00e7o de e-mail","type":"string","default":"noop","enum":["noop","create","regenerate","delete"],"required":false},"jetpack_protect_key":{"description":"Chave da API do Proteger","type":"string","default":"","required":false},"jetpack_protect_global_whitelist":{"description":"Proteger lista global de IPs permitidos","type":"string","default":"","required":false},"sharing_services":{"description":"Servi\u00e7os ativados e ocultos atr\u00e1s de um bot\u00e3o","type":"object","default":{"visible":["facebook","x"],"hidden":[]},"required":false},"button_style":{"description":"Estilo do bot\u00e3o","type":"string","default":"icon","enum":["icon-text","icon","text","official"],"required":false},"sharing_label":{"description":"R\u00f3tulo de compartilhamento","type":"string","default":"","required":false},"show":{"description":"Exibi\u00e7\u00f5es onde os bot\u00f5es s\u00e3o mostrados","type":"array","items":{"type":"string"},"default":["post"],"required":false},"jetpack-twitter-cards-site-tag":{"description":"O nome de usu\u00e1rio no Twitter do propriet\u00e1rio do dom\u00ednio deste site.","type":"string","default":"","required":false},"sharedaddy_disable_resources":{"description":"Desativar CSS e JS","type":"boolean","default":0,"required":false},"custom":{"description":"Servi\u00e7os de compartilhamento personalizados adicionados pelo usu\u00e1rio.","type":"object","default":{"sharing_name":"","sharing_url":"","sharing_icon":""},"required":false},"sharing_delete_service":{"description":"Excluir servi\u00e7o de compartilhamento personalizado.","type":"string","default":"","required":false},"jetpack_sso_require_two_step":{"description":"Exige Autentica\u00e7\u00e3o Dois Fatores ","type":"boolean","default":false,"required":false},"jetpack_sso_match_by_email":{"description":"Coincidir por e-mail","type":"boolean","default":1,"required":false},"stb_enabled":{"description":"Mostrar uma op\u00e7\u00e3o &lt;em&gt;&#039;seguir blog&#039;&lt;\/em&gt; no formul\u00e1rio de coment\u00e1rio","type":"boolean","default":1,"required":false},"stc_enabled":{"description":"Mostrar a op\u00e7\u00e3o &lt;em&gt;&#039;seguir coment\u00e1rios&#039;&lt;\/em&gt; no formul\u00e1rio de coment\u00e1rios","type":"boolean","default":1,"required":false},"wpcom_newsletter_categories":{"description":"Array de IDs de categoria de post marcadas como categorias de newsletter","type":"array","default":[],"required":false},"wpcom_newsletter_categories_enabled":{"description":"Se as categorias de newsletter est\u00e3o ativadas ou n\u00e3o","type":"boolean","default":0,"required":false},"wpcom_featured_image_in_email":{"description":"Se \u00e9 para incluir a imagem destacada no e-mail ou n\u00e3o","type":"boolean","default":0,"required":false},"jetpack_gravatar_in_email":{"description":"Escolha mostrar ou n\u00e3o o avatar do autor no in\u00edcio do seu e-mail","type":"boolean","default":1,"required":false},"jetpack_author_in_email":{"description":"Escolha mostrar ou n\u00e3o o nome de exibi\u00e7\u00e3o do autor no in\u00edcio do seu e-mail","type":"boolean","default":1,"required":false},"jetpack_post_date_in_email":{"description":"Escolha mostrar ou n\u00e3o a data no in\u00edcio do seu e-mail","type":"boolean","default":1,"required":false},"wpcom_subscription_emails_use_excerpt":{"description":"Se \u00e9 para usar o resumo no e-mail ou n\u00e3o","type":"boolean","default":0,"required":false},"jetpack_subscriptions_reply_to":{"description":"Comportamento do e-mail para respostas \u00e0s suas newsletters","type":"string","default":"comment","required":false},"jetpack_subscriptions_from_name":{"description":"Nome de remetente para e-mails de newsletters","type":"string","default":"","required":false},"sm_enabled":{"description":"Exiba um modal popup de assinatura para os leitores.","type":"boolean","default":0,"required":false},"jetpack_subscribe_overlay_enabled":{"description":"Exibir a sobreposi\u00e7\u00e3o de assinatura na p\u00e1gina inicial.","type":"boolean","default":0,"required":false},"jetpack_subscribe_floating_button_enabled":{"description":"Mostra um bot\u00e3o flutuante de assinatura.","type":"boolean","default":0,"required":false},"jetpack_subscriptions_subscribe_post_end_enabled":{"description":"Adicione um bloco de assinatura ao final de cada post.","type":"boolean","default":0,"required":false},"jetpack_subscriptions_login_navigation_enabled":{"description":"Adicione o bloco de login do assinante \u00e0 navega\u00e7\u00e3o.","type":"boolean","default":0,"required":false},"jetpack_subscriptions_subscribe_navigation_enabled":{"description":"Adicione o bloco Assinar \u00e0 navega\u00e7\u00e3o.","type":"boolean","default":0,"required":false},"social_notifications_subscribe":{"description":"Enviar notifica\u00e7\u00e3o por e-mail quando algu\u00e9m assinar meu blog","type":"boolean","default":0,"required":false},"subscription_options":{"description":"Tr\u00eas op\u00e7\u00f5es usadas nos modelos de e-mail por assinatura: &quot;invitation&quot;, &quot;welcome&quot; e &quot;comment_follow&quot;.","type":"object","default":{"invitation":"","welcome":"","comment_follow":""},"required":false},"show_headline":{"description":"Destaque o conte\u00fado relacionado com um cabe\u00e7alho","type":"boolean","default":1,"required":false},"show_thumbnails":{"description":"Exibir uma miniatura de imagem quando dispon\u00edvel","type":"boolean","default":0,"required":false},"instant_search_enabled":{"description":"Ative a busca instant\u00e2nea","type":"boolean","default":0,"required":false},"has_jetpack_search_product":{"description":"Tem uma compra de produto ativa do Jetpack Search","type":"boolean","default":0,"required":false},"search_auto_config":{"description":"Acione uma configura\u00e7\u00e3o autom\u00e1tica de busca instant\u00e2nea","type":"boolean","default":0,"required":false},"google":{"description":"Console de busca do Google","type":"string","default":"","required":false},"bing":{"description":"Centro do webmaster Bing","type":"string","default":"","required":false},"pinterest":{"description":"Verifica\u00e7\u00e3o do Site Pinterest","type":"string","default":"","required":false},"yandex":{"description":"Verifica\u00e7\u00e3o de site Yandex","type":"string","default":"","required":false},"facebook":{"description":"Verifica\u00e7\u00e3o de dom\u00ednio do Facebook","type":"string","default":"","required":false},"enable_header_ad":{"description":"Exiba um an\u00fancio na parte superior de cada p\u00e1gina.","type":"boolean","default":1,"required":false},"wordads_approved":{"description":"Este site est\u00e1 aprovado para WordAds?","type":"boolean","default":0,"required":false},"wordads_second_belowpost":{"description":"Exibir um segundo an\u00fancio abaixo do post?","type":"boolean","default":1,"required":false},"wordads_inline_enabled":{"description":"Exibir an\u00fancio integrado ao conte\u00fado do post?","type":"boolean","default":1,"required":false},"wordads_display_front_page":{"description":"Exibir an\u00fancios na p\u00e1gina inicial?","type":"boolean","default":1,"required":false},"wordads_display_post":{"description":"Exibir publicidade nos posts?","type":"boolean","default":1,"required":false},"wordads_display_page":{"description":"Exibir an\u00fancios nas p\u00e1ginas?","type":"boolean","default":1,"required":false},"wordads_display_archive":{"description":"Exibir publicidade nas p\u00e1ginas de arquivos?","type":"boolean","default":1,"required":false},"wordads_custom_adstxt_enabled":{"description":"Personalizar ads.txt","type":"boolean","default":0,"required":false},"wordads_custom_adstxt":{"description":"Entradas de ads.txt personalizados","type":"string","default":"","required":false},"wordads_ccpa_enabled":{"description":"Ativar compatibilidade com a Lei de Privacidade do Consumidor da Calif\u00f3rnia","type":"boolean","default":0,"required":false},"wordads_ccpa_privacy_policy_url":{"description":"URL da pol\u00edtica de privacidade","type":"string","default":"","required":false},"wordads_cmp_enabled":{"description":"Ativar banner de gerenciamento de consentimento do GDPR para WordAds","type":"boolean","default":0,"required":false},"google_analytics_tracking_id":{"description":"Google Analytics","type":"string","default":"","required":false},"jetpack_wga":{"description":"Google Analytics","type":"object","required":false},"admin_bar":{"description":"Adicionar um pequeno gr\u00e1fico na barra administrativa com o tr\u00e1fego das \u00faltimas 48 horas.","type":"boolean","default":1,"required":false},"enable_odyssey_stats":{"description":"Confira a nova experi\u00eancia das Estat\u00edsticas do Jetpack (em teste).","type":"boolean","default":1,"required":false},"roles":{"description":"Selecione as fun\u00e7\u00f5es de usu\u00e1rios que ser\u00e3o capaz de visualizar relat\u00f3rios de estat\u00edsticas.","type":"array","items":{"type":"string"},"default":["administrator"],"required":false},"count_roles":{"description":"Contar visualiza\u00e7\u00f5es de p\u00e1ginas de usu\u00e1rios registrados que est\u00e3o autenticados.","type":"array","items":{"type":"string"},"default":["administrator"],"required":false},"blog_id":{"description":"ID do blog.","type":"boolean","default":0,"required":false},"do_not_track":{"description":"N\u00e3o rastrear.","type":"boolean","default":1,"required":false},"version":{"description":"Vers\u00e3o.","type":"integer","default":9,"required":false},"collapse_nudges":{"description":"Recolher sugest\u00f5es de upgrade","type":"boolean","default":0,"required":false},"wpcom_reader_views_enabled":{"description":"Mostre visualiza\u00e7\u00f5es de posts no Leitor do WordPress.com.","type":"boolean","default":1,"required":false},"akismet_show_user_comments_approved":{"description":"","type":"boolean","default":0,"required":false},"wordpress_api_key":{"description":"","type":"string","default":"","required":false},"dismiss_empty_stats_card":{"description":"","type":"boolean","default":0,"required":false},"dismiss_dash_backup_getting_started":{"description":"","type":"boolean","default":0,"required":false},"dismiss_dash_agencies_learn_more":{"description":"","type":"boolean","default":0,"required":false},"lang_id":{"description":"Idioma principal do site.","type":"string","default":"en_US","required":false},"advanced_seo_front_page_description":{"description":"Metadescri\u00e7\u00e3o da p\u00e1gina inicial.","type":"string","default":"","required":false},"advanced_seo_title_formats":{"description":"Estruturas de t\u00edtulo de p\u00e1gina de SEO.","type":"object","default":{"archives":[],"front_page":[],"groups":[],"pages":[],"posts":[]},"required":false},"videopress_private_enabled_for_site":{"description":"Privacidade do v\u00eddeo: restringir visualiza\u00e7\u00e3o aos membros deste site","type":"boolean","default":0,"required":false},"ai_seo_enhancer_enabled":{"description":"Gere automaticamente t\u00edtulo de SEO, descri\u00e7\u00e3o de SEO e texto alternativo de imagem para novos posts.","type":"boolean","default":0,"required":false},"account-protection":{"description":"","type":"boolean","default":0,"required":false},"blaze":{"description":"","type":"boolean","default":0,"required":false},"blocks":{"description":"","type":"boolean","default":0,"required":false},"canonical-urls":{"description":"","type":"boolean","default":0,"required":false},"carousel":{"description":"","type":"boolean","default":0,"required":false},"comment-likes":{"description":"","type":"boolean","default":0,"required":false},"comments":{"description":"","type":"boolean","default":0,"required":false},"contact-form":{"description":"","type":"boolean","default":0,"required":false},"copy-post":{"description":"","type":"boolean","default":0,"required":false},"custom-content-types":{"description":"","type":"boolean","default":0,"required":false},"google-fonts":{"description":"","type":"boolean","default":0,"required":false},"gravatar-hovercards":{"description":"","type":"boolean","default":0,"required":false},"infinite-scroll":{"description":"","type":"boolean","default":0,"required":false},"json-api":{"description":"","type":"boolean","default":0,"required":false},"latex":{"description":"","type":"boolean","default":0,"required":false},"likes":{"description":"","type":"boolean","default":0,"required":false},"markdown":{"description":"","type":"boolean","default":0,"required":false},"monitor":{"description":"","type":"boolean","default":0,"required":false},"notes":{"description":"","type":"boolean","default":0,"required":false},"photon-cdn":{"description":"","type":"boolean","default":0,"required":false},"photon":{"description":"","type":"boolean","default":0,"required":false},"post-by-email":{"description":"","type":"boolean","default":0,"required":false},"post-list":{"description":"","type":"boolean","default":0,"required":false},"protect":{"description":"","type":"boolean","default":0,"required":false},"publicize":{"description":"","type":"boolean","default":0,"required":false},"related-posts":{"description":"","type":"boolean","default":0,"required":false},"search":{"description":"","type":"boolean","default":0,"required":false},"seo-tools":{"description":"","type":"boolean","default":0,"required":false},"sharedaddy":{"description":"","type":"boolean","default":0,"required":false},"shortcodes":{"description":"","type":"boolean","default":0,"required":false},"shortlinks":{"description":"","type":"boolean","default":0,"required":false},"sitemaps":{"description":"","type":"boolean","default":0,"required":false},"sso":{"description":"","type":"boolean","default":0,"required":false},"stats":{"description":"","type":"boolean","default":0,"required":false},"subscriptions":{"description":"","type":"boolean","default":0,"required":false},"tiled-gallery":{"description":"","type":"boolean","default":0,"required":false},"vaultpress":{"description":"","type":"boolean","default":0,"required":false},"verification-tools":{"description":"","type":"boolean","default":0,"required":false},"videopress":{"description":"","type":"boolean","default":0,"required":false},"waf":{"description":"","type":"boolean","default":0,"required":false},"widget-visibility":{"description":"","type":"boolean","default":0,"required":false},"widgets":{"description":"","type":"boolean","default":0,"required":false},"woocommerce-analytics":{"description":"","type":"boolean","default":0,"required":false},"wordads":{"description":"","type":"boolean","default":0,"required":false},"wpcom-reader":{"description":"","type":"boolean","default":0,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/settings"}]}},"\/jetpack\/v4\/settings\/(?P<slug>[a-z\\-]+)":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"context":{"default":"edit","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/jetpack\/v4\/options\/(?P<options>[a-z\\-]+)":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/jetpack\/v4\/updates\/plugins":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/updates\/plugins"}]}},"\/jetpack\/v4\/notice\/(?P<notice>[a-z\\-_]+)":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/jetpack\/v4\/plugins":{"namespace":"jetpack\/v4","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST"],"args":{"slug":{"type":"string","description":"Slug de diret\u00f3rio de plugin do WordPress.org.","pattern":"[\\w\\-]+","required":true},"status":{"description":"O status de ativa\u00e7\u00e3o do plugin.","type":"string","enum":["inactive","active"],"default":"inactive","required":false},"source":{"type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/plugins"}]}},"\/jetpack\/v4\/plugins\/(?P<plugin>[^.\\\/]+(?:\\\/[^.\\\/]+)?)":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"status":{"type":"string","required":true},"source":{"type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/jetpack\/v4\/plugin\/(?P<plugin>[a-z\\\/\\.\\-_]+)":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/jetpack\/v4\/widgets\/(?P<id>[0-9a-z\\-_]+)":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/jetpack\/v4\/verify-site\/(?P<service>[a-z\\-_]+)":{"namespace":"jetpack\/v4","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"keyring_id":{"type":"integer","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/jetpack\/v4\/verify-site\/(?P<service>[a-z\\-_]+)\/(?<keyring_id>[0-9]+)":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/jetpack\/v4\/recommendations\/data":{"namespace":"jetpack\/v4","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"data":{"type":"object","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/recommendations\/data"}]}},"\/jetpack\/v4\/recommendations\/step":{"namespace":"jetpack\/v4","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"step":{"type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/recommendations\/step"}]}},"\/jetpack\/v4\/recommendations\/product-suggestions":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/recommendations\/product-suggestions"}]}},"\/jetpack\/v4\/recommendations\/upsell":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/recommendations\/upsell"}]}},"\/jetpack\/v4\/recommendations\/conditional":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/recommendations\/conditional"}]}},"\/jetpack\/v4\/site\/discount":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/site\/discount"}]}},"\/jetpack\/v4\/jetpack_crm":{"namespace":"jetpack\/v4","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"extension":{"type":"text","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/jetpack_crm"}]}},"\/jetpack\/v4\/purchase-token":{"namespace":"jetpack\/v4","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/purchase-token"}]}},"\/jetpack\/v4\/seen-wc-connection-modal":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/seen-wc-connection-modal"}]}},"\/jetpack\/v4\/intro-offers":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/intro-offers"}]}},"\/jetpack\/v4\/subscribers\/auth":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"redirect_url":{"description":"A URL para qual voc\u00ea \u00e9 direcionado.","type":"string","format":"uri","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/subscribers\/auth"}]}},"\/jetpack\/v4\/features\/available":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/features\/available"}]}},"\/jetpack\/v4\/features\/enabled":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/features\/enabled"}]}},"\/jetpack\/v4\/licensing\/error":{"namespace":"jetpack\/v4","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"error":{"type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/licensing\/error"}]}},"\/jetpack\/v4\/licensing\/set-license":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"license":{"type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/licensing\/set-license"}]}},"\/jetpack\/v4\/licensing\/user\/licenses":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/licensing\/user\/licenses"}]}},"\/jetpack\/v4\/licensing\/user\/counts":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/licensing\/user\/counts"}]}},"\/jetpack\/v4\/licensing\/user\/activation-notice-dismiss":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"last_detached_count":{"type":"integer","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/licensing\/user\/activation-notice-dismiss"}]}},"\/jetpack\/v4\/licensing\/attach-licenses":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"licenses":{"type":"array","items":{"type":"string"},"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/licensing\/attach-licenses"}]}},"\/quiz-survey-master\/v1":{"namespace":"quiz-survey-master\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"quiz-survey-master\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/quiz-survey-master\/v1"}]}},"\/quiz-survey-master\/v1\/quiz\/hierarchical-category-list":{"namespace":"quiz-survey-master\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/quiz-survey-master\/v1\/quiz\/hierarchical-category-list"}]}},"\/quiz-survey-master\/v1\/quiz\/advance-ques-type-upgrade-popup":{"namespace":"quiz-survey-master\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/quiz-survey-master\/v1\/quiz\/advance-ques-type-upgrade-popup"}]}},"\/quiz-survey-master\/v1\/quiz\/structure":{"namespace":"quiz-survey-master\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/quiz-survey-master\/v1\/quiz\/structure"}]}},"\/quiz-survey-master\/v1\/quiz\/create_quiz":{"namespace":"quiz-survey-master\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/quiz-survey-master\/v1\/quiz\/create_quiz"}]}},"\/quiz-survey-master\/v1\/quiz\/save_quiz":{"namespace":"quiz-survey-master\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/quiz-survey-master\/v1\/quiz\/save_quiz"}]}},"\/quiz-survey-master\/v1\/questions":{"namespace":"quiz-survey-master\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/quiz-survey-master\/v1\/questions"}]}},"\/quiz-survey-master\/v1\/questions\/(?P<id>\\d+)":{"namespace":"quiz-survey-master\/v1","methods":["POST","PUT","PATCH","GET"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/quiz-survey-master\/v1\/quizzes\/(?P<id>\\d+)\/results":{"namespace":"quiz-survey-master\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/quiz-survey-master\/v1\/quizzes\/(?P<id>\\d+)\/emails":{"namespace":"quiz-survey-master\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/qsm":{"namespace":"qsm","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"qsm","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/qsm"}]}},"\/qsm\/list_quiz":{"namespace":"qsm","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/qsm\/list_quiz"}]}},"\/qsm\/list_results\/(?P<id>\\d+)":{"namespace":"qsm","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/quiz-survey-master\/v1\/bank_questions\/(?P<id>\\d+)":{"namespace":"quiz-survey-master\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/quiz-survey-master\/v1\/quizzes\/(?P<id>\\d+)\/categories":{"namespace":"quiz-survey-master\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/quiz-survey-master\/v2":{"namespace":"quiz-survey-master\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"quiz-survey-master\/v2","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/quiz-survey-master\/v2"}]}},"\/quiz-survey-master\/v2\/quizzlist":{"namespace":"quiz-survey-master\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/quiz-survey-master\/v2\/quizzlist"}]}},"\/qsm\/quiz(?:\/(?P<quiz_id>\\d+))?":{"namespace":"qsm","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/qsm\/quiz_result(?:\/(?P<result_id>\\d+))?":{"namespace":"qsm","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/qsm\/submitquiz":{"namespace":"qsm","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/qsm\/submitquiz"}]}},"\/qsm\/get_questions":{"namespace":"qsm","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/qsm\/get_questions"}]}},"\/templately\/v1":{"namespace":"templately\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"templately\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/templately\/v1"}]}},"\/templately\/v1\/conditions":{"namespace":"templately\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"template_id":{"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/templately\/v1\/conditions"}]}},"\/templately\/v1\/check-conditions":{"namespace":"templately\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"template_id":{"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/templately\/v1\/check-conditions"}]}},"\/templately\/v1\/save-conditions":{"namespace":"templately\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"template_id":{"required":true},"conditions":{"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/templately\/v1\/save-conditions"}]}},"\/templately\/v1\/autocomplete-condition":{"namespace":"templately\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"payload":{"required":true},"query":{"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/templately\/v1\/autocomplete-condition"}]}},"\/templately\/v1\/categories":{"namespace":"templately\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/templately\/v1\/categories"}]}},"\/templately\/v1\/templateTypes":{"namespace":"templately\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/templately\/v1\/templateTypes"}]}},"\/templately\/v1\/dependencies":{"namespace":"templately\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/templately\/v1\/dependencies"}]}},"\/templately\/v1\/dependencies\/plugins":{"namespace":"templately\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/templately\/v1\/dependencies\/plugins"}]}},"\/templately\/v1\/dependencies\/themes":{"namespace":"templately\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/templately\/v1\/dependencies\/themes"}]}},"\/templately\/v1\/dependencies\/check":{"namespace":"templately\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/templately\/v1\/dependencies\/check"}]}},"\/templately\/v1\/dependencies\/install":{"namespace":"templately\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/templately\/v1\/dependencies\/install"}]}},"\/templately\/v1\/tags":{"namespace":"templately\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/templately\/v1\/tags"}]}},"\/templately\/v1\/create-template":{"namespace":"templately\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"platform":{"required":true},"type":{"required":true},"title":{"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/templately\/v1\/create-template"}]}},"\/templately\/v1\/ai-content\/modify-content":{"namespace":"templately\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/templately\/v1\/ai-content\/modify-content"}]}},"\/templately\/v1\/ai-content\/ai-update":{"namespace":"templately\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/templately\/v1\/ai-content\/ai-update"}]}},"\/templately\/v1\/ai-content\/ai-update-preview":{"namespace":"templately\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/templately\/v1\/ai-content\/ai-update-preview"}]}},"\/templately\/v1\/ai-content\/generate-tagline":{"namespace":"templately\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/templately\/v1\/ai-content\/generate-tagline"}]}},"\/templately\/v1\/ai-content\/attachments":{"namespace":"templately\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"type":{"default":"pack","required":false},"id":{"required":false},"pack_id":{"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/templately\/v1\/ai-content\/attachments"}]}},"\/templately\/v1\/ai-content\/images":{"namespace":"templately\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"query":{"required":false},"orientation":{"default":"all","required":false},"size":{"default":"medium","required":false},"color":{"required":false},"page":{"default":1,"required":false},"per_page":{"default":20,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/templately\/v1\/ai-content\/images"}]}},"\/templately\/v1\/logo-generation\/generate":{"namespace":"templately\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/templately\/v1\/logo-generation\/generate"}]}},"\/templately\/v1\/logo-generation\/callback":{"namespace":"templately\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/templately\/v1\/logo-generation\/callback"}]}},"\/templately\/v1\/logo-generation\/data":{"namespace":"templately\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/templately\/v1\/logo-generation\/data"}]}},"\/templately\/v1\/logo-generation\/poll":{"namespace":"templately\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/templately\/v1\/logo-generation\/poll"}]}},"\/templately\/v1\/logo-generation\/available-credits":{"namespace":"templately\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/templately\/v1\/logo-generation\/available-credits"}]}},"\/templately\/v1\/items":{"namespace":"templately\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"type":{"default":"items","required":false},"platform":{"default":"elementor","required":false},"per_page":{"default":40,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/templately\/v1\/items"}]}},"\/templately\/v1\/items\/(?P<id>[0-9]+)":{"namespace":"templately\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"required":true},"type":{"default":"block","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/templately\/v1\/items\/(?P<slug>[a-zA-Z0-9-]+)":{"namespace":"templately\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"required":true},"type":{"default":"block","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/templately\/v1\/items\/search\/(?P<keyword>[a-zA-Z0-9-]+)":{"namespace":"templately\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"keyword":{"required":true},"platform":{"default":"elementor","required":false},"query_type":{"default":"block","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/templately\/v1\/items\/favourite":{"namespace":"templately\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/templately\/v1\/items\/favourite"}]}},"\/templately\/v1\/items\/rating":{"namespace":"templately\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/templately\/v1\/items\/rating"}]}},"\/templately\/v1\/items-count":{"namespace":"templately\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/templately\/v1\/items-count"}]}},"\/templately\/v1\/featured-items":{"namespace":"templately\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/templately\/v1\/featured-items"}]}},"\/templately\/v1\/trending-items":{"namespace":"templately\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/templately\/v1\/trending-items"}]}},"\/templately\/v1\/related-items":{"namespace":"templately\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/templately\/v1\/related-items"}]}},"\/templately\/v1\/saved-templates":{"namespace":"templately\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/templately\/v1\/saved-templates"}]}},"\/templately\/v1\/saved-templates\/delete":{"namespace":"templately\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/templately\/v1\/saved-templates\/delete"}]}},"\/templately\/v1\/login":{"namespace":"templately\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/templately\/v1\/login"}]}},"\/templately\/v1\/logout":{"namespace":"templately\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/templately\/v1\/logout"}]}},"\/templately\/v1\/is-signed":{"namespace":"templately\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/templately\/v1\/is-signed"}]}},"\/templately\/v1\/pricing":{"namespace":"templately\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/templately\/v1\/pricing"}]}},"\/templately\/v1\/google-auth-url":{"namespace":"templately\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/templately\/v1\/google-auth-url"}]}},"\/templately\/v1\/signup":{"namespace":"templately\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/templately\/v1\/signup"}]}},"\/templately\/v1\/insert":{"namespace":"templately\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/templately\/v1\/insert"}]}},"\/templately\/v1\/import":{"namespace":"templately\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/templately\/v1\/import"}]}},"\/templately\/v1\/import\/page":{"namespace":"templately\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/templately\/v1\/import\/page"}]}},"\/templately\/v1\/profile\/sync":{"namespace":"templately\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/templately\/v1\/profile\/sync"}]}},"\/templately\/v1\/profile\/verified":{"namespace":"templately\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/templately\/v1\/profile\/verified"}]}},"\/templately\/v1\/profile\/download-history":{"namespace":"templately\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/templately\/v1\/profile\/download-history"}]}},"\/templately\/v1\/profile\/my-favourites":{"namespace":"templately\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/templately\/v1\/profile\/my-favourites"}]}},"\/templately\/v1\/profile\/purchased-items":{"namespace":"templately\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/templately\/v1\/profile\/purchased-items"}]}},"\/templately\/v1\/clouds":{"namespace":"templately\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/templately\/v1\/clouds"}]}},"\/templately\/v1\/clouds\/usage":{"namespace":"templately\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/templately\/v1\/clouds\/usage"}]}},"\/templately\/v1\/clouds\/copy-move":{"namespace":"templately\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/templately\/v1\/clouds\/copy-move"}]}},"\/templately\/v1\/clouds\/upload":{"namespace":"templately\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/templately\/v1\/clouds\/upload"}]}},"\/templately\/v1\/clouds\/download\/(?P<id>[a-zA-Z0-9-]+)":{"namespace":"templately\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/templately\/v1\/clouds\/delete\/(?P<id>[a-zA-Z0-9-]+)":{"namespace":"templately\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/templately\/v1\/workspaces":{"namespace":"templately\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/templately\/v1\/workspaces"}]}},"\/templately\/v1\/workspaces\/(?P<slug>[a-zA-Z0-9-]+)":{"namespace":"templately\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/templately\/v1\/workspaces\/item\/(?P<id>[a-zA-Z0-9-]+)":{"namespace":"templately\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/templately\/v1\/workspaces\/item\/delete\/(?P<id>[a-zA-Z0-9-]+)":{"namespace":"templately\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/templately\/v1\/workspaces\/create":{"namespace":"templately\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/templately\/v1\/workspaces\/create"}]}},"\/templately\/v1\/workspaces\/delete\/(?P<id>[a-zA-Z0-9-]+)":{"namespace":"templately\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/templately\/v1\/workspaces\/item\/add":{"namespace":"templately\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/templately\/v1\/workspaces\/item\/add"}]}},"\/templately\/v1\/sites\/migrate":{"namespace":"templately\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/templately\/v1\/sites\/migrate"}]}},"\/templately\/v1\/settings\/update":{"namespace":"templately\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/templately\/v1\/settings\/update"}]}},"\/wordfence\/v1":{"namespace":"wordfence\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wordfence\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wordfence\/v1"}]}},"\/wordfence\/v1\/authenticate":{"namespace":"wordfence\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wordfence\/v1\/authenticate"}]}},"\/wordfence\/v1\/authenticate-premium":{"namespace":"wordfence\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wordfence\/v1\/authenticate-premium"}]}},"\/wordfence\/v1\/config":{"namespace":"wordfence\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wordfence\/v1\/config"}]}},"\/wordfence\/v1\/disconnect":{"namespace":"wordfence\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wordfence\/v1\/disconnect"}]}},"\/wordfence\/v1\/premium-connect":{"namespace":"wordfence\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wordfence\/v1\/premium-connect"}]}},"\/wordfence\/v1\/scan\/issues":{"namespace":"wordfence\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wordfence\/v1\/scan\/issues"}]}},"\/wordfence\/v1\/scan":{"namespace":"wordfence\/v1","methods":["POST","DELETE"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["DELETE"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wordfence\/v1\/scan"}]}},"\/wordfence\/v1\/scan\/issue":{"namespace":"wordfence\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wordfence\/v1\/scan\/issue"}]}},"\/wp-rollback\/v1":{"namespace":"wp-rollback\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-rollback\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wp-rollback\/v1"}]}},"\/wp-rollback\/v1\/fetch-info":{"namespace":"wp-rollback\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"type":{"type":"string","required":true},"slug":{"type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wp-rollback\/v1\/fetch-info"}]}},"\/elementor-one\/v1":{"namespace":"elementor-one\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"elementor-one\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/elementor-one\/v1"}]}},"\/elementor-one\/v1\/connect\/authorize":{"namespace":"elementor-one\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"clearSession":{"type":"boolean","default":false,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/elementor-one\/v1\/connect\/authorize"}]}},"\/elementor-one\/v1\/connect\/disconnect":{"namespace":"elementor-one\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/elementor-one\/v1\/connect\/disconnect"}]}},"\/elementor-one\/v1\/connect\/switch-domain":{"namespace":"elementor-one\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/elementor-one\/v1\/connect\/switch-domain"}]}},"\/elementor-one\/v1\/connect\/deactivate":{"namespace":"elementor-one\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/elementor-one\/v1\/connect\/deactivate"}]}},"\/elementor-one\/v1\/top-bar\/notifications":{"namespace":"elementor-one\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"app_name":{"type":"string","required":true},"app_version":{"type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/elementor-one\/v1\/top-bar\/notifications"}]}},"\/elementor-one\/v1\/top-bar\/feedback":{"namespace":"elementor-one\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"product":{"type":"string","required":true},"subject":{"type":"string","required":true},"title":{"type":"string","required":true},"description":{"type":"string","required":true},"countryCode":{"type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/elementor-one\/v1\/top-bar\/feedback"}]}},"\/elementor-one\/v1\/themes":{"namespace":"elementor-one\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"slug":{"type":"string","description":"WordPress.org theme directory slug.","pattern":"[\\w\\-]+","required":true},"status":{"description":"The theme activation status.","type":"string","enum":["inactive","active"],"default":"inactive","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/elementor-one\/v1\/themes"}]}},"\/elementor-one\/v1\/themes\/(?P<slug>[\\w\\-]+)\/activate":{"namespace":"elementor-one\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"slug":{"type":"string","description":"WordPress.org theme directory slug.","pattern":"[\\w\\-]+","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/elementor-one\/v1\/plugins":{"namespace":"elementor-one\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"search":{"description":"Limitar resultados para aqueles que combinam com um texto.","type":"string","required":false},"status":{"description":"Limita os resultados a plugins com o status especificado.","type":"array","items":{"type":"string","enum":["inactive","active"]},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST"],"args":{"slug":{"type":"string","description":"WordPress.org plugin directory slug.","enum":["angie","manage","elementor","elementor-pro","site-mailer","image-optimization","pojo-accessibility"],"required":true},"status":{"description":"The plugin activation status.","type":"string","enum":["inactive","active"],"default":"inactive","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/elementor-one\/v1\/plugins"}]}},"\/elementor-one\/v1\/plugins\/(?P<slug>[\\w\\-]+)\/activate":{"namespace":"elementor-one\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"slug":{"type":"string","description":"WordPress.org plugin directory slug.","enum":["angie","manage","elementor","elementor-pro","site-mailer","image-optimization","pojo-accessibility"],"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/elementor-one\/v1\/plugins\/(?P<slug>[\\w\\-]+)\/deactivate":{"namespace":"elementor-one\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"slug":{"type":"string","description":"WordPress.org plugin directory slug.","enum":["angie","manage","elementor","elementor-pro","site-mailer","image-optimization","pojo-accessibility"],"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/elementor-one\/v1\/plugins\/(?P<slug>[\\w\\-]+)\/upgrade":{"namespace":"elementor-one\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"slug":{"type":"string","description":"WordPress.org plugin directory slug.","enum":["angie","manage","elementor","elementor-pro","site-mailer","image-optimization","pojo-accessibility"],"required":true},"status":{"description":"The plugin activation status.","type":"string","enum":["active"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/elementor-one\/v1\/plugins\/(?P<slug>[\\w\\-]+)\/migration\/run":{"namespace":"elementor-one\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"slug":{"type":"string","description":"WordPress.org plugin directory slug.","enum":{"1":"manage","2":"elementor","3":"elementor-pro","4":"site-mailer","5":"image-optimization","6":"pojo-accessibility"},"required":true},"force":{"type":"boolean","default":true,"description":"Force migration even if the plugin is already connected.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/elementor-one\/v1\/plugins\/(?P<slug>[\\w\\-]+)\/migration\/rollback":{"namespace":"elementor-one\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"slug":{"type":"string","description":"WordPress.org plugin directory slug.","enum":{"1":"manage","2":"elementor","3":"elementor-pro","4":"site-mailer","5":"image-optimization","6":"pojo-accessibility"},"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/elementor-one\/v1\/settings":{"namespace":"elementor-one\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/elementor-one\/v1\/settings"}]}},"\/wpml\/tm\/v1":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wpml\/tm\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wpml\/tm\/v1"}]}},"\/wpml\/tm\/v1\/ate\/jobs\/store":{"namespace":"wpml\/tm\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_job_id":{"type":"string","required":true},"ate_job_data":{"type":"array","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wpml\/tm\/v1\/ate\/jobs\/store"}]}},"\/wpml\/tm\/v1\/xliff\/fetch\/(?P<jobId>\\d+)":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wpml\/tm\/v1\/ams\/register_manager":{"namespace":"wpml\/tm\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wpml\/tm\/v1\/ams\/register_manager"}]}},"\/wpml\/tm\/v1\/ams\/synchronize\/translators":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wpml\/tm\/v1\/ams\/synchronize\/translators"}]}},"\/wpml\/tm\/v1\/ams\/synchronize\/managers":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wpml\/tm\/v1\/ams\/synchronize\/managers"}]}},"\/wpml\/tm\/v1\/ams\/status":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wpml\/tm\/v1\/ams\/status"}]}},"\/wpml\/tm\/v1\/ams\/console":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wpml\/tm\/v1\/ams\/console"}]}},"\/wpml\/tm\/v1\/ams\/engines":{"namespace":"wpml\/tm\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wpml\/tm\/v1\/ams\/engines"}]}},"\/wpml\/tm\/v1\/ate\/jobs":{"namespace":"wpml\/tm\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wpml\/tm\/v1\/ate\/jobs"}]}},"\/wpml\/tm\/v1\/ate\/jobs\/(?P<ateJobId>\\d+)":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wpml\/tm\/v1\/jobs":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"local_job_ids":{"type":"string","required":false},"scope":{"type":"string","required":false},"id":{"type":"integer","required":false},"title":{"type":"string","required":false},"source_language":{"type":"string","required":false},"target_language":{"type":"string","required":false},"status":{"type":"string","required":false},"needs_update":{"type":"string","required":false},"limit":{"type":"integer","required":false},"offset":{"type":"integer","required":false},"sorting":{"required":false},"translated_by":{"type":"string","required":false},"sent_from":{"type":"string","required":false},"sent_to":{"type":"string","required":false},"deadline_from":{"type":"string","required":false},"deadline_to":{"type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wpml\/tm\/v1\/jobs"}]}},"\/wpml\/tm\/v1\/jobs\/assign":{"namespace":"wpml\/tm\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"jobId":{"required":true},"type":{"required":false},"translatorId":{"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wpml\/tm\/v1\/jobs\/assign"}]}},"\/wpml\/tm\/v1\/jobs\/cancel":{"namespace":"wpml\/tm\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wpml\/tm\/v1\/jobs\/cancel"}]}},"\/wpml\/tm\/v1\/tp\/xliff\/download\/(?P<job_id>\\d+)\/(?P<job_type>\\w+)":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"job_id":{"required":true},"job_type":{"required":true},"json":{"type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wpml\/tm\/v1\/tp\/apply-translations":{"namespace":"wpml\/tm\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wpml\/tm\/v1\/tp\/apply-translations"}]}},"\/wpml\/tm\/v1\/tp\/batches\/sync":{"namespace":"wpml\/tm\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"batchId":{"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wpml\/tm\/v1\/tp\/batches\/sync"}]}},"\/wpml\/tm\/v1\/tp\/batches\/status":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wpml\/tm\/v1\/tp\/batches\/status"}]}},"\/wpml\/tm\/v1\/ate\/jobs\/sync":{"namespace":"wpml\/tm\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"lockKey":{"type":"string","required":false},"ateToken":{"type":"string","required":false},"page":{"type":"int","required":false},"numberOfPages":{"type":"int","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wpml\/tm\/v1\/ate\/jobs\/sync"}]}},"\/wpml\/tm\/v1\/ate\/jobs\/download":{"namespace":"wpml\/tm\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wpml\/tm\/v1\/ate\/jobs\/download"}]}},"\/wpml\/tm\/v1\/ate\/jobs\/retry":{"namespace":"wpml\/tm\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wpml\/tm\/v1\/ate\/jobs\/retry"}]}},"\/wpml\/tm\/v1\/ate\/jobs\/receive\/(?P<wpmlJobId>\\d+)":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpmlJobId":{"type":"int","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wpml\/tm\/v1\/ate\/jobs\/(?P<ateJobId>\\d+)\/fix":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wpml\/ate\/v1":{"namespace":"wpml\/ate\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wpml\/ate\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wpml\/ate\/v1"}]}},"\/wpml\/ate\/v1\/ate\/proxy":{"namespace":"wpml\/ate\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET","POST","PUT","PATCH","DELETE"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wpml\/ate\/v1\/ate\/proxy"}]}},"\/wpml\/st\/v1":{"namespace":"wpml\/st\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wpml\/st\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wpml\/st\/v1"}]}},"\/wpml\/st\/v1\/import_mo_strings":{"namespace":"wpml\/st\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"plugins":{"type":"array","required":false},"themes":{"type":"array","required":false},"other":{"type":"array","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wpml\/st\/v1\/import_mo_strings"}]}},"\/wpml\/st\/v1\/pre_generate_mo_files":{"namespace":"wpml\/st\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wpml\/st\/v1\/pre_generate_mo_files"}]}},"\/wpml\/st\/v1\/settings":{"namespace":"wpml\/st\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"group":{"required":true},"key":{"required":true},"data":{"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wpml\/st\/v1\/settings"}]}},"\/jetpack\/v4\/verify_xmlrpc_error":{"namespace":"jetpack\/v4","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"nonce":{"type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/verify_xmlrpc_error"}]}},"\/jetpack\/v4\/heartbeat\/data":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"prefix":{"description":"Prefixo para inserir antes de identificadores de estat\u00edsticas.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/heartbeat\/data"}]}},"\/jetpack\/v4\/sync\/full-sync":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"modules":{"description":"M\u00f3dulos de dados que deveriam ser inclu\u00eddos na sincroniza\u00e7\u00e3o completa","type":"array","required":false},"users":{"description":"IDs de usu\u00e1rio a serem inclu\u00eddas na sincroniza\u00e7\u00e3o completa ou \"inicial\"","required":false},"posts":{"description":"IDs de post a serem inclu\u00eddas na sincroniza\u00e7\u00e3o completa","type":"array","required":false},"comments":{"description":"IDs de coment\u00e1rio a serem inclu\u00eddas na sincroniza\u00e7\u00e3o completa","type":"array","required":false},"context":{"description":"Contexto para sincroniza\u00e7\u00e3o completa","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/sync\/full-sync"}]}},"\/jetpack\/v4\/sync\/status":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"fields":{"description":"Lista de campos adicionais separados por v\u00edrgula que deveriam ser inclusos no status.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/sync\/status"}]}},"\/jetpack\/v4\/sync\/health":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"status":{"description":"Novo status de integridade de sincroniza\u00e7\u00e3o","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/sync\/health"}]}},"\/jetpack\/v4\/sync\/settings":{"namespace":"jetpack\/v4","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/sync\/settings"}]}},"\/jetpack\/v4\/sync\/object":{"namespace":"jetpack\/v4","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET","POST","PUT","PATCH","DELETE"],"args":{"module_name":{"description":"Nome do m\u00f3dulo de sincroniza\u00e7\u00e3o","type":"string","required":false},"object_type":{"description":"Tipo de objeto","type":"string","required":false},"object_ids":{"description":"Identificadores de objetos","type":"array","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/sync\/object"}]}},"\/jetpack\/v4\/sync\/now":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"queue":{"description":"Nome da fila de sincroniza\u00e7\u00e3o.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/sync\/now"}]}},"\/jetpack\/v4\/sync\/checkout":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/sync\/checkout"}]}},"\/jetpack\/v4\/sync\/close":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/sync\/close"}]}},"\/jetpack\/v4\/sync\/unlock":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"queue":{"description":"Nome da fila de sincroniza\u00e7\u00e3o.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/sync\/unlock"}]}},"\/jetpack\/v4\/sync\/object-id-range":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"sync_module":{"description":"Nome do m\u00f3dulo de sincroniza\u00e7\u00e3o.","type":"string","required":true},"batch_size":{"description":"Tamanho dos lotes","type":"int","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/sync\/object-id-range"}]}},"\/jetpack\/v4\/sync\/data-check":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"perform_text_conversion":{"description":"Se os campos de texto precisarem ser convertidos em latin1 no c\u00e1lculo da soma de verifica\u00e7\u00e3o.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/sync\/data-check"}]}},"\/jetpack\/v4\/sync\/data-histogram":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"columns":{"description":"Mapeamentos de colunas","type":"array","required":false},"object_type":{"description":"Tipo de objeto","type":"string","required":false},"buckets":{"description":"N\u00famero de buckets de histograma.","type":"int","required":false},"start_id":{"description":"Iniciar ID para o histograma","type":"int","required":false},"end_id":{"description":"Encerrar ID para o histograma","type":"int","required":false},"strip_non_ascii":{"description":"Remover caracteres n\u00e3o ASCII?","type":"boolean","required":false},"shared_salt":{"description":"Sal compartilhado a ser usado ao gerar a soma de verifica\u00e7\u00e3o","type":"string","required":false},"only_range_edges":{"description":"Apenas os limites do intervalo devem ser retornados","type":"boolean","required":false},"detailed_drilldown":{"description":"Voc\u00ea quer a soma de verifica\u00e7\u00e3o ou IDs de objeto?","type":"boolean","required":false},"perform_text_conversion":{"description":"Se os campos de texto precisarem ser convertidos em latin1 no c\u00e1lculo da soma de verifica\u00e7\u00e3o.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/sync\/data-histogram"}]}},"\/jetpack\/v4\/sync\/spawn-sync":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/sync\/spawn-sync"}]}},"\/jetpack\/v4\/sync\/locks":{"namespace":"jetpack\/v4","methods":["DELETE"],"endpoints":[{"methods":["DELETE"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/sync\/locks"}]}},"\/jetpack\/v4\/sync\/clear-queue":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/sync\/clear-queue"}]}},"\/jetpack\/v4\/jitm":{"namespace":"jetpack\/v4","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/jitm"}]}},"\/jetpack\/v4\/identity-crisis\/confirm-safe-mode":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/identity-crisis\/confirm-safe-mode"}]}},"\/jetpack\/v4\/identity-crisis\/migrate":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/identity-crisis\/migrate"}]}},"\/jetpack\/v4\/identity-crisis\/start-fresh":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"redirect_uri":{"description":"URI da p\u00e1gina de administra\u00e7\u00e3o para onde o usu\u00e1rio \u00e9 redirecionado ap\u00f3s um fluxo de conex\u00e3o","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/identity-crisis\/start-fresh"}]}},"\/jetpack\/v4\/identity-crisis\/idc-url-validation":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/identity-crisis\/idc-url-validation"}]}},"\/jetpack\/v4\/identity-crisis\/url-secret":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/identity-crisis\/url-secret"}]}},"\/jetpack\/v4\/identity-crisis\/compare-url-secret":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"secret":{"description":"O segredo da URL para comparar com o que j\u00e1 est\u00e1 armazenado no banco de dados.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/identity-crisis\/compare-url-secret"}]}},"\/jetpack\/v4\/search\/plan":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/search\/plan"}]}},"\/jetpack\/v4\/search\/settings":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH","GET"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/search\/settings"}]}},"\/jetpack\/v4\/search\/stats":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/search\/stats"}]}},"\/jetpack\/v4\/search\/pricing":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/search\/pricing"}]}},"\/jetpack\/v4\/search\/plan\/activate":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/search\/plan\/activate"}]}},"\/jetpack\/v4\/search\/plan\/deactivate":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/search\/plan\/deactivate"}]}},"\/jetpack\/v4\/search":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/search"}]}},"\/jetpack\/v4\/search\/local-stats":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/search\/local-stats"}]}},"\/jetpack\/v4\/waf":{"namespace":"jetpack\/v4","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/waf"}]}},"\/jetpack\/v4\/waf\/update-rules":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/waf\/update-rules"}]}},"\/wpcom\/v2":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wpcom\/v2","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wpcom\/v2"}]}},"\/wpcom\/v2\/videopress\/meta":{"namespace":"wpcom\/v2","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"O ID de post associado ao anexo.","type":"int","required":true},"title":{"description":"O t\u00edtulo do v\u00eddeo.","type":"string","required":false},"description":{"description":"A descri\u00e7\u00e3o do v\u00eddeo.","type":"string","required":false},"caption":{"description":"A legenda do v\u00eddeo.","type":"string","required":false},"rating":{"description":"A classifica\u00e7\u00e3o do conte\u00fado do v\u00eddeo. G (livre), PG-13 (acima de 13 anos) ou R-17 (acima de 17 anos)","type":"string","required":false},"display_embed":{"description":"Exiba o menu de compartilhamento no reprodutor.","type":"boolean","required":false},"allow_download":{"description":"Exibir op\u00e7\u00e3o de download e permitir que os visitantes fa\u00e7am download deste v\u00eddeo","type":"boolean","required":false},"privacy_setting":{"description":"Como decidir se o v\u00eddeo deve ser p\u00fablico ou privado","type":"int","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wpcom\/v2\/videopress\/meta"}]}},"\/wpcom\/v2\/videopress\/(?P<video_guid>\\w+)\/poster":{"namespace":"wpcom\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"at_time":{"description":"O tempo no v\u00eddeo para usar como quadro do poster.","type":"int","required":false},"is_millisec":{"description":"Se o tempo est\u00e1 em milissegundos ou segundos.","type":"boolean","required":false},"poster_attachment_id":{"description":"O ID do anexo da imagem do poster.","type":"int","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wpcom\/v2\/videopress\/(?P<video_guid>\\w+)\/check-ownership\/(?P<post_id>\\d+)":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wpcom\/v2\/videopress\/upload-jwt":{"namespace":"wpcom\/v2","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wpcom\/v2\/videopress\/upload-jwt"}]}},"\/wpcom\/v2\/videopress\/playback-jwt\/(?P<video_guid>\\w+)":{"namespace":"wpcom\/v2","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/jetpack\/v4\/stats\/blog":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/stats\/blog"}]}},"\/jetpack\/v4\/stats-app":{"namespace":"jetpack\/v4\/stats-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"jetpack\/v4\/stats-app","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/stats-app"}]}},"\/jetpack\/v4\/stats-app\/sites\/0\/stats\/(?P<resource>[\\-\\w]+)\/(?P<resource_id>[\\d]+)":{"namespace":"jetpack\/v4\/stats-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/jetpack\/v4\/stats-app\/sites\/0\/stats\/(?P<resource>[\\-\\w]+)":{"namespace":"jetpack\/v4\/stats-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/jetpack\/v4\/stats-app\/sites\/0\/posts\/(?P<resource_id>[\\d]+)":{"namespace":"jetpack\/v4\/stats-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/jetpack\/v4\/stats-app\/sites\/0\/posts\/(?P<resource_id>[\\d]+)\/likes":{"namespace":"jetpack\/v4\/stats-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/jetpack\/v4\/stats-app\/sites\/0\/stats":{"namespace":"jetpack\/v4\/stats-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/stats-app\/sites\/0\/stats"}]}},"\/jetpack\/v4\/stats-app\/sites\/0\/site-has-never-published-post":{"namespace":"jetpack\/v4\/stats-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/stats-app\/sites\/0\/site-has-never-published-post"}]}},"\/jetpack\/v4\/stats-app\/sites\/0\/posts":{"namespace":"jetpack\/v4\/stats-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/stats-app\/sites\/0\/posts"}]}},"\/jetpack\/v4\/stats-app\/sites\/0\/subscribers\/counts":{"namespace":"jetpack\/v4\/stats-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/stats-app\/sites\/0\/subscribers\/counts"}]}},"\/jetpack\/v4\/stats-app\/sites\/0\/jetpack-stats\/usage":{"namespace":"jetpack\/v4\/stats-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/stats-app\/sites\/0\/jetpack-stats\/usage"}]}},"\/jetpack\/v4\/stats-app\/sites\/0\/jetpack-stats\/user-feedback":{"namespace":"jetpack\/v4\/stats-app","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/stats-app\/sites\/0\/jetpack-stats\/user-feedback"}]}},"\/jetpack\/v4\/stats-app\/sites\/0\/wordads\/earnings":{"namespace":"jetpack\/v4\/stats-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/stats-app\/sites\/0\/wordads\/earnings"}]}},"\/jetpack\/v4\/stats-app\/sites\/0\/wordads\/stats":{"namespace":"jetpack\/v4\/stats-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/stats-app\/sites\/0\/wordads\/stats"}]}},"\/jetpack\/v4\/stats-app\/stats\/notices":{"namespace":"jetpack\/v4\/stats-app","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"id":{"type":"string","description":"ID of the notice","required":true},"status":{"type":"string","description":"Status of the notice","required":true},"postponed_for":{"type":"number","default":null,"description":"Postponed for (in seconds)","minimum":0,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/stats-app\/stats\/notices"}]}},"\/jetpack\/v4\/stats-app\/sites\/0\/jetpack-stats-dashboard\/notices":{"namespace":"jetpack\/v4\/stats-app","methods":["POST","PUT","PATCH","GET"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"id":{"type":"string","description":"ID of the notice","required":true},"status":{"type":"string","description":"Status of the notice","required":true},"postponed_for":{"type":"number","default":null,"description":"Postponed for (in seconds)","minimum":0,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/stats-app\/sites\/0\/jetpack-stats-dashboard\/notices"}]}},"\/jetpack\/v4\/stats-app\/sites\/0\/stats\/referrers\/spam\/new":{"namespace":"jetpack\/v4\/stats-app","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"domain":{"type":"string","description":"Domain of the referrer","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/stats-app\/sites\/0\/stats\/referrers\/spam\/new"}]}},"\/jetpack\/v4\/stats-app\/sites\/0\/stats\/referrers\/spam\/delete":{"namespace":"jetpack\/v4\/stats-app","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"domain":{"type":"string","description":"Domain of the referrer","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/stats-app\/sites\/0\/stats\/referrers\/spam\/delete"}]}},"\/jetpack\/v4\/stats-app\/sites\/0\/jetpack-stats-dashboard\/modules":{"namespace":"jetpack\/v4\/stats-app","methods":["POST","PUT","PATCH","GET"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/stats-app\/sites\/0\/jetpack-stats-dashboard\/modules"}]}},"\/jetpack\/v4\/stats-app\/sites\/0\/jetpack-stats-dashboard\/module-settings":{"namespace":"jetpack\/v4\/stats-app","methods":["POST","PUT","PATCH","GET"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/stats-app\/sites\/0\/jetpack-stats-dashboard\/module-settings"}]}},"\/jetpack\/v4\/stats-app\/sites\/0\/stats\/emails\/(?P<resource>[\\-\\w\\d]+)":{"namespace":"jetpack\/v4\/stats-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/jetpack\/v4\/stats-app\/sites\/0\/stats\/opens\/emails\/(?P<post_id>[\\d]+)\/(?P<resource>[\\-\\w]+)":{"namespace":"jetpack\/v4\/stats-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/jetpack\/v4\/stats-app\/sites\/0\/stats\/clicks\/emails\/(?P<post_id>[\\d]+)\/(?P<resource>[\\-\\w]+)":{"namespace":"jetpack\/v4\/stats-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/jetpack\/v4\/stats-app\/sites\/0\/stats\/(?P<resource>[\\-\\w]+)\/emails\/(?P<post_id>[\\d]+)":{"namespace":"jetpack\/v4\/stats-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/jetpack\/v4\/stats-app\/sites\/0\/stats\/utm\/(?P<utm_params>[_,\\-\\w]+)":{"namespace":"jetpack\/v4\/stats-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/jetpack\/v4\/stats-app\/sites\/0\/stats\/devices\/(?P<device_property>[\\w]+)":{"namespace":"jetpack\/v4\/stats-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/jetpack\/v4\/stats-app\/sites\/0\/commercial-classification":{"namespace":"jetpack\/v4\/stats-app","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/stats-app\/sites\/0\/commercial-classification"}]}},"\/jetpack\/v4\/stats-app\/sites\/0\/purchases":{"namespace":"jetpack\/v4\/stats-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/stats-app\/sites\/0\/purchases"}]}},"\/jetpack\/v4\/stats-app\/sites\/0\/stats\/location-views\/(?P<geo_mode>country|region|city)":{"namespace":"jetpack\/v4\/stats-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/elementor\/v1":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"elementor\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/elementor\/v1"}]}},"\/elementor\/v1\/site-editor":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/elementor\/v1\/site-editor"}]}},"\/elementor\/v1\/site-editor\/templates":{"namespace":"elementor\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/elementor\/v1\/site-editor\/templates"}]}},"\/elementor\/v1\/site-editor\/templates\/(?P<id>[\\w]+)":{"namespace":"elementor\/v1","methods":["DELETE","POST","PUT","PATCH"],"endpoints":[{"methods":["DELETE"],"args":{"id":{"description":"Unique identifier for the object.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Unique identifier for the object.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/elementor\/v1\/site-editor\/conditions-config":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/elementor\/v1\/site-editor\/conditions-config"}]}},"\/elementor\/v1\/site-editor\/templates-conditions\/(?P<id>[\\w]+)":{"namespace":"elementor\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the object.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Unique identifier for the object.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/elementor\/v1\/site-editor\/templates-conditions-conflicts":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/elementor\/v1\/site-editor\/templates-conditions-conflicts"}]}},"\/elementor-pro\/v1":{"namespace":"elementor-pro\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"elementor-pro\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/elementor-pro\/v1"}]}},"\/elementor-pro\/v1\/license\/tier-features":{"namespace":"elementor-pro\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/elementor-pro\/v1\/license\/tier-features"}]}},"\/elementor-pro\/v1\/license\/get-license-status":{"namespace":"elementor-pro\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/elementor-pro\/v1\/license\/get-license-status"}]}},"\/wpcom\/v2\/business-hours\/localized-week":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wpcom\/v2\/business-hours\/localized-week"}]}},"\/wpcom\/v2\/admin-color":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wpcom\/v2\/admin-color"}]}},"\/wpcom\/v2\/admin-menu":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wpcom\/v2\/admin-menu"}]}},"\/wpcom\/v2\/jetpack-ai\/ai-assistant-feature":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wpcom\/v2\/jetpack-ai\/ai-assistant-feature"}]}},"\/wpcom\/v2\/app-media":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"number":{"description":"N\u00famero de itens de m\u00eddia na solicita\u00e7\u00e3o","type":"number","default":20,"required":false},"page_handle":{"type":"number","default":1,"required":false},"after":{"description":"Data\/hora desde o upload da m\u00eddia","type":"number","default":0,"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wpcom\/v2\/app-media"}]}},"\/wpcom\/v2\/editor-assets":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"exclude":{"description":"Lista separada por v\u00edrgulas de tipos de ativos a serem exclu\u00eddos da resposta. Valores compat\u00edveis: \"core\" (ativos principais do WordPress), \"gutenberg\" (ativos de plugin do Gutenberg) e prefixos de identificadores de plugins (por exemplo, \"contact-form-7\").","type":"string","default":"","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wpcom\/v2\/editor-assets"}]}},"\/wpcom\/v2\/blog-stats":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"post_id":{"description":"ID do post para a qual obter estat\u00edsticas.","type":["string","integer"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wpcom\/v2\/blog-stats"}]}},"\/wpcom\/v2\/email-preview":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identificador \u00fanico para a publica\u00e7\u00e3o.","type":"integer","required":false},"access":{"description":"N\u00edvel de acesso.","enum":["everybody","subscribers","paid_subscribers"],"default":"everybody","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wpcom\/v2\/email-preview"}]}},"\/wpcom\/v2\/external-media\/list\/(?P<service>google_photos|openverse|pexels)":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"search":{"description":"Termo de busca da cole\u00e7\u00e3o de m\u00eddia.","type":"string","required":false},"number":{"description":"N\u00famero de itens de m\u00eddia na solicita\u00e7\u00e3o","type":"number","default":20,"required":false},"path":{"type":"string","required":false},"page_handle":{"type":"string","required":false},"session_id":{"description":"ID de sess\u00e3o de um servi\u00e7o, no momento somente no seletor do Google Fotos","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wpcom\/v2\/external-media\/copy\/(?P<service>google_photos|openverse|pexels)":{"namespace":"wpcom\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"media":{"description":"Dados de m\u00eddia a serem copiados.","items":{"type":"array","items":{"type":"object","required":true,"properties":{"caption":{"type":"string"},"guid":{"type":"object","properties":{"caption":{"type":"string"},"name":{"type":"string"},"title":{"type":"string"},"url":{"format":"uri","type":"string"}}},"title":{"type":"string"},"meta":{"type":"object","additionalProperties":false,"properties":{"vertical_id":{"type":"string","format":"text-field"},"pexels_object":{"type":"object"}}}}}},"type":"array","required":true},"post_id":{"description":"ID do post para anexar o arquivo.","type":"number","minimum":0,"required":false},"should_proxy":{"description":"Indica se deve ser usado proxy na solicita\u00e7\u00e3o de m\u00eddia.","type":"boolean","default":false,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wpcom\/v2\/external-media\/connection\/(?P<service>google_photos)":{"namespace":"wpcom\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["DELETE"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wpcom\/v2\/external-media\/connection\/(?P<service>google_photos)\/picker_status":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wpcom\/v2\/external-media\/session\/(?P<service>google_photos)":{"namespace":"wpcom\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wpcom\/v2\/external-media\/session\/(?P<service>google_photos)\/(?P<session_id>.*)":{"namespace":"wpcom\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["DELETE"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wpcom\/v2\/external-media\/proxy\/(?P<service>google_photos)":{"namespace":"wpcom\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"url":{"type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wpcom\/v2\/following\/mine":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"ignore_user_blogs":{"type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wpcom\/v2\/following\/mine"}]}},"\/wpcom\/v2\/following\/recommendations":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"number":{"type":"number","default":5,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wpcom\/v2\/following\/recommendations"}]}},"\/wpcom\/v2\/goodreads\/user-id":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"ID de usu\u00e1rio do Goodreads","type":"integer","minimum":1,"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wpcom\/v2\/goodreads\/user-id"}]}},"\/wpcom\/v2\/checkGoogleDocVisibility":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wpcom\/v2\/checkGoogleDocVisibility"}]}},"\/wpcom\/v2\/instagram-gallery\/connect-url":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wpcom\/v2\/instagram-gallery\/connect-url"}]}},"\/wpcom\/v2\/instagram-gallery\/connections":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wpcom\/v2\/instagram-gallery\/connections"}]}},"\/wpcom\/v2\/instagram-gallery\/gallery":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"access_token":{"description":"Um token de acesso do chaveiro do Instagram.","type":"integer","minimum":1,"required":true},"count":{"description":"Quantos posts no Instagram?","type":"integer","minimum":1,"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wpcom\/v2\/instagram-gallery\/gallery"}]}},"\/wpcom\/v2\/mailchimp":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wpcom\/v2\/mailchimp"}]}},"\/wpcom\/v2\/mailchimp\/groups":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wpcom\/v2\/mailchimp\/groups"}]}},"\/wpcom\/v2\/mailchimp\/settings":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wpcom\/v2\/mailchimp\/settings"}]}},"\/wpcom\/v2\/newsletter-categories":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wpcom\/v2\/newsletter-categories"}]}},"\/wpcom\/v2\/newsletter-categories\/count":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"term_ids":{"default":"","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wpcom\/v2\/newsletter-categories\/count"}]}},"\/wpcom\/v2\/podcast-player":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"A URL do feed de RSS do podcast.","type":"string","required":true},"guids":{"description":"Uma lista de identificadores \u00fanicos para buscar epis\u00f3dios de podcast espec\u00edficos.","type":"array","required":true},"episode-options":{"description":"Se devemos retornar a lista de epis\u00f3dios para uso na IU de sele\u00e7\u00e3o","type":"boolean","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wpcom\/v2\/podcast-player"}]}},"\/wpcom\/v2\/podcast-player\/track-quantity":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wpcom\/v2\/podcast-player\/track-quantity"}]}},"\/wpcom\/v2\/profile":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wpcom\/v2\/profile"}]}},"\/wpcom\/v2\/related-posts":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wpcom\/v2\/related-posts"}]}},"\/wpcom\/v2\/related-posts\/enable":{"namespace":"wpcom\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wpcom\/v2\/related-posts\/enable"}]}},"\/wpcom\/v2\/related-posts\/(?P<id>[\\d]+)":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identificador \u00fanico para a publica\u00e7\u00e3o.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wpcom\/v2\/resolve-redirect\/?(?P<url>.+)?":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"O URL para verificar se h\u00e1 redirecionamentos.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wpcom\/v2\/search":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wpcom\/v2\/search"}]}},"\/wpcom\/v2\/send-email-preview":{"namespace":"wpcom\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Identificador \u00fanico para a publica\u00e7\u00e3o.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wpcom\/v2\/send-email-preview"}]}},"\/wpcom\/v2\/template-loader\/(?P<template_type>\\w+)":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"template_type":{"description":"O tipo de modelo.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wpcom\/v2\/post-types":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wpcom\/v2\/post-types"}]}},"\/wpcom\/v2\/top-posts":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"period":{"description":"Prazo para estat\u00edsticas.","type":["string","integer"],"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wpcom\/v2\/top-posts"}]}},"\/wpcom\/v2\/transients\/(?P<name>\\w{1,172})":{"namespace":"wpcom\/v2","methods":["DELETE"],"endpoints":[{"methods":["DELETE"],"args":{"name":{"description":"O nome do transiente a excluir.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wpcom\/v3":{"namespace":"wpcom\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wpcom\/v3","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wpcom\/v3"}]}},"\/wpcom\/v3\/blogging-prompts":{"namespace":"wpcom\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"after":{"description":"Mostrar sugest\u00f5es ap\u00f3s uma determinada data.","type":"string","required":false},"before":{"description":"Mostrar sugest\u00f5es antes de uma determinada data.","type":"string","required":false},"force_year":{"description":"Force as sugest\u00f5es a se referirem a um ano espec\u00edfico. Retorna uma \u00fanica sugest\u00e3o por dia.","type":"integer","required":false},"exclude":{"description":"Garantir que o resultado exclua IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar resultados para IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"order":{"description":"Ordenar atributos de forma ascendente ou descendente.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar cole\u00e7\u00e3o pelo atributo do post.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search":{"description":"Limitar resultados para aqueles que combinam com um texto.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wpcom\/v3\/blogging-prompts"}]}},"\/wpcom\/v3\/blogging-prompts\/(?P<id>[\\d]+)":{"namespace":"wpcom\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identificador \u00fanico para a sugest\u00e3o.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wpcom\/v3\/jitm":{"namespace":"wpcom\/v3","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"message_path":{"type":"string","description":"O caminho da mensagem para o qual buscar JITMs","required":true},"query":{"type":"string","description":"Par\u00e2metros de consulta adicionais","required":false},"full_jp_logo_exists":{"type":"boolean","description":"Se o logotipo completo do Jetpack existe","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST"],"args":{"id":{"type":"string","description":"A ID da JITM a ser descartada","required":true},"feature_class":{"type":"string","description":"A classe de funcionalidade da JITM","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wpcom\/v3\/jitm"}]}},"\/wpcom\/v2\/gutenberg\/available-extensions":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wpcom\/v2\/gutenberg\/available-extensions"}]}},"\/wpcom\/v2\/hello":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wpcom\/v2\/hello"}]}},"\/wpcom\/v2\/publicize\/connection-test-results":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wpcom\/v2\/publicize\/connection-test-results"}]}},"\/wpcom\/v2\/service-api-keys\/(?P<service>[a-z\\-_]+)":{"namespace":"wpcom\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"service_api_key":{"type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["DELETE"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/post-views-counter":{"namespace":"post-views-counter","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"post-views-counter","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/post-views-counter"}]}},"\/post-views-counter\/update-post-views":{"namespace":"post-views-counter","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/post-views-counter\/update-post-views"}]}},"\/wp-smush\/v1":{"namespace":"wp-smush\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-smush\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wp-smush\/v1"}]}},"\/wp-smush\/v1\/preset_configs":{"namespace":"wp-smush\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wp-smush\/v1\/preset_configs"}]}},"\/hub-connector\/v1":{"namespace":"hub-connector\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"hub-connector\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/hub-connector\/v1"}]}},"\/hub-connector\/v1\/sync":{"namespace":"hub-connector\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"force":{"description":"Should do a force sync.","type":"boolean","default":false,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/hub-connector\/v1\/sync"}]}},"\/hub-connector\/v1\/logout":{"namespace":"hub-connector\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/hub-connector\/v1\/logout"}]}},"\/jetpack-boost\/v1":{"namespace":"jetpack-boost\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"jetpack-boost\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack-boost\/v1"}]}},"\/jetpack-boost\/v1\/speed-scores":{"namespace":"jetpack-boost\/v1","methods":["POST","PUT","PATCH","POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack-boost\/v1\/speed-scores"}]}},"\/jetpack-boost\/v1\/speed-scores\/refresh":{"namespace":"jetpack-boost\/v1","methods":["POST","PUT","PATCH","POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack-boost\/v1\/speed-scores\/refresh"}]}},"\/jetpack-boost\/v1\/speed-scores-history":{"namespace":"jetpack-boost\/v1","methods":["POST","PUT","PATCH","POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"start":{"type":"number","required":true},"end":{"type":"number","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"start":{"type":"number","required":true},"end":{"type":"number","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack-boost\/v1\/speed-scores-history"}]}},"\/my-jetpack\/v1":{"namespace":"my-jetpack\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"my-jetpack\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/my-jetpack\/v1"}]}},"\/my-jetpack\/v1\/site\/products":{"namespace":"my-jetpack\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"products":{"description":"Comma-separated list of product slugs that should be retrieved.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/my-jetpack\/v1\/site\/products"}]}},"\/my-jetpack\/v1\/site\/products\/install":{"namespace":"my-jetpack\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"products":{"description":"Array de slugs de produtos","type":"array","items":{"enum":["anti-spam","backup","boost","crm","creator","extras","jetpack-ai","ai","scan","search","social","security","protect","videopress","stats","growth","complete","newsletter","site-accelerator","related-posts"],"type":"string"},"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/my-jetpack\/v1\/site\/products\/install"}]}},"\/my-jetpack\/v1\/site\/products\/activate":{"namespace":"my-jetpack\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"products":{"description":"Array de slugs de produtos","type":"array","items":{"enum":["anti-spam","backup","boost","crm","creator","extras","jetpack-ai","ai","scan","search","social","security","protect","videopress","stats","growth","complete","newsletter","site-accelerator","related-posts"],"type":"string"},"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/my-jetpack\/v1\/site\/products\/activate"}]}},"\/my-jetpack\/v1\/site\/products\/interstitials":{"namespace":"my-jetpack\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"products":{"description":"Pares de chave-valor de slugs do produto e estados das intersticiais.","type":"object","properties":{"anti-spam":{"type":"boolean"},"backup":{"type":"boolean"},"boost":{"type":"boolean"},"crm":{"type":"boolean"},"creator":{"type":"boolean"},"extras":{"type":"boolean"},"jetpack-ai":{"type":"boolean"},"ai":{"type":"boolean"},"scan":{"type":"boolean"},"search":{"type":"boolean"},"social":{"type":"boolean"},"security":{"type":"boolean"},"protect":{"type":"boolean"},"videopress":{"type":"boolean"},"stats":{"type":"boolean"},"growth":{"type":"boolean"},"complete":{"type":"boolean"},"newsletter":{"type":"boolean"},"site-accelerator":{"type":"boolean"},"related-posts":{"type":"boolean"}},"additionalProperties":false,"minProperties":1,"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/my-jetpack\/v1\/site\/products\/interstitials"}]}},"\/my-jetpack\/v1\/site\/products\/deactivate":{"namespace":"my-jetpack\/v1","methods":["DELETE"],"endpoints":[{"methods":["DELETE"],"args":{"products":{"description":"Array de slugs de produtos","type":"array","items":{"enum":["anti-spam","backup","boost","crm","creator","extras","jetpack-ai","ai","scan","search","social","security","protect","videopress","stats","growth","complete","newsletter","site-accelerator","related-posts"],"type":"string"},"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/my-jetpack\/v1\/site\/products\/deactivate"}]}},"\/my-jetpack\/v1\/site\/products-ownership":{"namespace":"my-jetpack\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/my-jetpack\/v1\/site\/products-ownership"}]}},"\/my-jetpack\/v1\/site\/purchases":{"namespace":"my-jetpack\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/my-jetpack\/v1\/site\/purchases"}]}},"\/my-jetpack\/v1\/chat\/availability":{"namespace":"my-jetpack\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/my-jetpack\/v1\/chat\/availability"}]}},"\/my-jetpack\/v1\/chat\/authentication":{"namespace":"my-jetpack\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"type":{"type":"string","required":false},"test_mode":{"type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/my-jetpack\/v1\/chat\/authentication"}]}},"\/my-jetpack\/v1\/site\/recommendations\/evaluation":{"namespace":"my-jetpack\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/my-jetpack\/v1\/site\/recommendations\/evaluation"}]}},"\/my-jetpack\/v1\/site\/recommendations\/evaluation\/result":{"namespace":"my-jetpack\/v1","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["DELETE"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/my-jetpack\/v1\/site\/recommendations\/evaluation\/result"}]}},"\/my-jetpack\/v1\/site\/backup\/undo-event":{"namespace":"my-jetpack\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/my-jetpack\/v1\/site\/backup\/undo-event"}]}},"\/my-jetpack\/v1\/site\/protect\/data":{"namespace":"my-jetpack\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/my-jetpack\/v1\/site\/protect\/data"}]}},"\/my-jetpack\/v1\/site\/videopress\/data":{"namespace":"my-jetpack\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/my-jetpack\/v1\/site\/videopress\/data"}]}},"\/my-jetpack\/v1\/site\/update-historically-active-modules":{"namespace":"my-jetpack\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/my-jetpack\/v1\/site\/update-historically-active-modules"}]}},"\/my-jetpack\/v1\/jetpack-manage\/data":{"namespace":"my-jetpack\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/my-jetpack\/v1\/jetpack-manage\/data"}]}},"\/my-jetpack\/v1\/red-bubble-notifications":{"namespace":"my-jetpack\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"dismissal_cookies":{"type":"array","description":"Array of dismissal cookies to set for the red bubble notifications.","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/my-jetpack\/v1\/red-bubble-notifications"}]}},"\/my-jetpack\/v1\/site":{"namespace":"my-jetpack\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/my-jetpack\/v1\/site"}]}},"\/my-jetpack\/v1\/site\/dismiss-welcome-banner":{"namespace":"my-jetpack\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/my-jetpack\/v1\/site\/dismiss-welcome-banner"}]}},"\/jetpack\/v4\/explat":{"namespace":"jetpack\/v4\/explat","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"jetpack\/v4\/explat","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/explat"}]}},"\/jetpack\/v4\/explat\/assignments":{"namespace":"jetpack\/v4\/explat","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"experiment_name":{"type":"string","required":false},"anon_id":{"type":"string","required":false},"as_connected_user":{"type":"boolean","required":false},"platform":{"type":"string","enum":["jetpack","calypso","wpcom"],"default":"jetpack","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/explat\/assignments"}]}},"\/elementskit\/v1\/ajaxselect2":{"namespace":"elementskit\/v1\/ajaxselect2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"elementskit\/v1\/ajaxselect2","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/elementskit\/v1\/ajaxselect2"}]}},"\/elementskit\/v1\/ajaxselect2\/(?P<action>\\w+)":{"namespace":"elementskit\/v1\/ajaxselect2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET","POST","PUT","PATCH","DELETE"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/elementor\/v1\/documents":{"namespace":"elementor\/v1\/documents","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"elementor\/v1\/documents","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/elementor\/v1\/documents"}]}},"\/elementor\/v1\/documents\/(?P<id>\\d+)\/media\/import":{"namespace":"elementor\/v1\/documents","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/elementor\/v1\/cache":{"namespace":"elementor\/v1","methods":["DELETE"],"endpoints":[{"methods":["DELETE"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/elementor\/v1\/cache"}]}},"\/elementor\/v1\/globals":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/elementor\/v1\/globals"}]}},"\/elementor\/v1\/globals\/colors":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/elementor\/v1\/globals\/colors"}]}},"\/elementor\/v1\/globals\/colors\/(?P<id>[\\w]+)":{"namespace":"elementor\/v1","methods":["GET","POST","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the object.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST"],"args":{"id":{"description":"Unique identifier for the object.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Unique identifier for the object.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/elementor\/v1\/globals\/typography":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/elementor\/v1\/globals\/typography"}]}},"\/elementor\/v1\/globals\/typography\/(?P<id>[\\w]+)":{"namespace":"elementor\/v1","methods":["GET","POST","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the object.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST"],"args":{"id":{"description":"Unique identifier for the object.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Unique identifier for the object.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/elementor\/v1\/settings\/(?P<key>[\\w_-]+)":{"namespace":"elementor\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/elementor\/v1\/post":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"included_types":{"description":"Included post types","type":"array","default":null,"required":false},"excluded_types":{"description":"Post type to exclude","type":"array","default":["e-floating-buttons","e-landing-page","elementor_library","attachment","revision","nav_menu_item","custom_css","customize_changeset"],"required":false},"term":{"description":"Posts to search","type":"string","default":"","required":false},"keys_conversion_map":{"description":"Specify keys to extract and convert, i.e. [\"key_1\" => \"new_key_1\"].","type":"array","default":{"ID":"id","post_title":"label","post_type":"groupLabel"},"required":false},"items_count":{"description":"Posts per page","type":"integer","default":100,"required":false},"is_public":{"description":"Whether to include only public post types","type":"boolean","default":true,"required":false},"meta_query":{"description":"WP_Query meta_query array","type":"array","default":null,"required":false},"tax_query":{"description":"WP_Query tax_query array","type":"array","default":null,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/elementor\/v1\/post"}]}},"\/elementor\/v1\/term":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"included_types":{"description":"Included taxonomy containing terms (categories, tags, etc...)","type":"array","default":null,"required":false},"excluded_types":{"description":"Excluded taxonomy containing terms (categories, tags, etc...)","type":"array","default":null,"required":false},"term":{"description":"Terms to search","type":"string","default":"","required":false},"keys_conversion_map":{"description":"Specify keys to extract and convert, i.e. [\"key_1\" => \"new_key_1\"].","type":"array","default":{"term_id":"id","name":"label","taxonomy":"groupLabel"},"required":false},"items_count":{"description":"Terms per request","type":"integer","default":100,"required":false},"hide_empty":{"description":"Whether to include only public terms","type":"boolean","default":false,"required":false},"meta_query":{"description":"WP_Query meta_query array","type":"array","default":null,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/elementor\/v1\/term"}]}},"\/elementor\/v1\/user":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"term":{"description":"Posts to search","type":"string","default":"","required":false},"keys_conversion_map":{"description":"Specify keys to extract and convert, i.e. [\"key_1\" => \"new_key_1\"].","type":["array","string"],"default":{"ID":"id","display_name":"label","role":"groupLabel"},"required":false},"items_count":{"description":"Posts per page","type":"integer","default":100,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/elementor\/v1\/user"}]}},"\/elementor-ai\/v1":{"namespace":"elementor-ai\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"elementor-ai\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/elementor-ai\/v1"}]}},"\/elementor-ai\/v1\/permissions":{"namespace":"elementor-ai\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/elementor-ai\/v1\/permissions"}]}},"\/elementor\/v1\/favorites":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados para aqueles que combinam com um texto.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/elementor\/v1\/favorites"}]}},"\/elementor\/v1\/favorites\/(?P<id>[\\w]+)":{"namespace":"elementor\/v1","methods":["POST","DELETE"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Type of favorites.","type":"string","required":true},"favorite":{"description":"The favorite slug to create.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Type of favorites.","type":"string","required":true},"favorite":{"description":"The favorite slug to delete.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/elementor\/v1\/kit-elements-defaults":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/elementor\/v1\/kit-elements-defaults"}]}},"\/elementor\/v1\/kit-elements-defaults\/(?P<type>[\\w\\-\\_]+)":{"namespace":"elementor\/v1","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"type":{"type":"string","description":"The type of the element.","required":true},"settings":{"description":"All the default values for the requested type","type":"object","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["DELETE"],"args":{"type":{"type":"string","description":"The type of the element.","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/elementor\/v1\/site-navigation\/recent-posts":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"posts_per_page":{"description":"Number of posts to return","type":"integer","required":true},"post_type":{"description":"Post types to retrieve","type":"array","default":["page","post","elementor_library"],"required":false},"post__not_in":{"description":"Post id`s to exclude","type":"array","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/elementor\/v1\/site-navigation\/recent-posts"}]}},"\/elementor\/v1\/site-navigation\/add-new-post":{"namespace":"elementor\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"post_type":{"description":"Post type to create","type":"string","default":"post","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/elementor\/v1\/site-navigation\/add-new-post"}]}},"\/elementor\/v1\/checklist":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados para aqueles que combinam com um texto.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/elementor\/v1\/checklist"}]}},"\/elementor\/v1\/checklist\/(?P<id>[\\d]+)":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the object.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/elementor\/v1\/checklist\/steps":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/elementor\/v1\/checklist\/steps"}]}},"\/elementor\/v1\/checklist\/steps\/(?P<id>[\\d]+)":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the object.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/elementor\/v1\/checklist\/steps\/(?P<id>[\\w\\-\\_]+)":{"namespace":"elementor\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"id":{"type":"string","description":"The step id.","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/elementor\/v1\/checklist\/user-progress":{"namespace":"elementor\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/elementor\/v1\/checklist\/user-progress"}]}},"\/elementor\/v1\/components":{"namespace":"elementor\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST"],"args":{"status":{"type":"string","enum":["publish","draft","autosave"],"required":true},"items":{"type":"array","items":{"type":"object","properties":{"uid":{"type":"string","required":true},"title":{"type":"string","required":true,"minLength":2,"maxLength":200},"elements":{"type":"array","required":true,"items":{"type":"object"}},"settings":{"type":"object","required":false}}},"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/elementor\/v1\/components"}]}},"\/elementor\/v1\/components\/styles":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/elementor\/v1\/components\/styles"}]}},"\/elementor\/v1\/components\/create-validate":{"namespace":"elementor\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"items":{"type":"array","items":{"type":"object","properties":{"uid":{"type":"string","required":true},"title":{"type":"string","required":true,"minLength":2,"maxLength":200},"elements":{"type":"array","required":true,"items":{"type":"object"}},"settings":{"type":"object","required":false}}},"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/elementor\/v1\/components\/create-validate"}]}},"\/elementor\/v1\/components\/overridable-props":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"componentId":{"type":"integer","description":"The component ID to get overridable props for","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/elementor\/v1\/components\/overridable-props"}]}},"\/elementor\/v1\/components\/status":{"namespace":"elementor\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":{"status":{"type":"string","enum":["publish"],"required":true},"ids":{"type":"array","items":{"type":"number","required":true},"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/elementor\/v1\/components\/status"}]}},"\/elementor\/v1\/components\/lock":{"namespace":"elementor\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"componentId":{"type":"number","description":"The component ID to unlock","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/elementor\/v1\/components\/lock"}]}},"\/elementor\/v1\/components\/unlock":{"namespace":"elementor\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"componentId":{"type":"number","description":"The component ID to unlock","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/elementor\/v1\/components\/unlock"}]}},"\/elementor\/v1\/components\/lock-status":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"componentId":{"type":"string","description":"The component ID to check lock status","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/elementor\/v1\/components\/lock-status"}]}},"\/elementor\/v1\/components\/archive":{"namespace":"elementor\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"componentIds":{"type":"array","items":{"type":"number","required":true},"description":"The component IDs to archive","required":true},"status":{"type":"string","enum":["publish","draft","autosave"],"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/elementor\/v1\/components\/archive"}]}},"\/elementor\/v1\/components\/update-titles":{"namespace":"elementor\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"components":{"type":"array","items":{"type":"object","properties":{"componentId":{"type":"number","required":true,"description":"The component ID to update title"},"title":{"type":"string","required":true,"description":"The new title for the component"}}},"required":true},"status":{"type":"string","enum":["publish","draft","autosave"],"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/elementor\/v1\/components\/update-titles"}]}},"\/elementor\/v1\/feedback":{"namespace":"elementor\/v1\/feedback","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"elementor\/v1\/feedback","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/elementor\/v1\/feedback"}]}},"\/elementor\/v1\/feedback\/submit":{"namespace":"elementor\/v1\/feedback","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/elementor\/v1\/feedback\/submit"}]}},"\/elementor\/v1\/template-library\/templates":{"namespace":"elementor\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST"],"args":{"title":{"type":"string","description":"The title of the document","required":false},"type":{"description":"The document type.","type":"string","enum":["page","section","landing-page","popup","header","footer","single","single-post","single-page","archive","search-results","error-404","loop-item"],"required":true},"content":{"description":"Elementor data object","type":"object","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/elementor\/v1\/template-library\/templates"}]}},"\/elementor\/v1\/user-data\/current-user":{"namespace":"elementor\/v1","methods":["GET","PATCH"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["PATCH"],"args":{"suppressedMessages":{"type":"array","description":"Array of suppressed message keys","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/elementor\/v1\/user-data\/current-user"}]}},"\/elementor\/v1\/global-widget\/templates":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/elementor\/v1\/global-widget\/templates"}]}},"\/elementor-pro\/v1\/posts-widget":{"namespace":"elementor-pro\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/elementor-pro\/v1\/posts-widget"}]}},"\/elementor\/v1\/form-submissions":{"namespace":"elementor\/v1","methods":["GET","DELETE","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":50,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","additionalProperties":{"context":"filter"},"required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"order_by":{"description":"Sort collection by object attribute.","type":"string","default":"created_at","enum":["created_at","id","main_meta_id"],"required":false},"status":{"description":"Limit result set to submissions assigned one or more statuses.","type":"string","default":"all","enum":["all","unread","read","trash"],"additionalProperties":{"context":"filter"},"required":false},"form":{"description":"Limit result set to submissions assigned to specific forms. The form id should follow this pattern {post_id}_{element_id} e.g: 10_476d0ce","type":"string","additionalProperties":{"context":"filter"},"required":false},"referer":{"description":"Limit result set to submissions assigned to specific referer.","type":"string","additionalProperties":{"context":"filter"},"required":false},"after":{"description":"Limit response to submissions sent after a given ISO8601 compliant date.","type":"string","format":"date","additionalProperties":{"context":"filter"},"required":false},"before":{"description":"Limit response to submissions sent before a given ISO8601 compliant date.","type":"string","format":"date","additionalProperties":{"context":"filter"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["DELETE"],"args":{"ids":{"description":"Unique identifiers for the objects.","type":"array","items":{"type":"integer"},"required":true},"force":{"description":"Delete the object permanently.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"ids":{"description":"Unique identifiers for the objects.","type":"array","items":{"type":"integer"},"required":true},"is_read":{"description":"mark whether the submission was read or not","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/elementor\/v1\/form-submissions"}]}},"\/elementor\/v1\/form-submissions\/(?P<id>[\\d]+)":{"namespace":"elementor\/v1","methods":["GET","DELETE","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the object.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Unique identifier for the object.","type":"string","required":true},"force":{"description":"Delete the object permanently.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Unique identifier for the object.","type":"string","required":true},"is_read":{"description":"mark whether the submission was read or not","type":"boolean","required":false},"values":{"description":"Form field values, receive an array, the key should be the form field id and the value should be the value.","type":"object","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/elementor\/v1\/form-submissions\/restore\/(?P<id>[\\d]+)":{"namespace":"elementor\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Unique identifier for the object.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/elementor\/v1\/form-submissions\/restore":{"namespace":"elementor\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"ids":{"description":"Unique identifiers for the objects.","type":"array","items":{"type":"integer"},"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/elementor\/v1\/form-submissions\/restore"}]}},"\/elementor\/v1\/form-submissions\/export":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":10000,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","additionalProperties":{"context":"filter"},"required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"order_by":{"description":"Sort collection by object attribute.","type":"string","default":"created_at","enum":["created_at","id","main_meta_id"],"required":false},"status":{"description":"Limit result set to submissions assigned one or more statuses.","type":"string","default":"all","enum":["all","unread","read","trash"],"additionalProperties":{"context":"filter"},"required":false},"form":{"description":"Limit result set to submissions assigned to specific forms. The form id should follow this pattern {post_id}_{element_id} e.g: 10_476d0ce","type":"string","additionalProperties":{"context":"filter"},"required":false},"referer":{"description":"Limit result set to submissions assigned to specific referer.","type":"string","additionalProperties":{"context":"filter"},"required":false},"after":{"description":"Limit response to submissions sent after a given ISO8601 compliant date.","type":"string","format":"date","additionalProperties":{"context":"filter"},"required":false},"before":{"description":"Limit response to submissions sent before a given ISO8601 compliant date.","type":"string","format":"date","additionalProperties":{"context":"filter"},"required":false},"ids":{"description":"Unique identifiers for the objects.","type":"array","items":{"type":"integer"},"additionalProperties":{"context":"filter"},"required":false},"format":{"description":"The format of the export (for now only csv).","enum":["csv"],"default":"csv","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/elementor\/v1\/form-submissions\/export"}]}},"\/elementor\/v1\/form-submissions\/referer":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made, determines fields present in response. (only \"options\" available for now)","type":"string","enum":["options"],"default":"options","required":false},"search":{"description":"Limit results to those matching a string.","type":"string","additionalProperties":{"context":"filter"},"required":false},"value":{"description":"Limit results specific referer.","type":"string","additionalProperties":{"context":"filter"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/elementor\/v1\/form-submissions\/referer"}]}},"\/elementor\/v1\/forms":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made, determines fields present in response. (only \"options\" available for now)","type":"string","enum":["options"],"default":"options","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/elementor\/v1\/forms"}]}},"\/elementor-pro\/v1\/get-post-type-taxonomies":{"namespace":"elementor-pro\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"post_type":{"description":"The post type for which to fetch the list of taxonomies.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/elementor-pro\/v1\/get-post-type-taxonomies"}]}},"\/elementor-pro\/v1\/refresh-loop":{"namespace":"elementor-pro\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"post_id":{"description":"The post ID of the page containing the loop.","type":"integer","required":true},"widget_id":{"description":"The ID of the loop widget.","type":"string","required":true},"widget_filters":{"description":"The filters for the loop widget.","type":"object","required":true},"widget_model":{"description":"The model of the loop widget. In Editor mode only.","type":"object","required":false},"pagination_base_url":{"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/elementor-pro\/v1\/refresh-loop"}]}},"\/elementor-pro\/v1\/refresh-search":{"namespace":"elementor-pro\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"post_id":{"description":"The post ID of the page containing the loop.","type":"integer","required":true},"widget_id":{"description":"The ID of the loop widget.","type":"string","required":true},"widget_model":{"description":"The model of the loop widget. In Editor mode only.","type":"object","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/elementor-pro\/v1\/refresh-search"}]}},"\/elementor\/v1\/notes":{"namespace":"elementor\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"route_url":{"type":"string","description":"The URL of the route where the note was created at.","required":false},"status":{"type":"string","description":"The note status (e.g. \"publish\", \"draft\").","enum":["publish","draft"],"default":"publish","required":false},"is_resolved":{"type":"boolean","description":"Whether the note is resolved or not.","required":false},"parent_id":{"type":"integer","description":"The note's parent id (use 0 for top-level).","required":false},"post_id":{"type":"integer","description":"The ID of the post that the note is attached to.","required":false},"only_unread":{"type":"boolean","description":"Show only unread notes (represents an unread thread if one of its replies is unread).","required":false},"only_relevant":{"type":"boolean","description":"Show only notes that are relevant to the current user.","required":false},"order_by":{"type":"string","description":"A column to order the results by.","default":"last_activity_at","enum":["last_activity_at","created_at"],"required":false},"order":{"type":"string","description":"Results order direction.","default":"desc","enum":["asc","desc"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST"],"args":{"post_id":{"type":"integer","description":"The id of the post where the note was created at (can be template, post, page, etc.).","required":true},"element_id":{"type":"string","description":"Each note must be attached to an elementor element.","required":true},"content":{"type":"string","description":"The content of the note.","required":true},"position":{"type":"object","properties":{"x":{"required":true,"type":"number"},"y":{"required":true,"type":"number"}},"description":"The position of the note.","required":true},"mentioned_usernames":{"type":"array","description":"List of user names that have been mentioned in the note's content.","default":[],"items":{"type":"string","sanitize_callback":{}},"required":false},"route_post_id":{"description":"The ID of the post that's associated with the route (doesn't always exist, e.g: home page, archive)","required":false},"route_url":{"type":"string","description":"The URL of the route where the note was created at.","required":false},"route_title":{"type":"string","description":"The title of the route where the note was created at.","required":false},"parent_id":{"type":"integer","description":"If the new note is a reply to another note, the parent_id should be the thread's id.","default":0,"required":false},"is_public":{"type":"boolean","description":"Should this note be visible for everyone or just for its author.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/elementor\/v1\/notes"}]}},"\/elementor\/v1\/notes\/read-status":{"namespace":"elementor\/v1","methods":["POST","DELETE"],"endpoints":[{"methods":["POST"],"args":{"ids":{"type":"array","description":"The id's of the notes.","items":{"type":"integer"},"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["DELETE"],"args":{"ids":{"type":"array","description":"The id's of the notes.","items":{"type":"integer"},"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/elementor\/v1\/notes\/read-status"}]}},"\/elementor\/v1\/notes\/summary":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"route_url":{"type":"string","description":"The URL of the route where the note was created at.","required":false},"status":{"type":"string","description":"The note status (e.g. \"publish\", \"draft\").","enum":["publish","draft"],"default":"publish","required":false},"is_resolved":{"type":"boolean","description":"Whether the note is resolved or not.","required":false},"parent_id":{"type":"integer","description":"The note's parent id (use 0 for top-level).","required":false},"post_id":{"type":"integer","description":"The ID of the post that the note is attached to.","required":false},"only_unread":{"type":"boolean","description":"Show only unread notes (represents an unread thread if one of its replies is unread).","required":false},"only_relevant":{"type":"boolean","description":"Show only notes that are relevant to the current user.","required":false},"order_by":{"type":"string","description":"A column to order the results by.","default":"last_activity_at","enum":["last_activity_at","created_at"],"required":false},"order":{"type":"string","description":"Results order direction.","default":"desc","enum":["asc","desc"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/elementor\/v1\/notes\/summary"}]}},"\/elementor\/v1\/notes\/users":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"limit":{"type":"integer","description":"Limit the results.","required":false},"order_by":{"type":"string","description":"A column to order the results by.","default":"display_name","enum":["user_nicename","display_name","user_registered"],"required":false},"order":{"type":"string","description":"Results order direction.","default":"asc","enum":["asc","desc"],"required":false},"search":{"type":"string","description":"Filter users by a search term.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/elementor\/v1\/notes\/users"}]}},"\/elementor\/v1\/notes\/(?P<id>[\\d]+)":{"namespace":"elementor\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"type":"integer","description":"Note ID to find.","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"type":"integer","description":"The id the note.","required":true},"content":{"type":"string","description":"The content of the note.","required":false},"mentioned_usernames":{"type":"array","description":"List of user names that have been mentioned in the note's content.","items":{"type":"string","sanitize_callback":{}},"required":false},"status":{"type":"string","description":"Note status can be draft or publish.","enum":["publish","draft"],"required":false},"is_public":{"type":"boolean","description":"Should this note be visible for everyone or just for its author.","required":false},"is_resolved":{"type":"boolean","description":"Is this note resolved and should be hidden.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"type":"integer","description":"The id of the note.","required":true},"force":{"type":"boolean","description":"Determine if it should be deleted permanently or change the status to trash.","default":false,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/elementskit\/v1\/widget\/mailchimp":{"namespace":"elementskit\/v1\/widget\/mailchimp","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"elementskit\/v1\/widget\/mailchimp","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/elementskit\/v1\/widget\/mailchimp"}]}},"\/elementskit\/v1\/widget\/mailchimp\/(?P<action>\\w+)":{"namespace":"elementskit\/v1\/widget\/mailchimp","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET","POST","PUT","PATCH","DELETE"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/elementskit\/v1\/dynamic-content":{"namespace":"elementskit\/v1\/dynamic-content","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"elementskit\/v1\/dynamic-content","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/elementskit\/v1\/dynamic-content"}]}},"\/elementskit\/v1\/dynamic-content\/(?P<action>\\w+)\/(?P<type>\\w+)\/(?P<key>\\w+(|[-]\\w+))":{"namespace":"elementskit\/v1\/dynamic-content","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET","POST","PUT","PATCH","DELETE"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/elementskit\/v1\/layout-manager-api":{"namespace":"elementskit\/v1\/layout-manager-api","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"elementskit\/v1\/layout-manager-api","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/elementskit\/v1\/layout-manager-api"}]}},"\/elementskit\/v1\/layout-manager-api\/(?P<action>\\w+)":{"namespace":"elementskit\/v1\/layout-manager-api","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET","POST","PUT","PATCH","DELETE"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/elementskit\/v1\/my-template":{"namespace":"elementskit\/v1\/my-template","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"elementskit\/v1\/my-template","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/elementskit\/v1\/my-template"}]}},"\/elementskit\/v1\/my-template\/(?P<action>\\w+)\/(?P<id>\\w+)":{"namespace":"elementskit\/v1\/my-template","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET","POST","PUT","PATCH","DELETE"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/elementskit\/v1\/megamenu":{"namespace":"elementskit\/v1\/megamenu","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"elementskit\/v1\/megamenu","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/elementskit\/v1\/megamenu"}]}},"\/elementskit\/v1\/megamenu\/(?P<action>\\w+)":{"namespace":"elementskit\/v1\/megamenu","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET","POST","PUT","PATCH","DELETE"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/elementskit\/v1\/widget-builder":{"namespace":"elementskit\/v1\/widget-builder","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"elementskit\/v1\/widget-builder","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/elementskit\/v1\/widget-builder"}]}},"\/elementskit\/v1\/widget-builder\/(?P<action>\\w+)\/(?P<id>\\w+(|[-]\\w+))":{"namespace":"elementskit\/v1\/widget-builder","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET","POST","PUT","PATCH","DELETE"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wpmudev_pcs\/v1":{"namespace":"wpmudev_pcs\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wpmudev_pcs\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wpmudev_pcs\/v1"}]}},"\/wpmudev_pcs\/v1\/plugincrosssell\/install_plugin":{"namespace":"wpmudev_pcs\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"plugin_slug":{"type":"string","required":true},"current_slug":{"type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wpmudev_pcs\/v1\/plugincrosssell\/install_plugin"}]}},"\/wpmudev_pcs\/v1\/plugincrosssell\/activate_plugin":{"namespace":"wpmudev_pcs\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"plugin_slug":{"type":"string","required":true},"current_slug":{"type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wpmudev_pcs\/v1\/plugincrosssell\/activate_plugin"}]}},"\/post-views-counter\/view-post\/(?P<id>\\d+)|\/view-post":{"namespace":"post-views-counter","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"default":0,"required":false},"storage_type":{"default":"cookies","required":false},"storage_data":{"default":"","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/post-views-counter\/get-post-views\/(?P<id>(\\d+,?)+)":{"namespace":"post-views-counter","methods":["GET","POST"],"endpoints":[{"methods":["GET","POST"],"args":{"id":{"default":0,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/otgs\/installer\/v1":{"namespace":"otgs\/installer\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"otgs\/installer\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/otgs\/installer\/v1"}]}},"\/otgs\/installer\/v1\/push\/fetch-subscription":{"namespace":"otgs\/installer\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/otgs\/installer\/v1\/push\/fetch-subscription"}]}},"\/elementor\/v1\/library\/connect":{"namespace":"elementor\/v1","methods":["POST","DELETE"],"endpoints":[{"methods":["POST"],"args":{"token":{"type":"string","description":"Connect CLI token","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["DELETE"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/elementor\/v1\/library\/connect"}]}},"\/elementor\/v1\/send-event":{"namespace":"elementor\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados para aqueles que combinam com um texto.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST"],"args":{"event_data":{"description":"All the recorded event data in JSON format","type":"object","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/elementor\/v1\/send-event"}]}},"\/jetpack\/v4\/verify_registration":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/verify_registration"}]}},"\/jetpack\/v4\/remote_authorize":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/remote_authorize"}]}},"\/jetpack\/v4\/remote_provision":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/remote_provision"}]}},"\/jetpack\/v4\/remote_register":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/remote_register"}]}},"\/jetpack\/v4\/remote_connect":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/remote_connect"}]}},"\/jetpack\/v4\/connection\/check":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/connection\/check"}]}},"\/jetpack\/v4\/connection":{"namespace":"jetpack\/v4","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"isActive":{"description":"Definir como falso acionar\u00e1 a desconex\u00e3o do site.","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/connection"}]}},"\/jetpack\/v4\/connection\/user":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/connection\/user"}]}},"\/jetpack\/v4\/connection\/data":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/connection\/data"}]}},"\/jetpack\/v4\/connection\/plugins":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/connection\/plugins"}]}},"\/jetpack\/v4\/connection\/reconnect":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/connection\/reconnect"}]}},"\/jetpack\/v4\/connection\/register":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"from":{"description":"Indica onde a a\u00e7\u00e3o de registro foi disparada para fins de rastreamento\/segmenta\u00e7\u00e3o","type":"string","required":false},"redirect_uri":{"description":"URI da p\u00e1gina de administra\u00e7\u00e3o para onde o usu\u00e1rio \u00e9 redirecionado ap\u00f3s um fluxo de conex\u00e3o","type":"string","required":false},"plugin_slug":{"description":"Indica de qual plugin est\u00e1 vindo a solicita\u00e7\u00e3o","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/connection\/register"}]}},"\/jetpack\/v4\/connection\/authorize_url":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"redirect_uri":{"description":"URI da p\u00e1gina de administra\u00e7\u00e3o para onde o usu\u00e1rio \u00e9 redirecionado ap\u00f3s um fluxo de conex\u00e3o","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/connection\/authorize_url"}]}},"\/jetpack\/v4\/user-token":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"user_token":{"description":"Novo token de usu\u00e1rio","type":"string","required":true},"is_connection_owner":{"description":"\u00c9 propriet\u00e1rio da conex\u00e3o","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/user-token"}]}},"\/jetpack\/v4\/connection\/owner":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"owner":{"description":"Novo propriet\u00e1rio","type":"integer","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/jetpack\/v4\/connection\/owner"}]}},"\/wp\/v2":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp\/v2","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wp\/v2"}]}},"\/wp\/v2\/posts":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados para aqueles que combinam com um texto.","type":"string","required":false},"after":{"description":"Limitar respostas a posts publicados depois de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limitar respostas a posts modificados depois de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Limitar resultados a posts atribu\u00eddos a autores espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Garantir que o resultado exclui posts atribu\u00eddos a autores espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limitar respostas a posts publicados antes de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limitar respostas a posts modificados antes de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Garantir que o resultado exclua IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar resultados para IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Como interpretar o campo de pesquisa.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Deslocar o resultado para um n\u00famero especifico de itens.","type":"integer","required":false},"order":{"description":"Ordenar atributos de forma ascendente ou descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar cole\u00e7\u00e3o pelo atributo do post.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","post_views"],"required":false},"search_columns":{"default":[],"description":"Array de nomes de colunas para serem pesquisadas.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limitar resultados de posts definidos por um ou mais slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limitar resultados de posts atribu\u00eddo por um ou mais status.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limitar resultados com base no relacionamento entre m\u00faltiplas taxonomias.","type":"string","enum":["AND","OR"],"required":false},"categories":{"description":"Limitar resultados para todos os itens com termos espec\u00edficos atribu\u00eddos a taxonomia categories.","type":["object","array"],"oneOf":[{"title":"Lista de ID de termos","description":"Combinar os termos com os IDs listados.","type":"array","items":{"type":"integer"}},{"title":"Consulta da taxonomia do ID do termo","description":"Executar uma consulta avan\u00e7a de termos.","type":"object","properties":{"terms":{"description":"IDs dos termos.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Possibilidade de incluir termos descendentes nos termos limitando o conjunto de resultados.","type":"boolean","default":false},"operator":{"description":"Se os items devem ser atribu\u00eddos a todos ou a qualquer um dos termos especificados.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"categories_exclude":{"description":"Limitar resultados para todos os itens que tenham o termo espec\u00edfico atribu\u00eddo para a taxonomia categories.","type":["object","array"],"oneOf":[{"title":"Lista de ID de termos","description":"Combinar os termos com os IDs listados.","type":"array","items":{"type":"integer"}},{"title":"Consulta da taxonomia do ID do termo","description":"Executar uma consulta avan\u00e7a de termos.","type":"object","properties":{"terms":{"description":"IDs dos termos.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Possibilidade de incluir termos descendentes nos termos limitando o conjunto de resultados.","type":"boolean","default":false}},"additionalProperties":false}],"required":false},"tags":{"description":"Limitar resultados para todos os itens com termos espec\u00edficos atribu\u00eddos a taxonomia tags.","type":["object","array"],"oneOf":[{"title":"Lista de ID de termos","description":"Combinar os termos com os IDs listados.","type":"array","items":{"type":"integer"}},{"title":"Consulta da taxonomia do ID do termo","description":"Executar uma consulta avan\u00e7a de termos.","type":"object","properties":{"terms":{"description":"IDs dos termos.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Se os items devem ser atribu\u00eddos a todos ou a qualquer um dos termos especificados.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"tags_exclude":{"description":"Limitar resultados para todos os itens que tenham o termo espec\u00edfico atribu\u00eddo para a taxonomia tags.","type":["object","array"],"oneOf":[{"title":"Lista de ID de termos","description":"Combinar os termos com os IDs listados.","type":"array","items":{"type":"integer"}},{"title":"Consulta da taxonomia do ID do termo","description":"Executar uma consulta avan\u00e7a de termos.","type":"object","properties":{"terms":{"description":"IDs dos termos.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"sticky":{"description":"Limitar resultados de itens que sejam fixos.","type":"boolean","required":false},"ignore_sticky":{"description":"Se deve ou n\u00e3o ignorar os artigos fixos.","type":"boolean","default":true,"required":false},"format":{"description":"Limita conjunto de resultados a itens atribu\u00eddos a um ou mais formatos espec\u00edficos.","type":"array","uniqueItems":true,"items":{"enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Data da publica\u00e7\u00e3o do post, no fuso hor\u00e1rio do site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data que o post foi publicado, em GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Um identificador alfanum\u00e9rico para o post.","type":"string","required":false},"status":{"description":"Um nome de status para o post.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Uma senha para proteger o acesso ao conte\u00fado e resumo.","type":"string","required":false},"title":{"description":"O t\u00edtulo para o post.","type":"object","properties":{"raw":{"description":"T\u00edtulo para o post, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo para o post em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"O conte\u00fado para o post.","type":"object","properties":{"raw":{"description":"Conte\u00fado para o post, como ele existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"Conte\u00fado HTML do post, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Vers\u00e3o do formato do conte\u00fado do bloco usado pelo post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Se o conte\u00fado \u00e9 protegido por senha.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"O ID do autor para o post.","type":"integer","required":false},"excerpt":{"description":"O resumo para o post.","type":"object","properties":{"raw":{"description":"Resumo para o post, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"Resumo para o post em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Se o resumo \u00e9 protegido por senha.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"O ID da imagem destacada para o post.","type":"integer","required":false},"comment_status":{"description":"Se os coment\u00e1rios no post devem ou n\u00e3o ser abertos.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Se o post pode receber chamadas ping.","type":"string","enum":["open","closed"],"required":false},"format":{"description":"O formato para o post.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"footnotes":{"type":"string","title":"","description":"","default":""},"_elementor_edit_mode":{"type":"string","title":"Elementor edit mode","description":"Elementor edit mode, `builder` is required for Elementor editing","default":"","enum":["","builder"],"context":["edit"]},"_elementor_template_type":{"type":"string","title":"Elementor template type","description":"Elementor document type","default":"","enum":["post","wp-post","wp-page","kit","not-supported","page","section","landing-page","cloud-template-preview","elementor_component","widget","popup","header","footer","single","single-post","single-page","archive","search-results","error-404","code_snippet","loop-item",""],"context":["edit"]},"_elementor_data":{"type":"string","title":"Elementor data","description":"Elementor JSON as a string","default":"","context":["edit"]},"_elementor_page_settings":{"type":"object","title":"Elementor page settings","description":"Elementor page level settings","default":"{}","properties":{"hide_title":{"type":"string","enum":["yes","no"],"default":""}},"additionalProperties":true,"context":["edit"]},"_elementor_conditions":{"type":"array","title":"","description":"Elementor conditions","default":[],"additionalProperties":true,"context":["edit"]}},"required":false},"sticky":{"description":"Se o post deve ser tratado como fixo.","type":"boolean","required":false},"template":{"description":"O arquivo do tema usado para exibir o post.","type":"string","required":false},"categories":{"description":"Os termos atribu\u00eddos ao post na taxonomia category.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"Os termos atribu\u00eddos ao post na taxonomia post_tag.","type":"array","items":{"type":"integer"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wp\/v2\/posts"}]}},"\/wp\/v2\/posts\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o post.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Substitui o tamanho padr\u00e3o do resumo.","type":"integer","required":false},"password":{"description":"A senha para o post se este for protegido por senha.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o post.","type":"integer","required":false},"date":{"description":"Data da publica\u00e7\u00e3o do post, no fuso hor\u00e1rio do site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data que o post foi publicado, em GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Um identificador alfanum\u00e9rico para o post.","type":"string","required":false},"status":{"description":"Um nome de status para o post.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Uma senha para proteger o acesso ao conte\u00fado e resumo.","type":"string","required":false},"title":{"description":"O t\u00edtulo para o post.","type":"object","properties":{"raw":{"description":"T\u00edtulo para o post, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo para o post em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"O conte\u00fado para o post.","type":"object","properties":{"raw":{"description":"Conte\u00fado para o post, como ele existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"Conte\u00fado HTML do post, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Vers\u00e3o do formato do conte\u00fado do bloco usado pelo post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Se o conte\u00fado \u00e9 protegido por senha.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"O ID do autor para o post.","type":"integer","required":false},"excerpt":{"description":"O resumo para o post.","type":"object","properties":{"raw":{"description":"Resumo para o post, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"Resumo para o post em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Se o resumo \u00e9 protegido por senha.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"O ID da imagem destacada para o post.","type":"integer","required":false},"comment_status":{"description":"Se os coment\u00e1rios no post devem ou n\u00e3o ser abertos.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Se o post pode receber chamadas ping.","type":"string","enum":["open","closed"],"required":false},"format":{"description":"O formato para o post.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"footnotes":{"type":"string","title":"","description":"","default":""},"_elementor_edit_mode":{"type":"string","title":"Elementor edit mode","description":"Elementor edit mode, `builder` is required for Elementor editing","default":"","enum":["","builder"],"context":["edit"]},"_elementor_template_type":{"type":"string","title":"Elementor template type","description":"Elementor document type","default":"","enum":["post","wp-post","wp-page","kit","not-supported","page","section","landing-page","cloud-template-preview","elementor_component","widget","popup","header","footer","single","single-post","single-page","archive","search-results","error-404","code_snippet","loop-item",""],"context":["edit"]},"_elementor_data":{"type":"string","title":"Elementor data","description":"Elementor JSON as a string","default":"","context":["edit"]},"_elementor_page_settings":{"type":"object","title":"Elementor page settings","description":"Elementor page level settings","default":"{}","properties":{"hide_title":{"type":"string","enum":["yes","no"],"default":""}},"additionalProperties":true,"context":["edit"]},"_elementor_conditions":{"type":"array","title":"","description":"Elementor conditions","default":[],"additionalProperties":true,"context":["edit"]}},"required":false},"sticky":{"description":"Se o post deve ser tratado como fixo.","type":"boolean","required":false},"template":{"description":"O arquivo do tema usado para exibir o post.","type":"string","required":false},"categories":{"description":"Os termos atribu\u00eddos ao post na taxonomia category.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"Os termos atribu\u00eddos ao post na taxonomia post_tag.","type":"array","items":{"type":"integer"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o post.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ignorar ou n\u00e3o o envio para a lixeira e for\u00e7ar a exclus\u00e3o.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O ID do item ascendente \u00e0 revis\u00e3o.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados para aqueles que combinam com um texto.","type":"string","required":false},"exclude":{"description":"Garantir que o resultado exclua IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar resultados para IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Deslocar o resultado para um n\u00famero especifico de itens.","type":"integer","required":false},"order":{"description":"Ordenar atributos de forma ascendente ou descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar cole\u00e7\u00e3o pelo atributo do objeto.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O ID do item ascendente \u00e0 revis\u00e3o.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico da revis\u00e3o.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"O ID do item ascendente \u00e0 revis\u00e3o.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico da revis\u00e3o.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Necess\u00e1rio ser verdadeiro, as revis\u00f5es n\u00e3o suportam lixeira.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp\/v2\/posts\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O ID do item ascendente ao salvamento autom\u00e1tico.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST"],"args":{"parent":{"description":"O ID do item ascendente ao salvamento autom\u00e1tico.","type":"integer","required":false},"date":{"description":"Data da publica\u00e7\u00e3o do post, no fuso hor\u00e1rio do site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data que o post foi publicado, em GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Um identificador alfanum\u00e9rico para o post.","type":"string","required":false},"status":{"description":"Um nome de status para o post.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Uma senha para proteger o acesso ao conte\u00fado e resumo.","type":"string","required":false},"title":{"description":"O t\u00edtulo para o post.","type":"object","properties":{"raw":{"description":"T\u00edtulo para o post, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo para o post em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"O conte\u00fado para o post.","type":"object","properties":{"raw":{"description":"Conte\u00fado para o post, como ele existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"Conte\u00fado HTML do post, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Vers\u00e3o do formato do conte\u00fado do bloco usado pelo post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Se o conte\u00fado \u00e9 protegido por senha.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"O ID do autor para o post.","type":"integer","required":false},"excerpt":{"description":"O resumo para o post.","type":"object","properties":{"raw":{"description":"Resumo para o post, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"Resumo para o post em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Se o resumo \u00e9 protegido por senha.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"O ID da imagem destacada para o post.","type":"integer","required":false},"comment_status":{"description":"Se os coment\u00e1rios no post devem ou n\u00e3o ser abertos.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Se o post pode receber chamadas ping.","type":"string","enum":["open","closed"],"required":false},"format":{"description":"O formato para o post.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"footnotes":{"type":"string","title":"","description":"","default":""},"_elementor_edit_mode":{"type":"string","title":"Elementor edit mode","description":"Elementor edit mode, `builder` is required for Elementor editing","default":"","enum":["","builder"],"context":["edit"]},"_elementor_template_type":{"type":"string","title":"Elementor template type","description":"Elementor document type","default":"","enum":["post","wp-post","wp-page","kit","not-supported","page","section","landing-page","cloud-template-preview","elementor_component","widget","popup","header","footer","single","single-post","single-page","archive","search-results","error-404","code_snippet","loop-item",""],"context":["edit"]},"_elementor_data":{"type":"string","title":"Elementor data","description":"Elementor JSON as a string","default":"","context":["edit"]},"_elementor_page_settings":{"type":"object","title":"Elementor page settings","description":"Elementor page level settings","default":"{}","properties":{"hide_title":{"type":"string","enum":["yes","no"],"default":""}},"additionalProperties":true,"context":["edit"]},"_elementor_conditions":{"type":"array","title":"","description":"Elementor conditions","default":[],"additionalProperties":true,"context":["edit"]}},"required":false},"sticky":{"description":"Se o post deve ser tratado como fixo.","type":"boolean","required":false},"template":{"description":"O arquivo do tema usado para exibir o post.","type":"string","required":false},"categories":{"description":"Os termos atribu\u00eddos ao post na taxonomia category.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"Os termos atribu\u00eddos ao post na taxonomia post_tag.","type":"array","items":{"type":"integer"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O ID do item ascendente ao salvamento autom\u00e1tico.","type":"integer","required":false},"id":{"description":"O ID do salvamento autom\u00e1tico.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp\/v2\/pages":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados para aqueles que combinam com um texto.","type":"string","required":false},"after":{"description":"Limitar respostas a posts publicados depois de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limitar respostas a posts modificados depois de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Limitar resultados a posts atribu\u00eddos a autores espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Garantir que o resultado exclui posts atribu\u00eddos a autores espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limitar respostas a posts publicados antes de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limitar respostas a posts modificados antes de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Garantir que o resultado exclua IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar resultados para IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"menu_order":{"description":"Limitar resultados para posts com um valor menu_order espec\u00edfico.","type":"integer","required":false},"search_semantics":{"description":"Como interpretar o campo de pesquisa.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Deslocar o resultado para um n\u00famero especifico de itens.","type":"integer","required":false},"order":{"description":"Ordenar atributos de forma ascendente ou descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar cole\u00e7\u00e3o pelo atributo do post.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"parent":{"description":"Limitar resultados para itens cujos ascendentes t\u00eam determinados IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limitar resultados para todos os itens, exceto aqueles de um ID de ascendente em particular.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_columns":{"default":[],"description":"Array de nomes de colunas para serem pesquisadas.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limitar resultados de posts definidos por um ou mais slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limitar resultados de posts atribu\u00eddo por um ou mais status.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Data da publica\u00e7\u00e3o do post, no fuso hor\u00e1rio do site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data que o post foi publicado, em GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Um identificador alfanum\u00e9rico para o post.","type":"string","required":false},"status":{"description":"Um nome de status para o post.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Uma senha para proteger o acesso ao conte\u00fado e resumo.","type":"string","required":false},"parent":{"description":"O ID do ascendente para o post.","type":"integer","required":false},"title":{"description":"O t\u00edtulo para o post.","type":"object","properties":{"raw":{"description":"T\u00edtulo para o post, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo para o post em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"O conte\u00fado para o post.","type":"object","properties":{"raw":{"description":"Conte\u00fado para o post, como ele existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"Conte\u00fado HTML do post, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Vers\u00e3o do formato do conte\u00fado do bloco usado pelo post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Se o conte\u00fado \u00e9 protegido por senha.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"O ID do autor para o post.","type":"integer","required":false},"excerpt":{"description":"O resumo para o post.","type":"object","properties":{"raw":{"description":"Resumo para o post, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"Resumo para o post em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Se o resumo \u00e9 protegido por senha.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"O ID da imagem destacada para o post.","type":"integer","required":false},"comment_status":{"description":"Se os coment\u00e1rios no post devem ou n\u00e3o ser abertos.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Se o post pode receber chamadas ping.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"A ordem do post em rela\u00e7\u00e3o a outros posts.","type":"integer","required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"footnotes":{"type":"string","title":"","description":"","default":""},"_elementor_edit_mode":{"type":"string","title":"Elementor edit mode","description":"Elementor edit mode, `builder` is required for Elementor editing","default":"","enum":["","builder"],"context":["edit"]},"_elementor_template_type":{"type":"string","title":"Elementor template type","description":"Elementor document type","default":"","enum":["post","wp-post","wp-page","kit","not-supported","page","section","landing-page","cloud-template-preview","elementor_component","widget","popup","header","footer","single","single-post","single-page","archive","search-results","error-404","code_snippet","loop-item",""],"context":["edit"]},"_elementor_data":{"type":"string","title":"Elementor data","description":"Elementor JSON as a string","default":"","context":["edit"]},"_elementor_page_settings":{"type":"object","title":"Elementor page settings","description":"Elementor page level settings","default":"{}","properties":{"hide_title":{"type":"string","enum":["yes","no"],"default":""}},"additionalProperties":true,"context":["edit"]},"_elementor_conditions":{"type":"array","title":"","description":"Elementor conditions","default":[],"additionalProperties":true,"context":["edit"]}},"required":false},"template":{"description":"O arquivo do tema usado para exibir o post.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wp\/v2\/pages"}]}},"\/wp\/v2\/pages\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o post.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Substitui o tamanho padr\u00e3o do resumo.","type":"integer","required":false},"password":{"description":"A senha para o post se este for protegido por senha.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o post.","type":"integer","required":false},"date":{"description":"Data da publica\u00e7\u00e3o do post, no fuso hor\u00e1rio do site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data que o post foi publicado, em GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Um identificador alfanum\u00e9rico para o post.","type":"string","required":false},"status":{"description":"Um nome de status para o post.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Uma senha para proteger o acesso ao conte\u00fado e resumo.","type":"string","required":false},"parent":{"description":"O ID do ascendente para o post.","type":"integer","required":false},"title":{"description":"O t\u00edtulo para o post.","type":"object","properties":{"raw":{"description":"T\u00edtulo para o post, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo para o post em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"O conte\u00fado para o post.","type":"object","properties":{"raw":{"description":"Conte\u00fado para o post, como ele existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"Conte\u00fado HTML do post, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Vers\u00e3o do formato do conte\u00fado do bloco usado pelo post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Se o conte\u00fado \u00e9 protegido por senha.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"O ID do autor para o post.","type":"integer","required":false},"excerpt":{"description":"O resumo para o post.","type":"object","properties":{"raw":{"description":"Resumo para o post, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"Resumo para o post em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Se o resumo \u00e9 protegido por senha.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"O ID da imagem destacada para o post.","type":"integer","required":false},"comment_status":{"description":"Se os coment\u00e1rios no post devem ou n\u00e3o ser abertos.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Se o post pode receber chamadas ping.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"A ordem do post em rela\u00e7\u00e3o a outros posts.","type":"integer","required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"footnotes":{"type":"string","title":"","description":"","default":""},"_elementor_edit_mode":{"type":"string","title":"Elementor edit mode","description":"Elementor edit mode, `builder` is required for Elementor editing","default":"","enum":["","builder"],"context":["edit"]},"_elementor_template_type":{"type":"string","title":"Elementor template type","description":"Elementor document type","default":"","enum":["post","wp-post","wp-page","kit","not-supported","page","section","landing-page","cloud-template-preview","elementor_component","widget","popup","header","footer","single","single-post","single-page","archive","search-results","error-404","code_snippet","loop-item",""],"context":["edit"]},"_elementor_data":{"type":"string","title":"Elementor data","description":"Elementor JSON as a string","default":"","context":["edit"]},"_elementor_page_settings":{"type":"object","title":"Elementor page settings","description":"Elementor page level settings","default":"{}","properties":{"hide_title":{"type":"string","enum":["yes","no"],"default":""}},"additionalProperties":true,"context":["edit"]},"_elementor_conditions":{"type":"array","title":"","description":"Elementor conditions","default":[],"additionalProperties":true,"context":["edit"]}},"required":false},"template":{"description":"O arquivo do tema usado para exibir o post.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o post.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ignorar ou n\u00e3o o envio para a lixeira e for\u00e7ar a exclus\u00e3o.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O ID do item ascendente \u00e0 revis\u00e3o.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados para aqueles que combinam com um texto.","type":"string","required":false},"exclude":{"description":"Garantir que o resultado exclua IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar resultados para IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Deslocar o resultado para um n\u00famero especifico de itens.","type":"integer","required":false},"order":{"description":"Ordenar atributos de forma ascendente ou descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar cole\u00e7\u00e3o pelo atributo do objeto.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O ID do item ascendente \u00e0 revis\u00e3o.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico da revis\u00e3o.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"O ID do item ascendente \u00e0 revis\u00e3o.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico da revis\u00e3o.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Necess\u00e1rio ser verdadeiro, as revis\u00f5es n\u00e3o suportam lixeira.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp\/v2\/pages\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O ID do item ascendente ao salvamento autom\u00e1tico.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST"],"args":{"parent":{"description":"O ID do ascendente para o post.","type":"integer","required":false},"date":{"description":"Data da publica\u00e7\u00e3o do post, no fuso hor\u00e1rio do site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data que o post foi publicado, em GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Um identificador alfanum\u00e9rico para o post.","type":"string","required":false},"status":{"description":"Um nome de status para o post.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Uma senha para proteger o acesso ao conte\u00fado e resumo.","type":"string","required":false},"title":{"description":"O t\u00edtulo para o post.","type":"object","properties":{"raw":{"description":"T\u00edtulo para o post, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo para o post em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"O conte\u00fado para o post.","type":"object","properties":{"raw":{"description":"Conte\u00fado para o post, como ele existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"Conte\u00fado HTML do post, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Vers\u00e3o do formato do conte\u00fado do bloco usado pelo post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Se o conte\u00fado \u00e9 protegido por senha.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"O ID do autor para o post.","type":"integer","required":false},"excerpt":{"description":"O resumo para o post.","type":"object","properties":{"raw":{"description":"Resumo para o post, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"Resumo para o post em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Se o resumo \u00e9 protegido por senha.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"O ID da imagem destacada para o post.","type":"integer","required":false},"comment_status":{"description":"Se os coment\u00e1rios no post devem ou n\u00e3o ser abertos.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Se o post pode receber chamadas ping.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"A ordem do post em rela\u00e7\u00e3o a outros posts.","type":"integer","required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"footnotes":{"type":"string","title":"","description":"","default":""},"_elementor_edit_mode":{"type":"string","title":"Elementor edit mode","description":"Elementor edit mode, `builder` is required for Elementor editing","default":"","enum":["","builder"],"context":["edit"]},"_elementor_template_type":{"type":"string","title":"Elementor template type","description":"Elementor document type","default":"","enum":["post","wp-post","wp-page","kit","not-supported","page","section","landing-page","cloud-template-preview","elementor_component","widget","popup","header","footer","single","single-post","single-page","archive","search-results","error-404","code_snippet","loop-item",""],"context":["edit"]},"_elementor_data":{"type":"string","title":"Elementor data","description":"Elementor JSON as a string","default":"","context":["edit"]},"_elementor_page_settings":{"type":"object","title":"Elementor page settings","description":"Elementor page level settings","default":"{}","properties":{"hide_title":{"type":"string","enum":["yes","no"],"default":""}},"additionalProperties":true,"context":["edit"]},"_elementor_conditions":{"type":"array","title":"","description":"Elementor conditions","default":[],"additionalProperties":true,"context":["edit"]}},"required":false},"template":{"description":"O arquivo do tema usado para exibir o post.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O ID do item ascendente ao salvamento autom\u00e1tico.","type":"integer","required":false},"id":{"description":"O ID do salvamento autom\u00e1tico.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp\/v2\/media":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados para aqueles que combinam com um texto.","type":"string","required":false},"after":{"description":"Limitar respostas a posts publicados depois de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limitar respostas a posts modificados depois de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Limitar resultados a posts atribu\u00eddos a autores espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Garantir que o resultado exclui posts atribu\u00eddos a autores espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limitar respostas a posts publicados antes de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limitar respostas a posts modificados antes de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Garantir que o resultado exclua IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar resultados para IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Como interpretar o campo de pesquisa.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Deslocar o resultado para um n\u00famero especifico de itens.","type":"integer","required":false},"order":{"description":"Ordenar atributos de forma ascendente ou descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar cole\u00e7\u00e3o pelo atributo do post.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"parent":{"description":"Limitar resultados para itens cujos ascendentes t\u00eam determinados IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limitar resultados para todos os itens, exceto aqueles de um ID de ascendente em particular.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_columns":{"default":[],"description":"Array de nomes de colunas para serem pesquisadas.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limitar resultados de posts definidos por um ou mais slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"inherit","description":"Limitar resultados de posts atribu\u00eddo por um ou mais status.","type":"array","items":{"enum":["inherit","private","trash"],"type":"string"},"required":false},"media_type":{"default":null,"description":"Limita resultados a anexos de um tipo de m\u00eddia em particular ou tipos de m\u00eddia.","type":"array","items":{"type":"string","enum":["image","video","text","application","audio"]},"required":false},"mime_type":{"default":null,"description":"Limita resultados a anexos de um tipo MIME em particular ou tipos MIME.","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST"],"args":{"date":{"description":"Data da publica\u00e7\u00e3o do post, no fuso hor\u00e1rio do site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data que o post foi publicado, em GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Um identificador alfanum\u00e9rico para o post.","type":"string","required":false},"status":{"description":"Um nome de status para o post.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"title":{"description":"O t\u00edtulo para o post.","type":"object","properties":{"raw":{"description":"T\u00edtulo para o post, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo para o post em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"O ID do autor para o post.","type":"integer","required":false},"featured_media":{"description":"O ID da imagem destacada para o post.","type":"integer","required":false},"comment_status":{"description":"Se os coment\u00e1rios no post devem ou n\u00e3o ser abertos.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Se o post pode receber chamadas ping.","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"Campos meta.","type":"object","properties":[],"required":false},"template":{"description":"O arquivo do tema usado para exibir o post.","type":"string","required":false},"smush":{"description":"Compactar dados.","type":"string","required":false},"alt_text":{"description":"Texto alternativo para exibir quando o anexo n\u00e3o \u00e9 exibido.","type":"string","required":false},"caption":{"description":"A legenda do anexo.","type":"object","properties":{"raw":{"description":"Legenda para o anexo, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"Legenda HTML para o anexo, transformada para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"A descri\u00e7\u00e3o do anexo.","type":"object","properties":{"raw":{"description":"Descri\u00e7\u00e3o para o anexo, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"Descri\u00e7\u00e3o HTML para o anexo, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"post":{"description":"O ID para o post associado ao anexo.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wp\/v2\/media"}]}},"\/wp\/v2\/media\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identificador \u00fanico para o post.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identificador \u00fanico para o post.","type":"integer","required":false},"date":{"description":"Data da publica\u00e7\u00e3o do post, no fuso hor\u00e1rio do site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data que o post foi publicado, em GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Um identificador alfanum\u00e9rico para o post.","type":"string","required":false},"status":{"description":"Um nome de status para o post.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"title":{"description":"O t\u00edtulo para o post.","type":"object","properties":{"raw":{"description":"T\u00edtulo para o post, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo para o post em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"O ID do autor para o post.","type":"integer","required":false},"featured_media":{"description":"O ID da imagem destacada para o post.","type":"integer","required":false},"comment_status":{"description":"Se os coment\u00e1rios no post devem ou n\u00e3o ser abertos.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Se o post pode receber chamadas ping.","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"Campos meta.","type":"object","properties":[],"required":false},"template":{"description":"O arquivo do tema usado para exibir o post.","type":"string","required":false},"smush":{"description":"Compactar dados.","type":"string","required":false},"alt_text":{"description":"Texto alternativo para exibir quando o anexo n\u00e3o \u00e9 exibido.","type":"string","required":false},"caption":{"description":"A legenda do anexo.","type":"object","properties":{"raw":{"description":"Legenda para o anexo, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"Legenda HTML para o anexo, transformada para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"A descri\u00e7\u00e3o do anexo.","type":"object","properties":{"raw":{"description":"Descri\u00e7\u00e3o para o anexo, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"Descri\u00e7\u00e3o HTML para o anexo, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"post":{"description":"O ID para o post associado ao anexo.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identificador \u00fanico para o post.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ignorar ou n\u00e3o o envio para a lixeira e for\u00e7ar a exclus\u00e3o.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp\/v2\/media\/(?P<id>[\\d]+)\/post-process":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Identificador \u00fanico para o anexo.","type":"integer","required":false},"action":{"type":"string","enum":["create-image-subsizes"],"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp\/v2\/media\/(?P<id>[\\d]+)\/edit":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"src":{"description":"URL para o arquivo de imagem editado.","type":"string","format":"uri","required":true},"modifiers":{"description":"Array de edi\u00e7\u00f5es da imagem.","type":"array","minItems":1,"items":{"description":"Edi\u00e7\u00e3o de imagem.","type":"object","required":["type","args"],"oneOf":[{"title":"Virar","properties":{"type":{"description":"Tipo de giro.","type":"string","enum":["flip"]},"args":{"description":"Argumentos de invers\u00e3o.","type":"object","required":["flip"],"properties":{"flip":{"description":"Dire\u00e7\u00e3o de invers\u00e3o.","type":"object","required":["horizontal","vertical"],"properties":{"horizontal":{"description":"Se deve virar na dire\u00e7\u00e3o horizontal.","type":"boolean"},"vertical":{"description":"Se deve virar na dire\u00e7\u00e3o vertical.","type":"boolean"}}}}}}},{"title":"Rota\u00e7\u00e3o","properties":{"type":{"description":"Tipo de rota\u00e7\u00e3o.","type":"string","enum":["rotate"]},"args":{"description":"Argumentos para rota\u00e7\u00e3o.","type":"object","required":["angle"],"properties":{"angle":{"description":"\u00c2ngulo para girar no sentido hor\u00e1rio em graus..","type":"number"}}}}},{"title":"Recortar","properties":{"type":{"description":"Tipo de recorte.","type":"string","enum":["crop"]},"args":{"description":"Argumentos para recortar.","type":"object","required":["left","top","width","height"],"properties":{"left":{"description":"Posi\u00e7\u00e3o vertical da esquerda para iniciar um recorte como uma porcentagem da largura da imagem.","type":"number"},"top":{"description":"Posi\u00e7\u00e3o vertical do topo para iniciar um recorte como uma porcentagem da altura da imagem.","type":"number"},"width":{"description":"Largura para recortar como uma porcentagem da largura da imagem.","type":"number"},"height":{"description":"Altura para recortar como uma porcentagem da altura da imagem.","type":"number"}}}}}]},"required":false},"rotation":{"description":"A quantidade para girar a imagem no sentido hor\u00e1rio em graus. Obsoleto: use `modifiers` no lugar.","type":"integer","minimum":0,"exclusiveMinimum":true,"maximum":360,"exclusiveMaximum":true,"required":false},"x":{"description":"Como uma porcentagem da imagem, a posi\u00e7\u00e3o x para iniciar o recorte. Obsoleto: use `modifiers` no lugar.","type":"number","minimum":0,"maximum":100,"required":false},"y":{"description":"Como uma porcentagem da imagem, a posi\u00e7\u00e3o y para iniciar o recorte. Obsoleto: use `modifiers` no lugar.","type":"number","minimum":0,"maximum":100,"required":false},"width":{"description":"Como uma porcentagem da imagem, a largura que a imagem ser\u00e1 recortada. Obsoleto: use `modifiers` no lugar.","type":"number","minimum":0,"maximum":100,"required":false},"height":{"description":"Como uma porcentagem da imagem, a altura que a imagem ser\u00e1 recortada. Obsoleto: use `modifiers` no lugar.","type":"number","minimum":0,"maximum":100,"required":false},"caption":{"description":"A legenda do anexo.","type":"object","properties":{"raw":{"description":"Legenda para o anexo, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"Legenda HTML para o anexo, transformada para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"A descri\u00e7\u00e3o do anexo.","type":"object","properties":{"raw":{"description":"Descri\u00e7\u00e3o para o anexo, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"Descri\u00e7\u00e3o HTML para o anexo, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"title":{"description":"O t\u00edtulo para o post.","type":"object","properties":{"raw":{"description":"T\u00edtulo para o post, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo para o post em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"post":{"description":"O ID para o post associado ao anexo.","type":"integer","required":false},"alt_text":{"description":"Texto alternativo para exibir quando o anexo n\u00e3o \u00e9 exibido.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp\/v2\/menu-items":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","default":100,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados para aqueles que combinam com um texto.","type":"string","required":false},"after":{"description":"Limitar respostas a posts publicados depois de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limitar respostas a posts modificados depois de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limitar respostas a posts publicados antes de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limitar respostas a posts modificados antes de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Garantir que o resultado exclua IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar resultados para IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Como interpretar o campo de pesquisa.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Deslocar o resultado para um n\u00famero especifico de itens.","type":"integer","required":false},"order":{"description":"Ordenar atributos de forma ascendente ou descendente.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar cole\u00e7\u00e3o pelo atributo do objeto.","type":"string","default":"menu_order","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"search_columns":{"default":[],"description":"Array de nomes de colunas para serem pesquisadas.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limitar resultados de posts definidos por um ou mais slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limitar resultados de posts atribu\u00eddo por um ou mais status.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limitar resultados com base no relacionamento entre m\u00faltiplas taxonomias.","type":"string","enum":["AND","OR"],"required":false},"menus":{"description":"Limitar resultados para todos os itens com termos espec\u00edficos atribu\u00eddos a taxonomia menus.","type":["object","array"],"oneOf":[{"title":"Lista de ID de termos","description":"Combinar os termos com os IDs listados.","type":"array","items":{"type":"integer"}},{"title":"Consulta da taxonomia do ID do termo","description":"Executar uma consulta avan\u00e7a de termos.","type":"object","properties":{"terms":{"description":"IDs dos termos.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Se os items devem ser atribu\u00eddos a todos ou a qualquer um dos termos especificados.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"menus_exclude":{"description":"Limitar resultados para todos os itens que tenham o termo espec\u00edfico atribu\u00eddo para a taxonomia menus.","type":["object","array"],"oneOf":[{"title":"Lista de ID de termos","description":"Combinar os termos com os IDs listados.","type":"array","items":{"type":"integer"}},{"title":"Consulta da taxonomia do ID do termo","description":"Executar uma consulta avan\u00e7a de termos.","type":"object","properties":{"terms":{"description":"IDs dos termos.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"menu_order":{"description":"Limitar resultados para posts com um valor menu_order espec\u00edfico.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"title":{"description":"O t\u00edtulo para o objeto.","type":["string","object"],"properties":{"raw":{"description":"T\u00edtulo para o objeto, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo para o objeto em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"default":"custom","description":"A fam\u00edlia de objetos originalmente representados, como \"post_type\" ou \"taxonomy\".","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"default":"publish","description":"Um nome de status para o objeto.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"parent":{"default":0,"description":"O ID do item ascendente ao objeto.","type":"integer","minimum":0,"required":false},"attr_title":{"description":"Texto referente ao atributo de t\u00edtulo do elemento de link deste item de menu.","type":"string","required":false},"classes":{"description":"Nomes de classe do elemento de link deste item de menu.","type":"array","items":{"type":"string"},"required":false},"description":{"description":"A descri\u00e7\u00e3o deste item de menu.","type":"string","required":false},"menu_order":{"default":1,"description":"O ID de banco de dados do nav_menu_item ascendente deste item, se houver. Caso contr\u00e1rio, \u00e9 0.","type":"integer","minimum":1,"required":false},"object":{"description":"O tipo do objeto originalmente representado, como \"category,\" \"post\" ou \"attachment\".","type":"string","required":false},"object_id":{"default":0,"description":"O ID no banco de dados do objeto original que representa este item de menu, por exemplo o ID para os posts e o term_id para as categorias.","type":"integer","minimum":0,"required":false},"target":{"description":"O atributo target (destino) de um elemento de link para este item de menu.","type":"string","enum":["_blank",""],"required":false},"url":{"description":"O URL para o qual este item de menu aponta.","type":"string","format":"uri","required":false},"xfn":{"description":"A rela\u00e7\u00e3o XFN expressa no link deste item de menu.","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"Os termos atribu\u00eddos ao objeto na taxonomia nav_menu.","type":"integer","required":false},"meta":{"description":"Campos meta.","type":"object","properties":[],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wp\/v2\/menu-items"}]}},"\/wp\/v2\/menu-items\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o post.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o post.","type":"integer","required":false},"title":{"description":"O t\u00edtulo para o objeto.","type":["string","object"],"properties":{"raw":{"description":"T\u00edtulo para o objeto, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo para o objeto em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"description":"A fam\u00edlia de objetos originalmente representados, como \"post_type\" ou \"taxonomy\".","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"description":"Um nome de status para o objeto.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"parent":{"description":"O ID do item ascendente ao objeto.","type":"integer","minimum":0,"required":false},"attr_title":{"description":"Texto referente ao atributo de t\u00edtulo do elemento de link deste item de menu.","type":"string","required":false},"classes":{"description":"Nomes de classe do elemento de link deste item de menu.","type":"array","items":{"type":"string"},"required":false},"description":{"description":"A descri\u00e7\u00e3o deste item de menu.","type":"string","required":false},"menu_order":{"description":"O ID de banco de dados do nav_menu_item ascendente deste item, se houver. Caso contr\u00e1rio, \u00e9 0.","type":"integer","minimum":1,"required":false},"object":{"description":"O tipo do objeto originalmente representado, como \"category,\" \"post\" ou \"attachment\".","type":"string","required":false},"object_id":{"description":"O ID no banco de dados do objeto original que representa este item de menu, por exemplo o ID para os posts e o term_id para as categorias.","type":"integer","minimum":0,"required":false},"target":{"description":"O atributo target (destino) de um elemento de link para este item de menu.","type":"string","enum":["_blank",""],"required":false},"url":{"description":"O URL para o qual este item de menu aponta.","type":"string","format":"uri","required":false},"xfn":{"description":"A rela\u00e7\u00e3o XFN expressa no link deste item de menu.","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"Os termos atribu\u00eddos ao objeto na taxonomia nav_menu.","type":"integer","required":false},"meta":{"description":"Campos meta.","type":"object","properties":[],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o post.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ignorar ou n\u00e3o o envio para a lixeira e for\u00e7ar a exclus\u00e3o.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp\/v2\/menu-items\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O ID do item ascendente ao salvamento autom\u00e1tico.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST"],"args":{"parent":{"description":"O ID do item ascendente ao objeto.","type":"integer","minimum":0,"required":false},"title":{"description":"O t\u00edtulo para o objeto.","type":["string","object"],"properties":{"raw":{"description":"T\u00edtulo para o objeto, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo para o objeto em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"description":"A fam\u00edlia de objetos originalmente representados, como \"post_type\" ou \"taxonomy\".","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"description":"Um nome de status para o objeto.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"attr_title":{"description":"Texto referente ao atributo de t\u00edtulo do elemento de link deste item de menu.","type":"string","required":false},"classes":{"description":"Nomes de classe do elemento de link deste item de menu.","type":"array","items":{"type":"string"},"required":false},"description":{"description":"A descri\u00e7\u00e3o deste item de menu.","type":"string","required":false},"menu_order":{"description":"O ID de banco de dados do nav_menu_item ascendente deste item, se houver. Caso contr\u00e1rio, \u00e9 0.","type":"integer","minimum":1,"required":false},"object":{"description":"O tipo do objeto originalmente representado, como \"category,\" \"post\" ou \"attachment\".","type":"string","required":false},"object_id":{"description":"O ID no banco de dados do objeto original que representa este item de menu, por exemplo o ID para os posts e o term_id para as categorias.","type":"integer","minimum":0,"required":false},"target":{"description":"O atributo target (destino) de um elemento de link para este item de menu.","type":"string","enum":["_blank",""],"required":false},"url":{"description":"O URL para o qual este item de menu aponta.","type":"string","format":"uri","required":false},"xfn":{"description":"A rela\u00e7\u00e3o XFN expressa no link deste item de menu.","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"Os termos atribu\u00eddos ao objeto na taxonomia nav_menu.","type":"integer","required":false},"meta":{"description":"Campos meta.","type":"object","properties":[],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp\/v2\/menu-items\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O ID do item ascendente ao salvamento autom\u00e1tico.","type":"integer","required":false},"id":{"description":"O ID do salvamento autom\u00e1tico.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp\/v2\/blocks":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados para aqueles que combinam com um texto.","type":"string","required":false},"after":{"description":"Limitar respostas a posts publicados depois de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limitar respostas a posts modificados depois de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limitar respostas a posts publicados antes de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limitar respostas a posts modificados antes de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Garantir que o resultado exclua IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar resultados para IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Como interpretar o campo de pesquisa.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Deslocar o resultado para um n\u00famero especifico de itens.","type":"integer","required":false},"order":{"description":"Ordenar atributos de forma ascendente ou descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar cole\u00e7\u00e3o pelo atributo do post.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array de nomes de colunas para serem pesquisadas.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limitar resultados de posts definidos por um ou mais slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limitar resultados de posts atribu\u00eddo por um ou mais status.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limitar resultados com base no relacionamento entre m\u00faltiplas taxonomias.","type":"string","enum":["AND","OR"],"required":false},"wp_pattern_category":{"description":"Limitar resultados para todos os itens com termos espec\u00edficos atribu\u00eddos a taxonomia wp_pattern_category.","type":["object","array"],"oneOf":[{"title":"Lista de ID de termos","description":"Combinar os termos com os IDs listados.","type":"array","items":{"type":"integer"}},{"title":"Consulta da taxonomia do ID do termo","description":"Executar uma consulta avan\u00e7a de termos.","type":"object","properties":{"terms":{"description":"IDs dos termos.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Se os items devem ser atribu\u00eddos a todos ou a qualquer um dos termos especificados.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"wp_pattern_category_exclude":{"description":"Limitar resultados para todos os itens que tenham o termo espec\u00edfico atribu\u00eddo para a taxonomia wp_pattern_category.","type":["object","array"],"oneOf":[{"title":"Lista de ID de termos","description":"Combinar os termos com os IDs listados.","type":"array","items":{"type":"integer"}},{"title":"Consulta da taxonomia do ID do termo","description":"Executar uma consulta avan\u00e7a de termos.","type":"object","properties":{"terms":{"description":"IDs dos termos.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Data da publica\u00e7\u00e3o do post, no fuso hor\u00e1rio do site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data que o post foi publicado, em GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Um identificador alfanum\u00e9rico para o post.","type":"string","required":false},"status":{"description":"Um nome de status para o post.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Uma senha para proteger o acesso ao conte\u00fado e resumo.","type":"string","required":false},"title":{"description":"O t\u00edtulo para o post.","type":"object","properties":{"raw":{"description":"T\u00edtulo para o post, como existe no banco de dados.","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"O conte\u00fado para o post.","type":"object","properties":{"raw":{"description":"Conte\u00fado para o post, como ele existe no banco de dados.","type":"string","context":["view","edit"]},"block_version":{"description":"Vers\u00e3o do formato do conte\u00fado do bloco usado pelo post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Se o conte\u00fado \u00e9 protegido por senha.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"O resumo para o post.","type":"object","properties":{"raw":{"description":"Resumo para o post, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"Resumo para o post em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Se o resumo \u00e9 protegido por senha.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"O arquivo do tema usado para exibir o post.","type":"string","required":false},"wp_pattern_category":{"description":"Os termos atribu\u00eddos ao post na taxonomia wp_pattern_category.","type":"array","items":{"type":"integer"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wp\/v2\/blocks"}]}},"\/wp\/v2\/blocks\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o post.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Substitui o tamanho padr\u00e3o do resumo.","type":"integer","required":false},"password":{"description":"A senha para o post se este for protegido por senha.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o post.","type":"integer","required":false},"date":{"description":"Data da publica\u00e7\u00e3o do post, no fuso hor\u00e1rio do site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data que o post foi publicado, em GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Um identificador alfanum\u00e9rico para o post.","type":"string","required":false},"status":{"description":"Um nome de status para o post.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Uma senha para proteger o acesso ao conte\u00fado e resumo.","type":"string","required":false},"title":{"description":"O t\u00edtulo para o post.","type":"object","properties":{"raw":{"description":"T\u00edtulo para o post, como existe no banco de dados.","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"O conte\u00fado para o post.","type":"object","properties":{"raw":{"description":"Conte\u00fado para o post, como ele existe no banco de dados.","type":"string","context":["view","edit"]},"block_version":{"description":"Vers\u00e3o do formato do conte\u00fado do bloco usado pelo post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Se o conte\u00fado \u00e9 protegido por senha.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"O resumo para o post.","type":"object","properties":{"raw":{"description":"Resumo para o post, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"Resumo para o post em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Se o resumo \u00e9 protegido por senha.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"O arquivo do tema usado para exibir o post.","type":"string","required":false},"wp_pattern_category":{"description":"Os termos atribu\u00eddos ao post na taxonomia wp_pattern_category.","type":"array","items":{"type":"integer"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o post.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ignorar ou n\u00e3o o envio para a lixeira e for\u00e7ar a exclus\u00e3o.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O ID do item ascendente \u00e0 revis\u00e3o.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados para aqueles que combinam com um texto.","type":"string","required":false},"exclude":{"description":"Garantir que o resultado exclua IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar resultados para IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Deslocar o resultado para um n\u00famero especifico de itens.","type":"integer","required":false},"order":{"description":"Ordenar atributos de forma ascendente ou descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar cole\u00e7\u00e3o pelo atributo do objeto.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O ID do item ascendente \u00e0 revis\u00e3o.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico da revis\u00e3o.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"O ID do item ascendente \u00e0 revis\u00e3o.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico da revis\u00e3o.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Necess\u00e1rio ser verdadeiro, as revis\u00f5es n\u00e3o suportam lixeira.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp\/v2\/blocks\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O ID do item ascendente ao salvamento autom\u00e1tico.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST"],"args":{"parent":{"description":"O ID do item ascendente ao salvamento autom\u00e1tico.","type":"integer","required":false},"date":{"description":"Data da publica\u00e7\u00e3o do post, no fuso hor\u00e1rio do site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data que o post foi publicado, em GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Um identificador alfanum\u00e9rico para o post.","type":"string","required":false},"status":{"description":"Um nome de status para o post.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Uma senha para proteger o acesso ao conte\u00fado e resumo.","type":"string","required":false},"title":{"description":"O t\u00edtulo para o post.","type":"object","properties":{"raw":{"description":"T\u00edtulo para o post, como existe no banco de dados.","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"O conte\u00fado para o post.","type":"object","properties":{"raw":{"description":"Conte\u00fado para o post, como ele existe no banco de dados.","type":"string","context":["view","edit"]},"block_version":{"description":"Vers\u00e3o do formato do conte\u00fado do bloco usado pelo post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Se o conte\u00fado \u00e9 protegido por senha.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"O resumo para o post.","type":"object","properties":{"raw":{"description":"Resumo para o post, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"Resumo para o post em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Se o resumo \u00e9 protegido por senha.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"O arquivo do tema usado para exibir o post.","type":"string","required":false},"wp_pattern_category":{"description":"Os termos atribu\u00eddos ao post na taxonomia wp_pattern_category.","type":"array","items":{"type":"integer"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O ID do item ascendente ao salvamento autom\u00e1tico.","type":"integer","required":false},"id":{"description":"O ID do salvamento autom\u00e1tico.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O id de um modelo","type":"string","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados para aqueles que combinam com um texto.","type":"string","required":false},"exclude":{"description":"Garantir que o resultado exclua IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar resultados para IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Deslocar o resultado para um n\u00famero especifico de itens.","type":"integer","required":false},"order":{"description":"Ordenar atributos de forma ascendente ou descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar cole\u00e7\u00e3o pelo atributo do objeto.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O id de um modelo","type":"string","required":false},"id":{"description":"Identificador \u00fanico da revis\u00e3o.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"O id de um modelo","type":"string","required":false},"id":{"description":"Identificador \u00fanico da revis\u00e3o.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Necess\u00e1rio ser verdadeiro, as revis\u00f5es n\u00e3o suportam lixeira.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp\/v2\/templates\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"O id de um modelo","type":"string","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST"],"args":{"id":{"description":"O id de um modelo","type":"string","required":false},"slug":{"description":"Slug \u00fanico que identifica o modelo.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Identificador de tema para o modelo.","type":"string","required":false},"type":{"description":"Tipo do modelo.","type":"string","required":false},"content":{"description":"Conte\u00fado do modelo.","type":["object","string"],"properties":{"raw":{"description":"Conte\u00fado para o modelo, como existe no banco de dados.","type":"string","context":["view","edit"]},"block_version":{"description":"Vers\u00e3o do formato do bloco de conte\u00fado usado pelo modelo.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"T\u00edtulo do modelo.","type":["object","string"],"properties":{"raw":{"description":"T\u00edtulo para o modelo, como existe no banco de dados.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"T\u00edtulo para o modelo em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Descri\u00e7\u00e3o do modelo.","type":"string","required":false},"status":{"description":"Status do modelo.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"O ID do autor para o modelo.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O id de um modelo","type":"string","required":false},"id":{"description":"O ID do salvamento autom\u00e1tico.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp\/v2\/templates":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wp_id":{"description":"Limitar ao ID do post especificado.","type":"integer","required":false},"area":{"description":"Limitar \u00e0 \u00e1rea de parte de modelo especificada.","type":"string","required":false},"post_type":{"description":"Tipo de post para obter os modelos.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST"],"args":{"slug":{"description":"Slug \u00fanico que identifica o modelo.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":true},"theme":{"description":"Identificador de tema para o modelo.","type":"string","required":false},"type":{"description":"Tipo do modelo.","type":"string","required":false},"content":{"default":"","description":"Conte\u00fado do modelo.","type":["object","string"],"properties":{"raw":{"description":"Conte\u00fado para o modelo, como existe no banco de dados.","type":"string","context":["view","edit"]},"block_version":{"description":"Vers\u00e3o do formato do bloco de conte\u00fado usado pelo modelo.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"default":"","description":"T\u00edtulo do modelo.","type":["object","string"],"properties":{"raw":{"description":"T\u00edtulo para o modelo, como existe no banco de dados.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"T\u00edtulo para o modelo em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"default":"","description":"Descri\u00e7\u00e3o do modelo.","type":"string","required":false},"status":{"default":"publish","description":"Status do modelo.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"O ID do autor para o modelo.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wp\/v2\/templates"}]}},"\/wp\/v2\/templates\/lookup":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"O slug do modelo para obter o padr\u00e3o para","type":"string","required":true},"is_custom":{"description":"Indica se um modelo \u00e9 personalizado ou faz parte da hierarquia de modelo","type":"boolean","required":false},"template_prefix":{"description":"O prefixo do modelo para o modelo criado. Isso \u00e9 usado para extrair o tipo de modelo principal, por exemplo, em `taxonomia-livros` extrai a `taxonomia`","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wp\/v2\/templates\/lookup"}]}},"\/wp\/v2\/templates\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"O id de um modelo","type":"string","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"O id de um modelo","type":"string","required":false},"slug":{"description":"Slug \u00fanico que identifica o modelo.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Identificador de tema para o modelo.","type":"string","required":false},"type":{"description":"Tipo do modelo.","type":"string","required":false},"content":{"description":"Conte\u00fado do modelo.","type":["object","string"],"properties":{"raw":{"description":"Conte\u00fado para o modelo, como existe no banco de dados.","type":"string","context":["view","edit"]},"block_version":{"description":"Vers\u00e3o do formato do bloco de conte\u00fado usado pelo modelo.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"T\u00edtulo do modelo.","type":["object","string"],"properties":{"raw":{"description":"T\u00edtulo para o modelo, como existe no banco de dados.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"T\u00edtulo para o modelo em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Descri\u00e7\u00e3o do modelo.","type":"string","required":false},"status":{"description":"Status do modelo.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"O ID do autor para o modelo.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"O id de um modelo","type":"string","required":false},"force":{"type":"boolean","default":false,"description":"Ignorar ou n\u00e3o o envio para a lixeira e for\u00e7ar a exclus\u00e3o.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O id de um modelo","type":"string","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados para aqueles que combinam com um texto.","type":"string","required":false},"exclude":{"description":"Garantir que o resultado exclua IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar resultados para IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Deslocar o resultado para um n\u00famero especifico de itens.","type":"integer","required":false},"order":{"description":"Ordenar atributos de forma ascendente ou descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar cole\u00e7\u00e3o pelo atributo do objeto.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O id de um modelo","type":"string","required":false},"id":{"description":"Identificador \u00fanico da revis\u00e3o.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"O id de um modelo","type":"string","required":false},"id":{"description":"Identificador \u00fanico da revis\u00e3o.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Necess\u00e1rio ser verdadeiro, as revis\u00f5es n\u00e3o suportam lixeira.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp\/v2\/template-parts\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"O id de um modelo","type":"string","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST"],"args":{"id":{"description":"O id de um modelo","type":"string","required":false},"slug":{"description":"Slug \u00fanico que identifica o modelo.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Identificador de tema para o modelo.","type":"string","required":false},"type":{"description":"Tipo do modelo.","type":"string","required":false},"content":{"description":"Conte\u00fado do modelo.","type":["object","string"],"properties":{"raw":{"description":"Conte\u00fado para o modelo, como existe no banco de dados.","type":"string","context":["view","edit"]},"block_version":{"description":"Vers\u00e3o do formato do bloco de conte\u00fado usado pelo modelo.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"T\u00edtulo do modelo.","type":["object","string"],"properties":{"raw":{"description":"T\u00edtulo para o modelo, como existe no banco de dados.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"T\u00edtulo para o modelo em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Descri\u00e7\u00e3o do modelo.","type":"string","required":false},"status":{"description":"Status do modelo.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"O ID do autor para o modelo.","type":"integer","required":false},"area":{"description":"Onde a parte do modelo se destina a uso (cabe\u00e7alho, rodap\u00e9 etc.)","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O id de um modelo","type":"string","required":false},"id":{"description":"O ID do salvamento autom\u00e1tico.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp\/v2\/template-parts":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wp_id":{"description":"Limitar ao ID do post especificado.","type":"integer","required":false},"area":{"description":"Limitar \u00e0 \u00e1rea de parte de modelo especificada.","type":"string","required":false},"post_type":{"description":"Tipo de post para obter os modelos.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST"],"args":{"slug":{"description":"Slug \u00fanico que identifica o modelo.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":true},"theme":{"description":"Identificador de tema para o modelo.","type":"string","required":false},"type":{"description":"Tipo do modelo.","type":"string","required":false},"content":{"default":"","description":"Conte\u00fado do modelo.","type":["object","string"],"properties":{"raw":{"description":"Conte\u00fado para o modelo, como existe no banco de dados.","type":"string","context":["view","edit"]},"block_version":{"description":"Vers\u00e3o do formato do bloco de conte\u00fado usado pelo modelo.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"default":"","description":"T\u00edtulo do modelo.","type":["object","string"],"properties":{"raw":{"description":"T\u00edtulo para o modelo, como existe no banco de dados.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"T\u00edtulo para o modelo em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"default":"","description":"Descri\u00e7\u00e3o do modelo.","type":"string","required":false},"status":{"default":"publish","description":"Status do modelo.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"O ID do autor para o modelo.","type":"integer","required":false},"area":{"description":"Onde a parte do modelo se destina a uso (cabe\u00e7alho, rodap\u00e9 etc.)","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wp\/v2\/template-parts"}]}},"\/wp\/v2\/template-parts\/lookup":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"O slug do modelo para obter o padr\u00e3o para","type":"string","required":true},"is_custom":{"description":"Indica se um modelo \u00e9 personalizado ou faz parte da hierarquia de modelo","type":"boolean","required":false},"template_prefix":{"description":"O prefixo do modelo para o modelo criado. Isso \u00e9 usado para extrair o tipo de modelo principal, por exemplo, em `taxonomia-livros` extrai a `taxonomia`","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wp\/v2\/template-parts\/lookup"}]}},"\/wp\/v2\/template-parts\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"O id de um modelo","type":"string","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"O id de um modelo","type":"string","required":false},"slug":{"description":"Slug \u00fanico que identifica o modelo.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Identificador de tema para o modelo.","type":"string","required":false},"type":{"description":"Tipo do modelo.","type":"string","required":false},"content":{"description":"Conte\u00fado do modelo.","type":["object","string"],"properties":{"raw":{"description":"Conte\u00fado para o modelo, como existe no banco de dados.","type":"string","context":["view","edit"]},"block_version":{"description":"Vers\u00e3o do formato do bloco de conte\u00fado usado pelo modelo.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"T\u00edtulo do modelo.","type":["object","string"],"properties":{"raw":{"description":"T\u00edtulo para o modelo, como existe no banco de dados.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"T\u00edtulo para o modelo em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Descri\u00e7\u00e3o do modelo.","type":"string","required":false},"status":{"description":"Status do modelo.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"O ID do autor para o modelo.","type":"integer","required":false},"area":{"description":"Onde a parte do modelo se destina a uso (cabe\u00e7alho, rodap\u00e9 etc.)","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"O id de um modelo","type":"string","required":false},"force":{"type":"boolean","default":false,"description":"Ignorar ou n\u00e3o o envio para a lixeira e for\u00e7ar a exclus\u00e3o.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp\/v2\/global-styles\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O ID do item ascendente \u00e0 revis\u00e3o.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","minimum":1,"maximum":100,"required":false},"offset":{"description":"Deslocar o resultado para um n\u00famero especifico de itens.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp\/v2\/global-styles\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O ID ascendente da revis\u00e3o de estilos globais.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico para a revis\u00e3o de estilos globais.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp\/v2\/global-styles\/themes\/(?P<stylesheet>[\\\/\\s%\\w\\.\\(\\)\\[\\]\\@_\\-]+)\/variations":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"stylesheet":{"description":"O identificador do tema","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp\/v2\/global-styles\/themes\/(?P<stylesheet>[^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"stylesheet":{"description":"O identificador do tema","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp\/v2\/global-styles\/(?P<id>[\\\/\\d+]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"id":{"description":"ID da configura\u00e7\u00e3o de estilos globais.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":false},"args":{"styles":{"description":"Estilos globais.","type":["object"],"required":false},"settings":{"description":"Configura\u00e7\u00f5es globais","type":["object"],"required":false},"title":{"description":"T\u00edtulo da varia\u00e7\u00e3o de estilos globais.","type":["object","string"],"properties":{"raw":{"description":"T\u00edtulo para a varia\u00e7\u00e3o de estilos globais, como no banco de dados.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"T\u00edtulo para o post em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp\/v2\/navigation":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados para aqueles que combinam com um texto.","type":"string","required":false},"after":{"description":"Limitar respostas a posts publicados depois de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limitar respostas a posts modificados depois de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limitar respostas a posts publicados antes de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limitar respostas a posts modificados antes de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Garantir que o resultado exclua IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar resultados para IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Como interpretar o campo de pesquisa.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Deslocar o resultado para um n\u00famero especifico de itens.","type":"integer","required":false},"order":{"description":"Ordenar atributos de forma ascendente ou descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar cole\u00e7\u00e3o pelo atributo do post.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array de nomes de colunas para serem pesquisadas.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limitar resultados de posts definidos por um ou mais slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limitar resultados de posts atribu\u00eddo por um ou mais status.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Data da publica\u00e7\u00e3o do post, no fuso hor\u00e1rio do site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data que o post foi publicado, em GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Um identificador alfanum\u00e9rico para o post.","type":"string","required":false},"status":{"description":"Um nome de status para o post.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Uma senha para proteger o acesso ao conte\u00fado e resumo.","type":"string","required":false},"title":{"description":"O t\u00edtulo para o post.","type":"object","properties":{"raw":{"description":"T\u00edtulo para o post, como existe no banco de dados.","type":"string","context":["edit","embed"]},"rendered":{"description":"T\u00edtulo para o post em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"O conte\u00fado para o post.","type":"object","properties":{"raw":{"description":"Conte\u00fado para o post, como ele existe no banco de dados.","type":"string","context":["edit","embed"]},"rendered":{"description":"Conte\u00fado HTML do post, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"Vers\u00e3o do formato do conte\u00fado do bloco usado pelo post.","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"Se o conte\u00fado \u00e9 protegido por senha.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"O arquivo do tema usado para exibir o post.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wp\/v2\/navigation"}]}},"\/wp\/v2\/navigation\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o post.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"A senha para o post se este for protegido por senha.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o post.","type":"integer","required":false},"date":{"description":"Data da publica\u00e7\u00e3o do post, no fuso hor\u00e1rio do site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data que o post foi publicado, em GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Um identificador alfanum\u00e9rico para o post.","type":"string","required":false},"status":{"description":"Um nome de status para o post.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Uma senha para proteger o acesso ao conte\u00fado e resumo.","type":"string","required":false},"title":{"description":"O t\u00edtulo para o post.","type":"object","properties":{"raw":{"description":"T\u00edtulo para o post, como existe no banco de dados.","type":"string","context":["edit","embed"]},"rendered":{"description":"T\u00edtulo para o post em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"O conte\u00fado para o post.","type":"object","properties":{"raw":{"description":"Conte\u00fado para o post, como ele existe no banco de dados.","type":"string","context":["edit","embed"]},"rendered":{"description":"Conte\u00fado HTML do post, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"Vers\u00e3o do formato do conte\u00fado do bloco usado pelo post.","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"Se o conte\u00fado \u00e9 protegido por senha.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"O arquivo do tema usado para exibir o post.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o post.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ignorar ou n\u00e3o o envio para a lixeira e for\u00e7ar a exclus\u00e3o.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O ID do item ascendente \u00e0 revis\u00e3o.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados para aqueles que combinam com um texto.","type":"string","required":false},"exclude":{"description":"Garantir que o resultado exclua IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar resultados para IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Deslocar o resultado para um n\u00famero especifico de itens.","type":"integer","required":false},"order":{"description":"Ordenar atributos de forma ascendente ou descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar cole\u00e7\u00e3o pelo atributo do objeto.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O ID do item ascendente \u00e0 revis\u00e3o.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico da revis\u00e3o.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"O ID do item ascendente \u00e0 revis\u00e3o.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico da revis\u00e3o.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Necess\u00e1rio ser verdadeiro, as revis\u00f5es n\u00e3o suportam lixeira.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp\/v2\/navigation\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O ID do item ascendente ao salvamento autom\u00e1tico.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST"],"args":{"parent":{"description":"O ID do item ascendente ao salvamento autom\u00e1tico.","type":"integer","required":false},"date":{"description":"Data da publica\u00e7\u00e3o do post, no fuso hor\u00e1rio do site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data que o post foi publicado, em GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Um identificador alfanum\u00e9rico para o post.","type":"string","required":false},"status":{"description":"Um nome de status para o post.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Uma senha para proteger o acesso ao conte\u00fado e resumo.","type":"string","required":false},"title":{"description":"O t\u00edtulo para o post.","type":"object","properties":{"raw":{"description":"T\u00edtulo para o post, como existe no banco de dados.","type":"string","context":["edit","embed"]},"rendered":{"description":"T\u00edtulo para o post em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"O conte\u00fado para o post.","type":"object","properties":{"raw":{"description":"Conte\u00fado para o post, como ele existe no banco de dados.","type":"string","context":["edit","embed"]},"rendered":{"description":"Conte\u00fado HTML do post, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"Vers\u00e3o do formato do conte\u00fado do bloco usado pelo post.","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"Se o conte\u00fado \u00e9 protegido por senha.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"O arquivo do tema usado para exibir o post.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O ID do item ascendente ao salvamento autom\u00e1tico.","type":"integer","required":false},"id":{"description":"O ID do salvamento autom\u00e1tico.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp\/v2\/font-families":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"exclude":{"description":"Garantir que o resultado exclua IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar resultados para IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Como interpretar o campo de pesquisa.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Deslocar o resultado para um n\u00famero especifico de itens.","type":"integer","required":false},"order":{"description":"Ordenar atributos de forma ascendente ou descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar cole\u00e7\u00e3o pelo atributo do post.","type":"string","default":"id","enum":["id","include"],"required":false},"slug":{"description":"Limitar resultados de posts definidos por um ou mais slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST"],"args":{"theme_json_version":{"description":"Vers\u00e3o do schema do theme.json utilizado para as configura\u00e7\u00f5es de tipografia.","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_family_settings":{"description":"declara\u00e7\u00e3o font-family no formato para o theme.json, codificado como uma string.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wp\/v2\/font-families"}]}},"\/wp\/v2\/font-families\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identificador \u00fanico para o post.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identificador \u00fanico para o post.","type":"integer","required":false},"theme_json_version":{"description":"Vers\u00e3o do schema do theme.json utilizado para as configura\u00e7\u00f5es de tipografia.","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_family_settings":{"description":"declara\u00e7\u00e3o font-family no formato para o theme.json, codificado como uma string.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identificador \u00fanico para o post.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ignorar ou n\u00e3o o envio para a lixeira e for\u00e7ar a exclus\u00e3o.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp\/v2\/font-families\/(?P<font_family_id>[\\d]+)\/font-faces":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"font_family_id":{"description":"O ID para a fam\u00edlia de fontes ascendente do tipo de fonte.","type":"integer","required":true},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"exclude":{"description":"Garantir que o resultado exclua IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar resultados para IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Como interpretar o campo de pesquisa.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Deslocar o resultado para um n\u00famero especifico de itens.","type":"integer","required":false},"order":{"description":"Ordenar atributos de forma ascendente ou descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar cole\u00e7\u00e3o pelo atributo do post.","type":"string","default":"id","enum":["id","include"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST"],"args":{"font_family_id":{"description":"O ID para a fam\u00edlia de fontes ascendente do tipo de fonte.","type":"integer","required":true},"theme_json_version":{"description":"Vers\u00e3o do schema do theme.json utilizado para as configura\u00e7\u00f5es de tipografia.","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_face_settings":{"description":"declara\u00e7\u00e3o font-face no formato para o theme.json, codificado como uma string.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp\/v2\/font-families\/(?P<font_family_id>[\\d]+)\/font-faces\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"font_family_id":{"description":"O ID para a fam\u00edlia de fontes ascendente do tipo de fonte.","type":"integer","required":true},"id":{"description":"Identificador \u00fanico para o tipo de fonte.","type":"integer","required":true},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["DELETE"],"args":{"font_family_id":{"description":"O ID para a fam\u00edlia de fontes ascendente do tipo de fonte.","type":"integer","required":true},"id":{"description":"Identificador \u00fanico para o tipo de fonte.","type":"integer","required":true},"force":{"type":"boolean","default":false,"description":"Ignorar ou n\u00e3o o envio para a lixeira e for\u00e7ar a exclus\u00e3o.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp\/v2\/elementor_library":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados para aqueles que combinam com um texto.","type":"string","required":false},"after":{"description":"Limitar respostas a posts publicados depois de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limitar respostas a posts modificados depois de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Limitar resultados a posts atribu\u00eddos a autores espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Garantir que o resultado exclui posts atribu\u00eddos a autores espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limitar respostas a posts publicados antes de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limitar respostas a posts modificados antes de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Garantir que o resultado exclua IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar resultados para IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Como interpretar o campo de pesquisa.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Deslocar o resultado para um n\u00famero especifico de itens.","type":"integer","required":false},"order":{"description":"Ordenar atributos de forma ascendente ou descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar cole\u00e7\u00e3o pelo atributo do post.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array de nomes de colunas para serem pesquisadas.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limitar resultados de posts definidos por um ou mais slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limitar resultados de posts atribu\u00eddo por um ou mais status.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Data da publica\u00e7\u00e3o do post, no fuso hor\u00e1rio do site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data que o post foi publicado, em GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Um identificador alfanum\u00e9rico para o post.","type":"string","required":false},"status":{"description":"Um nome de status para o post.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Uma senha para proteger o acesso ao conte\u00fado e resumo.","type":"string","required":false},"title":{"description":"O t\u00edtulo para o post.","type":"object","properties":{"raw":{"description":"T\u00edtulo para o post, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo para o post em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"O ID do autor para o post.","type":"integer","required":false},"featured_media":{"description":"O ID da imagem destacada para o post.","type":"integer","required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"_elementor_edit_mode":{"type":"string","title":"Elementor edit mode","description":"Elementor edit mode, `builder` is required for Elementor editing","default":"","enum":["","builder"],"context":["edit"]},"_elementor_template_type":{"type":"string","title":"Elementor template type","description":"Elementor document type","default":"","enum":["post","wp-post","wp-page","kit","not-supported","page","section","landing-page","cloud-template-preview","elementor_component","widget","popup","header","footer","single","single-post","single-page","archive","search-results","error-404","code_snippet","loop-item",""],"context":["edit"]},"_elementor_data":{"type":"string","title":"Elementor data","description":"Elementor JSON as a string","default":"","context":["edit"]},"_elementor_page_settings":{"type":"object","title":"Elementor page settings","description":"Elementor page level settings","default":"{}","properties":{"hide_title":{"type":"string","enum":["yes","no"],"default":""}},"additionalProperties":true,"context":["edit"]},"_elementor_conditions":{"type":"array","title":"","description":"Elementor conditions","default":[],"additionalProperties":true,"context":["edit"]}},"required":false},"template":{"description":"O arquivo do tema usado para exibir o post.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wp\/v2\/elementor_library"}]}},"\/wp\/v2\/elementor_library\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o post.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"A senha para o post se este for protegido por senha.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o post.","type":"integer","required":false},"date":{"description":"Data da publica\u00e7\u00e3o do post, no fuso hor\u00e1rio do site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data que o post foi publicado, em GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Um identificador alfanum\u00e9rico para o post.","type":"string","required":false},"status":{"description":"Um nome de status para o post.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Uma senha para proteger o acesso ao conte\u00fado e resumo.","type":"string","required":false},"title":{"description":"O t\u00edtulo para o post.","type":"object","properties":{"raw":{"description":"T\u00edtulo para o post, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo para o post em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"O ID do autor para o post.","type":"integer","required":false},"featured_media":{"description":"O ID da imagem destacada para o post.","type":"integer","required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"_elementor_edit_mode":{"type":"string","title":"Elementor edit mode","description":"Elementor edit mode, `builder` is required for Elementor editing","default":"","enum":["","builder"],"context":["edit"]},"_elementor_template_type":{"type":"string","title":"Elementor template type","description":"Elementor document type","default":"","enum":["post","wp-post","wp-page","kit","not-supported","page","section","landing-page","cloud-template-preview","elementor_component","widget","popup","header","footer","single","single-post","single-page","archive","search-results","error-404","code_snippet","loop-item",""],"context":["edit"]},"_elementor_data":{"type":"string","title":"Elementor data","description":"Elementor JSON as a string","default":"","context":["edit"]},"_elementor_page_settings":{"type":"object","title":"Elementor page settings","description":"Elementor page level settings","default":"{}","properties":{"hide_title":{"type":"string","enum":["yes","no"],"default":""}},"additionalProperties":true,"context":["edit"]},"_elementor_conditions":{"type":"array","title":"","description":"Elementor conditions","default":[],"additionalProperties":true,"context":["edit"]}},"required":false},"template":{"description":"O arquivo do tema usado para exibir o post.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o post.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ignorar ou n\u00e3o o envio para a lixeira e for\u00e7ar a exclus\u00e3o.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp\/v2\/elementor_library\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O ID do item ascendente \u00e0 revis\u00e3o.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados para aqueles que combinam com um texto.","type":"string","required":false},"exclude":{"description":"Garantir que o resultado exclua IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar resultados para IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Deslocar o resultado para um n\u00famero especifico de itens.","type":"integer","required":false},"order":{"description":"Ordenar atributos de forma ascendente ou descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar cole\u00e7\u00e3o pelo atributo do objeto.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp\/v2\/elementor_library\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O ID do item ascendente \u00e0 revis\u00e3o.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico da revis\u00e3o.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"O ID do item ascendente \u00e0 revis\u00e3o.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico da revis\u00e3o.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Necess\u00e1rio ser verdadeiro, as revis\u00f5es n\u00e3o suportam lixeira.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp\/v2\/elementor_snippet":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados para aqueles que combinam com um texto.","type":"string","required":false},"after":{"description":"Limitar respostas a posts publicados depois de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limitar respostas a posts modificados depois de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Limitar resultados a posts atribu\u00eddos a autores espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Garantir que o resultado exclui posts atribu\u00eddos a autores espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limitar respostas a posts publicados antes de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limitar respostas a posts modificados antes de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Garantir que o resultado exclua IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar resultados para IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Como interpretar o campo de pesquisa.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Deslocar o resultado para um n\u00famero especifico de itens.","type":"integer","required":false},"order":{"description":"Ordenar atributos de forma ascendente ou descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar cole\u00e7\u00e3o pelo atributo do post.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array de nomes de colunas para serem pesquisadas.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limitar resultados de posts definidos por um ou mais slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limitar resultados de posts atribu\u00eddo por um ou mais status.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Data da publica\u00e7\u00e3o do post, no fuso hor\u00e1rio do site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data que o post foi publicado, em GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Um identificador alfanum\u00e9rico para o post.","type":"string","required":false},"status":{"description":"Um nome de status para o post.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Uma senha para proteger o acesso ao conte\u00fado e resumo.","type":"string","required":false},"title":{"description":"O t\u00edtulo para o post.","type":"object","properties":{"raw":{"description":"T\u00edtulo para o post, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo para o post em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"O ID do autor para o post.","type":"integer","required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"_elementor_location":{"type":"string","title":"","description":"","default":"elementor_head","enum":["elementor_head","elementor_body_start","elementor_body_end"]},"_elementor_priority":{"type":"integer","title":"","description":"","default":1},"_elementor_code":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"O arquivo do tema usado para exibir o post.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wp\/v2\/elementor_snippet"}]}},"\/wp\/v2\/elementor_snippet\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o post.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"A senha para o post se este for protegido por senha.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o post.","type":"integer","required":false},"date":{"description":"Data da publica\u00e7\u00e3o do post, no fuso hor\u00e1rio do site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data que o post foi publicado, em GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Um identificador alfanum\u00e9rico para o post.","type":"string","required":false},"status":{"description":"Um nome de status para o post.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Uma senha para proteger o acesso ao conte\u00fado e resumo.","type":"string","required":false},"title":{"description":"O t\u00edtulo para o post.","type":"object","properties":{"raw":{"description":"T\u00edtulo para o post, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo para o post em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"O ID do autor para o post.","type":"integer","required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"_elementor_location":{"type":"string","title":"","description":"","default":"elementor_head","enum":["elementor_head","elementor_body_start","elementor_body_end"]},"_elementor_priority":{"type":"integer","title":"","description":"","default":1},"_elementor_code":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"O arquivo do tema usado para exibir o post.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o post.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ignorar ou n\u00e3o o envio para a lixeira e for\u00e7ar a exclus\u00e3o.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp\/v2\/elementskit-content":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados para aqueles que combinam com um texto.","type":"string","required":false},"after":{"description":"Limitar respostas a posts publicados depois de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limitar respostas a posts modificados depois de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limitar respostas a posts publicados antes de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limitar respostas a posts modificados antes de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Garantir que o resultado exclua IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar resultados para IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Como interpretar o campo de pesquisa.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Deslocar o resultado para um n\u00famero especifico de itens.","type":"integer","required":false},"order":{"description":"Ordenar atributos de forma ascendente ou descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar cole\u00e7\u00e3o pelo atributo do post.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"parent":{"description":"Limitar resultados para itens cujos ascendentes t\u00eam determinados IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limitar resultados para todos os itens, exceto aqueles de um ID de ascendente em particular.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_columns":{"default":[],"description":"Array de nomes de colunas para serem pesquisadas.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limitar resultados de posts definidos por um ou mais slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limitar resultados de posts atribu\u00eddo por um ou mais status.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Data da publica\u00e7\u00e3o do post, no fuso hor\u00e1rio do site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data que o post foi publicado, em GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Um identificador alfanum\u00e9rico para o post.","type":"string","required":false},"status":{"description":"Um nome de status para o post.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Uma senha para proteger o acesso ao conte\u00fado e resumo.","type":"string","required":false},"parent":{"description":"O ID do ascendente para o post.","type":"integer","required":false},"title":{"description":"O t\u00edtulo para o post.","type":"object","properties":{"raw":{"description":"T\u00edtulo para o post, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo para o post em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"O conte\u00fado para o post.","type":"object","properties":{"raw":{"description":"Conte\u00fado para o post, como ele existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"Conte\u00fado HTML do post, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Vers\u00e3o do formato do conte\u00fado do bloco usado pelo post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Se o conte\u00fado \u00e9 protegido por senha.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"O arquivo do tema usado para exibir o post.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wp\/v2\/elementskit-content"}]}},"\/wp\/v2\/elementskit-content\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o post.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"A senha para o post se este for protegido por senha.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o post.","type":"integer","required":false},"date":{"description":"Data da publica\u00e7\u00e3o do post, no fuso hor\u00e1rio do site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data que o post foi publicado, em GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Um identificador alfanum\u00e9rico para o post.","type":"string","required":false},"status":{"description":"Um nome de status para o post.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Uma senha para proteger o acesso ao conte\u00fado e resumo.","type":"string","required":false},"parent":{"description":"O ID do ascendente para o post.","type":"integer","required":false},"title":{"description":"O t\u00edtulo para o post.","type":"object","properties":{"raw":{"description":"T\u00edtulo para o post, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo para o post em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"O conte\u00fado para o post.","type":"object","properties":{"raw":{"description":"Conte\u00fado para o post, como ele existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"Conte\u00fado HTML do post, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Vers\u00e3o do formato do conte\u00fado do bloco usado pelo post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Se o conte\u00fado \u00e9 protegido por senha.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"O arquivo do tema usado para exibir o post.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o post.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ignorar ou n\u00e3o o envio para a lixeira e for\u00e7ar a exclus\u00e3o.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp\/v2\/elementskit-content\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O ID do item ascendente \u00e0 revis\u00e3o.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados para aqueles que combinam com um texto.","type":"string","required":false},"exclude":{"description":"Garantir que o resultado exclua IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar resultados para IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Deslocar o resultado para um n\u00famero especifico de itens.","type":"integer","required":false},"order":{"description":"Ordenar atributos de forma ascendente ou descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar cole\u00e7\u00e3o pelo atributo do objeto.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp\/v2\/elementskit-content\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O ID do item ascendente \u00e0 revis\u00e3o.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico da revis\u00e3o.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"O ID do item ascendente \u00e0 revis\u00e3o.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico da revis\u00e3o.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Necess\u00e1rio ser verdadeiro, as revis\u00f5es n\u00e3o suportam lixeira.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp\/v2\/elementskit-content\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O ID do item ascendente ao salvamento autom\u00e1tico.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST"],"args":{"parent":{"description":"O ID do ascendente para o post.","type":"integer","required":false},"date":{"description":"Data da publica\u00e7\u00e3o do post, no fuso hor\u00e1rio do site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data que o post foi publicado, em GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Um identificador alfanum\u00e9rico para o post.","type":"string","required":false},"status":{"description":"Um nome de status para o post.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Uma senha para proteger o acesso ao conte\u00fado e resumo.","type":"string","required":false},"title":{"description":"O t\u00edtulo para o post.","type":"object","properties":{"raw":{"description":"T\u00edtulo para o post, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo para o post em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"O conte\u00fado para o post.","type":"object","properties":{"raw":{"description":"Conte\u00fado para o post, como ele existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"Conte\u00fado HTML do post, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Vers\u00e3o do formato do conte\u00fado do bloco usado pelo post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Se o conte\u00fado \u00e9 protegido por senha.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"O arquivo do tema usado para exibir o post.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp\/v2\/elementskit-content\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O ID do item ascendente ao salvamento autom\u00e1tico.","type":"integer","required":false},"id":{"description":"O ID do salvamento autom\u00e1tico.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp\/v2\/elementskit-template":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados para aqueles que combinam com um texto.","type":"string","required":false},"after":{"description":"Limitar respostas a posts publicados depois de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limitar respostas a posts modificados depois de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limitar respostas a posts publicados antes de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limitar respostas a posts modificados antes de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Garantir que o resultado exclua IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar resultados para IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Como interpretar o campo de pesquisa.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Deslocar o resultado para um n\u00famero especifico de itens.","type":"integer","required":false},"order":{"description":"Ordenar atributos de forma ascendente ou descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar cole\u00e7\u00e3o pelo atributo do post.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array de nomes de colunas para serem pesquisadas.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limitar resultados de posts definidos por um ou mais slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limitar resultados de posts atribu\u00eddo por um ou mais status.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Data da publica\u00e7\u00e3o do post, no fuso hor\u00e1rio do site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data que o post foi publicado, em GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Um identificador alfanum\u00e9rico para o post.","type":"string","required":false},"status":{"description":"Um nome de status para o post.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Uma senha para proteger o acesso ao conte\u00fado e resumo.","type":"string","required":false},"title":{"description":"O t\u00edtulo para o post.","type":"object","properties":{"raw":{"description":"T\u00edtulo para o post, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo para o post em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"O ID da imagem destacada para o post.","type":"integer","required":false},"template":{"description":"O arquivo do tema usado para exibir o post.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wp\/v2\/elementskit-template"}]}},"\/wp\/v2\/elementskit-template\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o post.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"A senha para o post se este for protegido por senha.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o post.","type":"integer","required":false},"date":{"description":"Data da publica\u00e7\u00e3o do post, no fuso hor\u00e1rio do site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data que o post foi publicado, em GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Um identificador alfanum\u00e9rico para o post.","type":"string","required":false},"status":{"description":"Um nome de status para o post.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Uma senha para proteger o acesso ao conte\u00fado e resumo.","type":"string","required":false},"title":{"description":"O t\u00edtulo para o post.","type":"object","properties":{"raw":{"description":"T\u00edtulo para o post, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo para o post em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"O ID da imagem destacada para o post.","type":"integer","required":false},"template":{"description":"O arquivo do tema usado para exibir o post.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o post.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ignorar ou n\u00e3o o envio para a lixeira e for\u00e7ar a exclus\u00e3o.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp\/v2\/elementskit-template\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O ID do item ascendente \u00e0 revis\u00e3o.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados para aqueles que combinam com um texto.","type":"string","required":false},"exclude":{"description":"Garantir que o resultado exclua IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar resultados para IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Deslocar o resultado para um n\u00famero especifico de itens.","type":"integer","required":false},"order":{"description":"Ordenar atributos de forma ascendente ou descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar cole\u00e7\u00e3o pelo atributo do objeto.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp\/v2\/elementskit-template\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O ID do item ascendente \u00e0 revis\u00e3o.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico da revis\u00e3o.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"O ID do item ascendente \u00e0 revis\u00e3o.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico da revis\u00e3o.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Necess\u00e1rio ser verdadeiro, as revis\u00f5es n\u00e3o suportam lixeira.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp\/v2\/templately_library":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados para aqueles que combinam com um texto.","type":"string","required":false},"after":{"description":"Limitar respostas a posts publicados depois de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limitar respostas a posts modificados depois de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Limitar resultados a posts atribu\u00eddos a autores espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Garantir que o resultado exclui posts atribu\u00eddos a autores espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limitar respostas a posts publicados antes de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limitar respostas a posts modificados antes de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Garantir que o resultado exclua IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar resultados para IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Como interpretar o campo de pesquisa.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Deslocar o resultado para um n\u00famero especifico de itens.","type":"integer","required":false},"order":{"description":"Ordenar atributos de forma ascendente ou descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar cole\u00e7\u00e3o pelo atributo do post.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array de nomes de colunas para serem pesquisadas.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limitar resultados de posts definidos por um ou mais slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limitar resultados de posts atribu\u00eddo por um ou mais status.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Data da publica\u00e7\u00e3o do post, no fuso hor\u00e1rio do site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data que o post foi publicado, em GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Um identificador alfanum\u00e9rico para o post.","type":"string","required":false},"status":{"description":"Um nome de status para o post.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Uma senha para proteger o acesso ao conte\u00fado e resumo.","type":"string","required":false},"title":{"description":"O t\u00edtulo para o post.","type":"object","properties":{"raw":{"description":"T\u00edtulo para o post, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo para o post em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"O conte\u00fado para o post.","type":"object","properties":{"raw":{"description":"Conte\u00fado para o post, como ele existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"Conte\u00fado HTML do post, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Vers\u00e3o do formato do conte\u00fado do bloco usado pelo post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Se o conte\u00fado \u00e9 protegido por senha.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"O ID do autor para o post.","type":"integer","required":false},"featured_media":{"description":"O ID da imagem destacada para o post.","type":"integer","required":false},"template":{"description":"O arquivo do tema usado para exibir o post.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wp\/v2\/templately_library"}]}},"\/wp\/v2\/templately_library\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o post.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"A senha para o post se este for protegido por senha.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o post.","type":"integer","required":false},"date":{"description":"Data da publica\u00e7\u00e3o do post, no fuso hor\u00e1rio do site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data que o post foi publicado, em GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Um identificador alfanum\u00e9rico para o post.","type":"string","required":false},"status":{"description":"Um nome de status para o post.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Uma senha para proteger o acesso ao conte\u00fado e resumo.","type":"string","required":false},"title":{"description":"O t\u00edtulo para o post.","type":"object","properties":{"raw":{"description":"T\u00edtulo para o post, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo para o post em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"O conte\u00fado para o post.","type":"object","properties":{"raw":{"description":"Conte\u00fado para o post, como ele existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"Conte\u00fado HTML do post, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Vers\u00e3o do formato do conte\u00fado do bloco usado pelo post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Se o conte\u00fado \u00e9 protegido por senha.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"O ID do autor para o post.","type":"integer","required":false},"featured_media":{"description":"O ID da imagem destacada para o post.","type":"integer","required":false},"template":{"description":"O arquivo do tema usado para exibir o post.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o post.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ignorar ou n\u00e3o o envio para a lixeira e for\u00e7ar a exclus\u00e3o.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp\/v2\/templately_library\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O ID do item ascendente \u00e0 revis\u00e3o.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados para aqueles que combinam com um texto.","type":"string","required":false},"exclude":{"description":"Garantir que o resultado exclua IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar resultados para IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Deslocar o resultado para um n\u00famero especifico de itens.","type":"integer","required":false},"order":{"description":"Ordenar atributos de forma ascendente ou descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar cole\u00e7\u00e3o pelo atributo do objeto.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp\/v2\/templately_library\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O ID do item ascendente \u00e0 revis\u00e3o.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico da revis\u00e3o.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"O ID do item ascendente \u00e0 revis\u00e3o.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico da revis\u00e3o.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Necess\u00e1rio ser verdadeiro, as revis\u00f5es n\u00e3o suportam lixeira.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp\/v2\/templately_library\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O ID do item ascendente ao salvamento autom\u00e1tico.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST"],"args":{"parent":{"description":"O ID do item ascendente ao salvamento autom\u00e1tico.","type":"integer","required":false},"date":{"description":"Data da publica\u00e7\u00e3o do post, no fuso hor\u00e1rio do site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data que o post foi publicado, em GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Um identificador alfanum\u00e9rico para o post.","type":"string","required":false},"status":{"description":"Um nome de status para o post.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Uma senha para proteger o acesso ao conte\u00fado e resumo.","type":"string","required":false},"title":{"description":"O t\u00edtulo para o post.","type":"object","properties":{"raw":{"description":"T\u00edtulo para o post, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo para o post em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"O conte\u00fado para o post.","type":"object","properties":{"raw":{"description":"Conte\u00fado para o post, como ele existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"Conte\u00fado HTML do post, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Vers\u00e3o do formato do conte\u00fado do bloco usado pelo post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Se o conte\u00fado \u00e9 protegido por senha.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"O ID do autor para o post.","type":"integer","required":false},"featured_media":{"description":"O ID da imagem destacada para o post.","type":"integer","required":false},"template":{"description":"O arquivo do tema usado para exibir o post.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp\/v2\/templately_library\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O ID do item ascendente ao salvamento autom\u00e1tico.","type":"integer","required":false},"id":{"description":"O ID do salvamento autom\u00e1tico.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp\/v2\/types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wp\/v2\/types"}]}},"\/wp\/v2\/types\/(?P<type>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"type":{"description":"Um identificador alfanum\u00e9rico para o tipo de post.","type":"string","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp\/v2\/statuses":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wp\/v2\/statuses"}]}},"\/wp\/v2\/statuses\/(?P<status>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"status":{"description":"Um identificador alfanum\u00e9rico para o status.","type":"string","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp\/v2\/taxonomies":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"type":{"description":"Limitar resultados para taxonomias associadas com um tipo especifico de post.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wp\/v2\/taxonomies"}]}},"\/wp\/v2\/taxonomies\/(?P<taxonomy>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"taxonomy":{"description":"Um identificador alfanum\u00e9rico para a taxonomia.","type":"string","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp\/v2\/categories":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados para aqueles que combinam com um texto.","type":"string","required":false},"exclude":{"description":"Garantir que o resultado exclua IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar resultados para IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"Ordenar atributos de forma ascendente ou descendente.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar cole\u00e7\u00e3o por termo de atributo.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Se deseja ocultar termos n\u00e3o atribu\u00eddos a posts.","type":"boolean","default":false,"required":false},"parent":{"description":"Limitar resultados de termos atribu\u00eddos a um ascendente espec\u00edfico.","type":"integer","required":false},"post":{"description":"Limitar resultados de termos atribu\u00eddos a um post espec\u00edfico.","type":"integer","default":null,"required":false},"slug":{"description":"Limitar resultados a termos com um ou mais slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"Descri\u00e7\u00e3o HTML do recurso.","type":"string","required":false},"name":{"description":"T\u00edtulo em HTML para o termo.","type":"string","required":true},"slug":{"description":"Um identificador alfanum\u00e9rico para o termo \u00fanico do seu tipo.","type":"string","required":false},"parent":{"description":"ID do termo ascendente.","type":"integer","required":false},"meta":{"description":"Campos meta.","type":"object","properties":[],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wp\/v2\/categories"}]}},"\/wp\/v2\/categories\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o termo.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o termo.","type":"integer","required":false},"description":{"description":"Descri\u00e7\u00e3o HTML do recurso.","type":"string","required":false},"name":{"description":"T\u00edtulo em HTML para o termo.","type":"string","required":false},"slug":{"description":"Um identificador alfanum\u00e9rico para o termo \u00fanico do seu tipo.","type":"string","required":false},"parent":{"description":"ID do termo ascendente.","type":"integer","required":false},"meta":{"description":"Campos meta.","type":"object","properties":[],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o termo.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Necess\u00e1rio ser verdadeiro, os termos n\u00e3o suportam lixeira.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp\/v2\/tags":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados para aqueles que combinam com um texto.","type":"string","required":false},"exclude":{"description":"Garantir que o resultado exclua IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar resultados para IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Deslocar o resultado para um n\u00famero especifico de itens.","type":"integer","required":false},"order":{"description":"Ordenar atributos de forma ascendente ou descendente.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar cole\u00e7\u00e3o por termo de atributo.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Se deseja ocultar termos n\u00e3o atribu\u00eddos a posts.","type":"boolean","default":false,"required":false},"post":{"description":"Limitar resultados de termos atribu\u00eddos a um post espec\u00edfico.","type":"integer","default":null,"required":false},"slug":{"description":"Limitar resultados a termos com um ou mais slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"Descri\u00e7\u00e3o HTML do recurso.","type":"string","required":false},"name":{"description":"T\u00edtulo em HTML para o termo.","type":"string","required":true},"slug":{"description":"Um identificador alfanum\u00e9rico para o termo \u00fanico do seu tipo.","type":"string","required":false},"meta":{"description":"Campos meta.","type":"object","properties":[],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wp\/v2\/tags"}]}},"\/wp\/v2\/tags\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o termo.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o termo.","type":"integer","required":false},"description":{"description":"Descri\u00e7\u00e3o HTML do recurso.","type":"string","required":false},"name":{"description":"T\u00edtulo em HTML para o termo.","type":"string","required":false},"slug":{"description":"Um identificador alfanum\u00e9rico para o termo \u00fanico do seu tipo.","type":"string","required":false},"meta":{"description":"Campos meta.","type":"object","properties":[],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o termo.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Necess\u00e1rio ser verdadeiro, os termos n\u00e3o suportam lixeira.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp\/v2\/menus":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados para aqueles que combinam com um texto.","type":"string","required":false},"exclude":{"description":"Garantir que o resultado exclua IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar resultados para IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Deslocar o resultado para um n\u00famero especifico de itens.","type":"integer","required":false},"order":{"description":"Ordenar atributos de forma ascendente ou descendente.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar cole\u00e7\u00e3o por termo de atributo.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Se deseja ocultar termos n\u00e3o atribu\u00eddos a posts.","type":"boolean","default":false,"required":false},"post":{"description":"Limitar resultados de termos atribu\u00eddos a um post espec\u00edfico.","type":"integer","default":null,"required":false},"slug":{"description":"Limitar resultados a termos com um ou mais slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"Descri\u00e7\u00e3o HTML do recurso.","type":"string","required":false},"name":{"description":"T\u00edtulo em HTML para o termo.","type":"string","required":true},"slug":{"description":"Um identificador alfanum\u00e9rico para o termo \u00fanico do seu tipo.","type":"string","required":false},"meta":{"description":"Campos meta.","type":"object","properties":[],"required":false},"locations":{"description":"As localiza\u00e7\u00f5es atribu\u00eddas ao menu.","type":"array","items":{"type":"string"},"required":false},"auto_add":{"description":"Se as p\u00e1ginas de n\u00edvel superior ser\u00e3o adicionadas automaticamente a este menu ou n\u00e3o.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wp\/v2\/menus"}]}},"\/wp\/v2\/menus\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o termo.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o termo.","type":"integer","required":false},"description":{"description":"Descri\u00e7\u00e3o HTML do recurso.","type":"string","required":false},"name":{"description":"T\u00edtulo em HTML para o termo.","type":"string","required":false},"slug":{"description":"Um identificador alfanum\u00e9rico para o termo \u00fanico do seu tipo.","type":"string","required":false},"meta":{"description":"Campos meta.","type":"object","properties":[],"required":false},"locations":{"description":"As localiza\u00e7\u00f5es atribu\u00eddas ao menu.","type":"array","items":{"type":"string"},"required":false},"auto_add":{"description":"Se as p\u00e1ginas de n\u00edvel superior ser\u00e3o adicionadas automaticamente a este menu ou n\u00e3o.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o termo.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Necess\u00e1rio ser verdadeiro, os termos n\u00e3o suportam lixeira.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp\/v2\/wp_pattern_category":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados para aqueles que combinam com um texto.","type":"string","required":false},"exclude":{"description":"Garantir que o resultado exclua IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar resultados para IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Deslocar o resultado para um n\u00famero especifico de itens.","type":"integer","required":false},"order":{"description":"Ordenar atributos de forma ascendente ou descendente.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar cole\u00e7\u00e3o por termo de atributo.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Se deseja ocultar termos n\u00e3o atribu\u00eddos a posts.","type":"boolean","default":false,"required":false},"post":{"description":"Limitar resultados de termos atribu\u00eddos a um post espec\u00edfico.","type":"integer","default":null,"required":false},"slug":{"description":"Limitar resultados a termos com um ou mais slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"Descri\u00e7\u00e3o HTML do recurso.","type":"string","required":false},"name":{"description":"T\u00edtulo em HTML para o termo.","type":"string","required":true},"slug":{"description":"Um identificador alfanum\u00e9rico para o termo \u00fanico do seu tipo.","type":"string","required":false},"meta":{"description":"Campos meta.","type":"object","properties":[],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wp\/v2\/wp_pattern_category"}]}},"\/wp\/v2\/wp_pattern_category\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o termo.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o termo.","type":"integer","required":false},"description":{"description":"Descri\u00e7\u00e3o HTML do recurso.","type":"string","required":false},"name":{"description":"T\u00edtulo em HTML para o termo.","type":"string","required":false},"slug":{"description":"Um identificador alfanum\u00e9rico para o termo \u00fanico do seu tipo.","type":"string","required":false},"meta":{"description":"Campos meta.","type":"object","properties":[],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o termo.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Necess\u00e1rio ser verdadeiro, os termos n\u00e3o suportam lixeira.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp\/v2\/qsm_category":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados para aqueles que combinam com um texto.","type":"string","required":false},"exclude":{"description":"Garantir que o resultado exclua IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar resultados para IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"Ordenar atributos de forma ascendente ou descendente.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar cole\u00e7\u00e3o por termo de atributo.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Se deseja ocultar termos n\u00e3o atribu\u00eddos a posts.","type":"boolean","default":false,"required":false},"parent":{"description":"Limitar resultados de termos atribu\u00eddos a um ascendente espec\u00edfico.","type":"integer","required":false},"post":{"description":"Limitar resultados de termos atribu\u00eddos a um post espec\u00edfico.","type":"integer","default":null,"required":false},"slug":{"description":"Limitar resultados a termos com um ou mais slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"Descri\u00e7\u00e3o HTML do recurso.","type":"string","required":false},"name":{"description":"T\u00edtulo em HTML para o termo.","type":"string","required":true},"slug":{"description":"Um identificador alfanum\u00e9rico para o termo \u00fanico do seu tipo.","type":"string","required":false},"parent":{"description":"ID do termo ascendente.","type":"integer","required":false},"meta":{"description":"Campos meta.","type":"object","properties":[],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wp\/v2\/qsm_category"}]}},"\/wp\/v2\/qsm_category\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o termo.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o termo.","type":"integer","required":false},"description":{"description":"Descri\u00e7\u00e3o HTML do recurso.","type":"string","required":false},"name":{"description":"T\u00edtulo em HTML para o termo.","type":"string","required":false},"slug":{"description":"Um identificador alfanum\u00e9rico para o termo \u00fanico do seu tipo.","type":"string","required":false},"parent":{"description":"ID do termo ascendente.","type":"integer","required":false},"meta":{"description":"Campos meta.","type":"object","properties":[],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o termo.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Necess\u00e1rio ser verdadeiro, os termos n\u00e3o suportam lixeira.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp\/v2\/users":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados para aqueles que combinam com um texto.","type":"string","required":false},"exclude":{"description":"Garantir que o resultado exclua IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar resultados para IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Deslocar o resultado para um n\u00famero especifico de itens.","type":"integer","required":false},"order":{"default":"asc","description":"Ordenar atributos de forma ascendente ou descendente.","enum":["asc","desc"],"type":"string","required":false},"orderby":{"default":"name","description":"Ordenar cole\u00e7\u00e3o por atributo do usu\u00e1rio.","enum":["id","include","name","registered_date","slug","include_slugs","email","url"],"type":"string","required":false},"slug":{"description":"Limitar resultados a usu\u00e1rios com um ou mais slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false},"roles":{"description":"Limitar resultados a usu\u00e1rios que tenham pelo menos uma dada fun\u00e7\u00e3o espec\u00edfica. Aceita lista separada por v\u00edrgulas ou uma fun\u00e7\u00e3o apenas.","type":"array","items":{"type":"string"},"required":false},"capabilities":{"description":"Limitar resultados a usu\u00e1rios que tenham pelo menos uma dada capacidade espec\u00edfica. Aceita lista separada por v\u00edrgulas ou uma capacidade apenas.","type":"array","items":{"type":"string"},"required":false},"who":{"description":"Limitar resultados a usu\u00e1rios considerados autores.","type":"string","enum":["authors"],"required":false},"has_published_posts":{"description":"Limitar resultados para usu\u00e1rios que publicaram posts.","type":["boolean","array"],"items":{"type":"string","enum":{"post":"post","page":"page","attachment":"attachment","nav_menu_item":"nav_menu_item","wp_block":"wp_block","wp_template":"wp_template","wp_template_part":"wp_template_part","wp_global_styles":"wp_global_styles","wp_navigation":"wp_navigation","wp_font_family":"wp_font_family","wp_font_face":"wp_font_face","elementor_library":"elementor_library","elementor_snippet":"elementor_snippet","elementskit_content":"elementskit_content","elementskit_template":"elementskit_template","templately_library":"templately_library"}},"required":false},"search_columns":{"default":[],"description":"Array de nomes de colunas para serem pesquisadas.","type":"array","items":{"enum":["email","name","id","username","slug"],"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"username":{"description":"Nome de login para o usu\u00e1rio.","type":"string","required":true},"name":{"description":"Nome de exibi\u00e7\u00e3o para o usu\u00e1rio.","type":"string","required":false},"first_name":{"description":"Nome para o usu\u00e1rio.","type":"string","required":false},"last_name":{"description":"Sobrenome para o usu\u00e1rio.","type":"string","required":false},"email":{"description":"O endere\u00e7o de e-mail para o usu\u00e1rio.","type":"string","format":"email","required":true},"url":{"description":"URL do usu\u00e1rio.","type":"string","format":"uri","required":false},"description":{"description":"Descri\u00e7\u00e3o do usu\u00e1rio.","type":"string","required":false},"locale":{"description":"Localidade para o usu\u00e1rio.","type":"string","enum":["","en_US","es_ES","pt_BR"],"required":false},"nickname":{"description":"O apelido para o usu\u00e1rio.","type":"string","required":false},"slug":{"description":"Um identificador alfanum\u00e9rico para o usu\u00e1rio.","type":"string","required":false},"roles":{"description":"Fun\u00e7\u00f5es atribu\u00eddas ao usu\u00e1rio.","type":"array","items":{"type":"string"},"required":false},"password":{"description":"Senha para o usu\u00e1rio (nunca incluso).","type":"string","required":true},"meta":{"description":"Campos meta.","type":"object","properties":{"persisted_preferences":{"type":"object","title":"","description":"","default":[],"context":["edit"],"properties":{"_modified":{"description":"A data e o hor\u00e1rio que as prefer\u00eancias foram atualizadas.","type":"string","format":"date-time","readonly":false}},"additionalProperties":true}},"required":false},"elementor_introduction":{"description":"Elementor user meta data","type":"object","properties":{"ai_get_started":{"type":"boolean"}},"additionalProperties":true,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wp\/v2\/users"}]}},"\/wp\/v2\/users\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o usu\u00e1rio.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o usu\u00e1rio.","type":"integer","required":false},"username":{"description":"Nome de login para o usu\u00e1rio.","type":"string","required":false},"name":{"description":"Nome de exibi\u00e7\u00e3o para o usu\u00e1rio.","type":"string","required":false},"first_name":{"description":"Nome para o usu\u00e1rio.","type":"string","required":false},"last_name":{"description":"Sobrenome para o usu\u00e1rio.","type":"string","required":false},"email":{"description":"O endere\u00e7o de e-mail para o usu\u00e1rio.","type":"string","format":"email","required":false},"url":{"description":"URL do usu\u00e1rio.","type":"string","format":"uri","required":false},"description":{"description":"Descri\u00e7\u00e3o do usu\u00e1rio.","type":"string","required":false},"locale":{"description":"Localidade para o usu\u00e1rio.","type":"string","enum":["","en_US","es_ES","pt_BR"],"required":false},"nickname":{"description":"O apelido para o usu\u00e1rio.","type":"string","required":false},"slug":{"description":"Um identificador alfanum\u00e9rico para o usu\u00e1rio.","type":"string","required":false},"roles":{"description":"Fun\u00e7\u00f5es atribu\u00eddas ao usu\u00e1rio.","type":"array","items":{"type":"string"},"required":false},"password":{"description":"Senha para o usu\u00e1rio (nunca incluso).","type":"string","required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"persisted_preferences":{"type":"object","title":"","description":"","default":[],"context":["edit"],"properties":{"_modified":{"description":"A data e o hor\u00e1rio que as prefer\u00eancias foram atualizadas.","type":"string","format":"date-time","readonly":false}},"additionalProperties":true}},"required":false},"elementor_introduction":{"description":"Elementor user meta data","type":"object","properties":{"ai_get_started":{"type":"boolean"}},"additionalProperties":true,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o usu\u00e1rio.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Necess\u00e1rio para ser verdadeiro, como usu\u00e1rios n\u00e3o suporta lixeira.","required":false},"reassign":{"type":"integer","description":"Reatribuir os posts e links do usu\u00e1rio exclu\u00eddo para este ID de usu\u00e1rio.","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp\/v2\/users\/me":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"username":{"description":"Nome de login para o usu\u00e1rio.","type":"string","required":false},"name":{"description":"Nome de exibi\u00e7\u00e3o para o usu\u00e1rio.","type":"string","required":false},"first_name":{"description":"Nome para o usu\u00e1rio.","type":"string","required":false},"last_name":{"description":"Sobrenome para o usu\u00e1rio.","type":"string","required":false},"email":{"description":"O endere\u00e7o de e-mail para o usu\u00e1rio.","type":"string","format":"email","required":false},"url":{"description":"URL do usu\u00e1rio.","type":"string","format":"uri","required":false},"description":{"description":"Descri\u00e7\u00e3o do usu\u00e1rio.","type":"string","required":false},"locale":{"description":"Localidade para o usu\u00e1rio.","type":"string","enum":["","en_US","es_ES","pt_BR"],"required":false},"nickname":{"description":"O apelido para o usu\u00e1rio.","type":"string","required":false},"slug":{"description":"Um identificador alfanum\u00e9rico para o usu\u00e1rio.","type":"string","required":false},"roles":{"description":"Fun\u00e7\u00f5es atribu\u00eddas ao usu\u00e1rio.","type":"array","items":{"type":"string"},"required":false},"password":{"description":"Senha para o usu\u00e1rio (nunca incluso).","type":"string","required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"persisted_preferences":{"type":"object","title":"","description":"","default":[],"context":["edit"],"properties":{"_modified":{"description":"A data e o hor\u00e1rio que as prefer\u00eancias foram atualizadas.","type":"string","format":"date-time","readonly":false}},"additionalProperties":true}},"required":false},"elementor_introduction":{"description":"Elementor user meta data","type":"object","properties":{"ai_get_started":{"type":"boolean"}},"additionalProperties":true,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["DELETE"],"args":{"force":{"type":"boolean","default":false,"description":"Necess\u00e1rio para ser verdadeiro, como usu\u00e1rios n\u00e3o suporta lixeira.","required":false},"reassign":{"type":"integer","description":"Reatribuir os posts e links do usu\u00e1rio exclu\u00eddo para este ID de usu\u00e1rio.","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wp\/v2\/users\/me"}]}},"\/wp\/v2\/users\/(?P<user_id>(?:[\\d]+|me))\/application-passwords":{"namespace":"wp\/v2","methods":["GET","POST","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST"],"args":{"app_id":{"description":"Um UUID fornecido pela aplica\u00e7\u00e3o para identific\u00e1-la de forma \u00fanica. Recomenda-se usar o UUID vers\u00e3o 5 com o URL ou namespace DNS.","type":"string","oneOf":[{"type":"string","format":"uuid"},{"type":"string","enum":[""]}],"required":false},"name":{"description":"O nome da senha da aplica\u00e7\u00e3o.","type":"string","minLength":1,"pattern":".*\\S.*","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["DELETE"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp\/v2\/users\/(?P<user_id>(?:[\\d]+|me))\/application-passwords\/introspect":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp\/v2\/users\/(?P<user_id>(?:[\\d]+|me))\/application-passwords\/(?P<uuid>[\\w\\-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"app_id":{"description":"Um UUID fornecido pela aplica\u00e7\u00e3o para identific\u00e1-la de forma \u00fanica. Recomenda-se usar o UUID vers\u00e3o 5 com o URL ou namespace DNS.","type":"string","oneOf":[{"type":"string","format":"uuid"},{"type":"string","enum":[""]}],"required":false},"name":{"description":"O nome da senha da aplica\u00e7\u00e3o.","type":"string","minLength":1,"pattern":".*\\S.*","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["DELETE"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp\/v2\/comments":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados para aqueles que combinam com um texto.","type":"string","required":false},"after":{"description":"Limitar resposta para coment\u00e1rios publicados depois de uma determinada data compat\u00edvel com a norma ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Limitar resultados a coment\u00e1rios atribu\u00eddos a IDs de usu\u00e1rios espec\u00edficos. Requer autoriza\u00e7\u00e3o.","type":"array","items":{"type":"integer"},"required":false},"author_exclude":{"description":"Garantir que resultados excluir\u00e3o coment\u00e1rios atribu\u00eddos a IDs de usu\u00e1rios espec\u00edficos. Requer autoriza\u00e7\u00e3o.","type":"array","items":{"type":"integer"},"required":false},"author_email":{"default":null,"description":"Limitar resultado para e-mails de autores em especifico. Requer autoriza\u00e7\u00e3o.","format":"email","type":"string","required":false},"before":{"description":"Limitar resposta para coment\u00e1rios publicados antes de uma determinada data compat\u00edvel com a norma ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Garantir que o resultado exclua IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar resultados para IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Deslocar o resultado para um n\u00famero especifico de itens.","type":"integer","required":false},"order":{"description":"Ordenar atributos de forma ascendente ou descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar cole\u00e7\u00e3o pelo atributo do coment\u00e1rio.","type":"string","default":"date_gmt","enum":["date","date_gmt","id","include","post","parent","type"],"required":false},"parent":{"default":[],"description":"Limitar resultados para coment\u00e1rios cujos ascendentes t\u00eam determinados IDs.","type":"array","items":{"type":"integer"},"required":false},"parent_exclude":{"default":[],"description":"Garantir que o resultado exclui IDs de ascendentes espec\u00edficos.","type":"array","items":{"type":"integer"},"required":false},"post":{"default":[],"description":"Limitar resultados para coment\u00e1rios atribu\u00eddos para IDs espec\u00edficos de post.","type":"array","items":{"type":"integer"},"required":false},"status":{"default":"approve","description":"Limitar resultados para coment\u00e1rios atribu\u00eddos a um status espec\u00edfico. Necessita autoriza\u00e7\u00e3o.","type":"string","required":false},"type":{"default":"comment","description":"Limitar resultados para coment\u00e1rios atribu\u00eddos a um tipo espec\u00edfico. Necessita autoriza\u00e7\u00e3o.","type":"string","required":false},"password":{"description":"A senha para o post se este for protegido por senha.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST"],"args":{"author":{"description":"O ID do usu\u00e1rio do objeto, se o autor for um usu\u00e1rio.","type":"integer","required":false},"author_email":{"description":"Endere\u00e7o e-mail para o autor do coment\u00e1rio.","type":"string","format":"email","required":false},"author_ip":{"description":"Endere\u00e7o IP para o autor do coment\u00e1rio.","type":"string","format":"ip","required":false},"author_name":{"description":"Nome de exibi\u00e7\u00e3o para o autor do coment\u00e1rio.","type":"string","required":false},"author_url":{"description":"URL para o autor do coment\u00e1rio.","type":"string","format":"uri","required":false},"author_user_agent":{"description":"Agente de usu\u00e1rio para o autor do coment\u00e1rio.","type":"string","required":false},"content":{"description":"O conte\u00fado para o coment\u00e1rio.","type":"object","properties":{"raw":{"description":"Conte\u00fado do coment\u00e1rio, tal como est\u00e1 no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"Conte\u00fado HTML do coment\u00e1rio, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"date":{"description":"Data da publica\u00e7\u00e3o do coment\u00e1rio, no fuso hor\u00e1rio do site.","type":"string","format":"date-time","required":false},"date_gmt":{"description":"Data da publica\u00e7\u00e3o do coment\u00e1rio, em GMT.","type":"string","format":"date-time","required":false},"parent":{"default":0,"description":"O ID do item ascendente ao coment\u00e1rio.","type":"integer","required":false},"post":{"default":0,"description":"O ID para o post associado ao objeto.","type":"integer","required":false},"status":{"description":"Estado do coment\u00e1rio.","type":"string","required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"_wp_note_status":{"type":"string","title":"","description":"Status de resolu\u00e7\u00e3o da nota","default":"","enum":["resolved","reopen"]}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wp\/v2\/comments"}]}},"\/wp\/v2\/comments\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identificador \u00fanico para o coment\u00e1rio.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"A senha do post ascendente ao coment\u00e1rio (se o post for protegido por senha).","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identificador \u00fanico para o coment\u00e1rio.","type":"integer","required":false},"author":{"description":"O ID do usu\u00e1rio do objeto, se o autor for um usu\u00e1rio.","type":"integer","required":false},"author_email":{"description":"Endere\u00e7o e-mail para o autor do coment\u00e1rio.","type":"string","format":"email","required":false},"author_ip":{"description":"Endere\u00e7o IP para o autor do coment\u00e1rio.","type":"string","format":"ip","required":false},"author_name":{"description":"Nome de exibi\u00e7\u00e3o para o autor do coment\u00e1rio.","type":"string","required":false},"author_url":{"description":"URL para o autor do coment\u00e1rio.","type":"string","format":"uri","required":false},"author_user_agent":{"description":"Agente de usu\u00e1rio para o autor do coment\u00e1rio.","type":"string","required":false},"content":{"description":"O conte\u00fado para o coment\u00e1rio.","type":"object","properties":{"raw":{"description":"Conte\u00fado do coment\u00e1rio, tal como est\u00e1 no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"Conte\u00fado HTML do coment\u00e1rio, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"date":{"description":"Data da publica\u00e7\u00e3o do coment\u00e1rio, no fuso hor\u00e1rio do site.","type":"string","format":"date-time","required":false},"date_gmt":{"description":"Data da publica\u00e7\u00e3o do coment\u00e1rio, em GMT.","type":"string","format":"date-time","required":false},"parent":{"description":"O ID do item ascendente ao coment\u00e1rio.","type":"integer","required":false},"post":{"description":"O ID para o post associado ao objeto.","type":"integer","required":false},"status":{"description":"Estado do coment\u00e1rio.","type":"string","required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"_wp_note_status":{"type":"string","title":"","description":"Status de resolu\u00e7\u00e3o da nota","default":"","enum":["resolved","reopen"]}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identificador \u00fanico para o coment\u00e1rio.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ignorar ou n\u00e3o o envio para a lixeira e for\u00e7ar a exclus\u00e3o.","required":false},"password":{"description":"A senha do post ascendente ao coment\u00e1rio (se o post for protegido por senha).","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp\/v2\/search":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados para aqueles que combinam com um texto.","type":"string","required":false},"type":{"default":"post","description":"Limite os resultados aos itens de um tipo de objeto.","type":"string","enum":["post","term","post-format"],"required":false},"subtype":{"default":"any","description":"Limite os resultados a itens de um ou mais subtipos de objeto.","type":"array","items":{"enum":["post","page","elementor_library","elementskit_content","elementskit_template","templately_library","category","post_tag","qsm_category","any"],"type":"string"},"required":false},"exclude":{"description":"Garantir que o resultado exclua IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar resultados para IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wp\/v2\/search"}]}},"\/wp\/v2\/block-renderer\/(?P<name>[a-z0-9-]+\/[a-z0-9-]+)":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET","POST"],"args":{"name":{"description":"Nome registrado exclusivo para o bloco.","type":"string","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["edit"],"default":"view","required":false},"attributes":{"description":"Atributos para o bloco.","type":"object","default":[],"required":false},"post_id":{"description":"ID de contexto do post.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp\/v2\/block-types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"namespace":{"description":"Namespace do bloco.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wp\/v2\/block-types"}]}},"\/wp\/v2\/block-types\/(?P<namespace>[a-zA-Z0-9_-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"namespace":{"description":"Namespace do bloco.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp\/v2\/block-types\/(?P<namespace>[a-zA-Z0-9_-]+)\/(?P<name>[a-zA-Z0-9_-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"name":{"description":"Nome do bloco.","type":"string","required":false},"namespace":{"description":"Namespace do bloco.","type":"string","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp\/v2\/settings":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"title":{"title":"T\u00edtulo","description":"T\u00edtulo do site.","type":"string","required":false},"description":{"title":"Descri\u00e7\u00e3o","description":"Slogan do site.","type":"string","required":false},"url":{"title":"","description":"URL do site.","type":"string","format":"uri","required":false},"email":{"title":"","description":"Este endere\u00e7o \u00e9 utilizado para administra\u00e7\u00e3o, como notifica\u00e7\u00e3o de novo usu\u00e1rio.","type":"string","format":"email","required":false},"timezone":{"title":"","description":"Uma cidade no mesmo fuso hor\u00e1rio que voc\u00ea.","type":"string","required":false},"date_format":{"title":"","description":"Um formato de data para todos os textos.","type":"string","required":false},"time_format":{"title":"","description":"Um formato de hora para todos os textos.","type":"string","required":false},"start_of_week":{"title":"","description":"N\u00famero do dia da semana em que a semana deve iniciar.","type":"integer","required":false},"language":{"title":"","description":"C\u00f3digo de localiza\u00e7\u00e3o do WordPress.","type":"string","required":false},"use_smilies":{"title":"","description":"Converter emoticons como :-) e :-P em gr\u00e1ficos ao exib\u00ed-los.","type":"boolean","required":false},"default_category":{"title":"","description":"Categoria padr\u00e3o para post.","type":"integer","required":false},"default_post_format":{"title":"","description":"Formato de post padr\u00e3o.","type":"string","required":false},"posts_per_page":{"title":"M\u00e1ximo de posts por p\u00e1gina","description":"As p\u00e1ginas do blog mostram no m\u00e1ximo.","type":"integer","required":false},"show_on_front":{"title":"Mostrar na frente","description":"O que exibir na p\u00e1gina inicial","type":"string","required":false},"page_on_front":{"title":"P\u00e1gina frontal","description":"O ID da p\u00e1gina que deve ser exibida na p\u00e1gina inicial","type":"integer","required":false},"page_for_posts":{"title":"","description":"O ID da p\u00e1gina que deve exibir os posts mais recentes","type":"integer","required":false},"default_ping_status":{"title":"","description":"Permitir avisos de links de outros blogs (pingbacks ou trackbacks) em novos artigos.","type":"string","enum":["open","closed"],"required":false},"default_comment_status":{"title":"Permitir coment\u00e1rios em novas publica\u00e7\u00f5es","description":"Permitir que pessoas enviem coment\u00e1rios em novos posts.","type":"string","enum":["open","closed"],"required":false},"site_logo":{"title":"Logo","description":"Logo do site.","type":"integer","required":false},"site_icon":{"title":"\u00cdcone","description":"\u00cdcone do site.","type":"integer","required":false},"elementor_one_welcome_screen_completed":{"title":"","description":"Elementor One Welcome Screen Completed","type":"boolean","required":false},"elementor_one_dismiss_connect_alert":{"title":"","description":"Elementor One Dismiss Connect Alert","type":"boolean","required":false},"elementor_one_editor_update_notification_dismissed":{"title":"","description":"Elementor One Dismiss Editor Update Notification","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wp\/v2\/settings"}]}},"\/wp\/v2\/themes":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"status":{"description":"Limitar resultados a temas com um ou mais status atribu\u00eddos.","type":"array","items":{"enum":["active","inactive"],"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wp\/v2\/themes"}]}},"\/wp\/v2\/themes\/(?P<stylesheet>[^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"stylesheet":{"description":"A folha de estilos do tema. Isso identifica exclusivamente o tema.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp\/v2\/plugins":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"search":{"description":"Limitar resultados para aqueles que combinam com um texto.","type":"string","required":false},"status":{"description":"Limita os resultados a plugins com o status especificado.","type":"array","items":{"type":"string","enum":["inactive","active"]},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST"],"args":{"slug":{"type":"string","description":"slug do diret\u00f3rio de plugins do WordPress.org","pattern":"[\\w\\-]+","required":true},"status":{"description":"O status de ativa\u00e7\u00e3o do plugin","type":"string","enum":["inactive","active"],"default":"inactive","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wp\/v2\/plugins"}]}},"\/wp\/v2\/plugins\/(?P<plugin>[^.\\\/]+(?:\\\/[^.\\\/]+)?)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"plugin":{"type":"string","pattern":"[^.\\\/]+(?:\\\/[^.\\\/]+)?","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"plugin":{"type":"string","pattern":"[^.\\\/]+(?:\\\/[^.\\\/]+)?","required":false},"status":{"description":"O status de ativa\u00e7\u00e3o do plugin","type":"string","enum":["inactive","active"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["DELETE"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"plugin":{"type":"string","pattern":"[^.\\\/]+(?:\\\/[^.\\\/]+)?","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp\/v2\/sidebars":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wp\/v2\/sidebars"}]}},"\/wp\/v2\/sidebars\/(?P<id>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"O ID de uma barra lateral registrada","type":"string","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"widgets":{"description":"Widgets aninhados.","type":"array","items":{"type":["object","string"]},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp\/v2\/widget-types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wp\/v2\/widget-types"}]}},"\/wp\/v2\/widget-types\/(?P<id>[a-zA-Z0-9_-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"O id do tipo de widget.","type":"string","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp\/v2\/widget-types\/(?P<id>[a-zA-Z0-9_-]+)\/encode":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"O id do tipo de widget.","type":"string","required":true},"instance":{"description":"Configura\u00e7\u00f5es da inst\u00e2ncia atual do widget.","type":"object","required":false},"form_data":{"description":"Configura\u00e7\u00f5es da inst\u00e2ncia serializados","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp\/v2\/widget-types\/(?P<id>[a-zA-Z0-9_-]+)\/render":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"O id do tipo de widget.","type":"string","required":true},"instance":{"description":"Configura\u00e7\u00f5es da inst\u00e2ncia atual do widget.","type":"object","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp\/v2\/widgets":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"sidebar":{"description":"A barra lateral de onde se deseja retornar os widgets.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o widget.","type":"string","required":false},"id_base":{"description":"O tipo do widget. Corresponde ao ID no endpoint widget-types.","type":"string","required":false},"sidebar":{"default":"wp_inactive_widgets","description":"A barra lateral a que o widget pertence.","type":"string","required":true},"instance":{"description":"Configura\u00e7\u00f5es da inst\u00e2ncia do widget, se suportado.","type":"object","properties":{"encoded":{"description":"Configura\u00e7\u00f5es da inst\u00e2ncia codificados em Base64.","type":"string","context":["edit"]},"hash":{"description":"Configura\u00e7\u00f5es da inst\u00e2ncia em hash criptografado.","type":"string","context":["edit"]},"raw":{"description":"Configura\u00e7\u00f5es n\u00e3o codificadas da inst\u00e2ncia, caso tenha suporte.","type":"object","context":["edit"]}},"required":false},"form_data":{"description":"Dados no formato URL-encoded do formul\u00e1rio de administra\u00e7\u00e3o do widget. Usado para atualizar um widget que n\u00e3o permite ser instanciado. Apenas escrita. ","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wp\/v2\/widgets"}]}},"\/wp\/v2\/widgets\/(?P<id>[\\w\\-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o widget.","type":"string","required":false},"id_base":{"description":"O tipo do widget. Corresponde ao ID no endpoint widget-types.","type":"string","required":false},"sidebar":{"description":"A barra lateral a que o widget pertence.","type":"string","required":false},"instance":{"description":"Configura\u00e7\u00f5es da inst\u00e2ncia do widget, se suportado.","type":"object","properties":{"encoded":{"description":"Configura\u00e7\u00f5es da inst\u00e2ncia codificados em Base64.","type":"string","context":["edit"]},"hash":{"description":"Configura\u00e7\u00f5es da inst\u00e2ncia em hash criptografado.","type":"string","context":["edit"]},"raw":{"description":"Configura\u00e7\u00f5es n\u00e3o codificadas da inst\u00e2ncia, caso tenha suporte.","type":"object","context":["edit"]}},"required":false},"form_data":{"description":"Dados no formato URL-encoded do formul\u00e1rio de administra\u00e7\u00e3o do widget. Usado para atualizar um widget que n\u00e3o permite ser instanciado. Apenas escrita. ","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"force":{"description":"Se deve-se for\u00e7ar a remo\u00e7\u00e3o do widget ou mov\u00ea-lo para a barra lateral inativa.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp\/v2\/block-directory\/search":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"term":{"description":"Limitar resultados a blocos correspondentes ao termo da pesquisa.","type":"string","minLength":1,"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wp\/v2\/block-directory\/search"}]}},"\/wp\/v2\/pattern-directory\/patterns":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","default":100,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados para aqueles que combinam com um texto.","type":"string","minLength":1,"required":false},"category":{"description":"Limitar resultados para aqueles que combinam com o ID de uma categoria.","type":"integer","minimum":1,"required":false},"keyword":{"description":"Limitar resultados para aqueles que combinam com um ID de palavra-chave.","type":"integer","minimum":1,"required":false},"slug":{"description":"Limitar os resultados para aqueles que combinam com um padr\u00e3o (slug).","type":"array","required":false},"offset":{"description":"Deslocar o resultado para um n\u00famero especifico de itens.","type":"integer","required":false},"order":{"description":"Ordenar atributos de forma ascendente ou descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar cole\u00e7\u00e3o pelo atributo do post.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","favorite_count"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wp\/v2\/pattern-directory\/patterns"}]}},"\/wp\/v2\/block-patterns\/patterns":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wp\/v2\/block-patterns\/patterns"}]}},"\/wp\/v2\/block-patterns\/categories":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wp\/v2\/block-patterns\/categories"}]}},"\/wp-site-health\/v1":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-site-health\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wp-site-health\/v1"}]}},"\/wp-site-health\/v1\/tests\/background-updates":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wp-site-health\/v1\/tests\/background-updates"}]}},"\/wp-site-health\/v1\/tests\/loopback-requests":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wp-site-health\/v1\/tests\/loopback-requests"}]}},"\/wp-site-health\/v1\/tests\/https-status":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wp-site-health\/v1\/tests\/https-status"}]}},"\/wp-site-health\/v1\/tests\/dotorg-communication":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wp-site-health\/v1\/tests\/dotorg-communication"}]}},"\/wp-site-health\/v1\/tests\/authorization-header":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wp-site-health\/v1\/tests\/authorization-header"}]}},"\/wp-site-health\/v1\/directory-sizes":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wp-site-health\/v1\/directory-sizes"}]}},"\/wp-site-health\/v1\/tests\/page-cache":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wp-site-health\/v1\/tests\/page-cache"}]}},"\/wp-block-editor\/v1":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-block-editor\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wp-block-editor\/v1"}]}},"\/wp-block-editor\/v1\/url-details":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"O URL a ser processado.","type":"string","format":"uri","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wp-block-editor\/v1\/url-details"}]}},"\/wp\/v2\/menu-locations":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wp\/v2\/menu-locations"}]}},"\/wp\/v2\/menu-locations\/(?P<location>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"location":{"description":"Um identificador alfanum\u00e9rico para a localiza\u00e7\u00e3o do menu.","type":"string","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp-block-editor\/v1\/export":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wp-block-editor\/v1\/export"}]}},"\/wp-block-editor\/v1\/navigation-fallback":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wp-block-editor\/v1\/navigation-fallback"}]}},"\/wp\/v2\/font-collections":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wp\/v2\/font-collections"}]}},"\/wp\/v2\/font-collections\/(?P<slug>[\\\/\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp-abilities\/v1":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-abilities\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wp-abilities\/v1"}]}},"\/wp-abilities\/v1\/categories":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","default":50,"minimum":1,"maximum":100,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wp-abilities\/v1\/categories"}]}},"\/wp-abilities\/v1\/categories\/(?P<slug>[a-z0-9]+(?:-[a-z0-9]+)*)":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"Identificador \u00fanico da categoria da habilidade.","type":"string","pattern":"^[a-z0-9]+(?:-[a-z0-9]+)*$","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp-abilities\/v1\/abilities\/(?P<name>[a-zA-Z0-9\\-\\\/]+?)\/run":{"namespace":"wp-abilities\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET","POST","PUT","PATCH","DELETE"],"args":{"name":{"description":"Identificador \u00fanico para a habilidade.","type":"string","pattern":"^[a-zA-Z0-9\\-\\\/]+$","required":false},"input":{"description":"Par\u00e2metros da execu\u00e7\u00e3o da habilidade.","type":["integer","number","boolean","string","array","object","null"],"default":null,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]},"\/wp-abilities\/v1\/abilities":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","default":50,"minimum":1,"maximum":100,"required":false},"category":{"description":"Limita os resultados \u00e0s habilidades em uma categoria de habilidade espec\u00edfica.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wp-abilities\/v1\/abilities"}]}},"\/wp-abilities\/v1\/abilities\/(?P<name>[a-zA-Z0-9\\-\\\/]+)":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"name":{"description":"Identificador \u00fanico para a habilidade.","type":"string","pattern":"^[a-zA-Z0-9\\-\\\/]+$","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","pt-br","es"],"required":false}}}]}},"site_logo":243,"site_icon":140,"site_icon_url":"https:\/\/rocketbot.com\/wp-content\/uploads\/2021\/12\/rocketbot-iso.svg","_links":{"help":[{"href":"https:\/\/developer.wordpress.org\/rest-api\/"}],"wp:featuredmedia":[{"embeddable":true,"type":"site_logo","href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wp\/v2\/media\/243"},{"embeddable":true,"type":"site_icon","href":"https:\/\/rocketbot.com\/pt-br\/wp-json\/wp\/v2\/media\/140"}],"curies":[{"name":"wp","href":"https:\/\/api.w.org\/{rel}","templated":true}]}}
